Well, i violated my warranty today
I bought a new hard drive, a travelstar 40 Gb. I put it in, and used the drivebuilder, then put the dev 2.00 on it. then i did the same for the original drive.
Then i put the jumper on and slaved the 40 Gb to the master 20Gb. However, now empeg crashes.
Anyway, I'm trying to get the HD to work together to no avail.
emplode keeps crashing
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com)5 > hda2 hda3 hda4 CS4231A revision a0
If there is anyone present who wants to upgrade the flash, let them speak now,mpeg
or forever hold their peace...it seems not. Let fly the Penguins of Linux!itialised, PDIUSBD12 logo.
Probing
e000 v1.04rface...
Copying kernel...
hda: IC2
Calling linux kernel...drived 0089/88c1 (save
hda: IC25N040ATCS04-0, ATA DISK drive
empe
l.DS
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315ic driver initialised
(release)) #11 Tue Apr 1 18:49:59 BST 2003SK drivesk driver initialized: 16 RAM dis
smc chip id/revision 0x3349
Dentry hash table entries: 2048 (order 2, 16k)check:k Stahlman (erik
SMC9194: SMC91
Page cache hash table entries: 4096 (order 2, 16k)044b MAC 00:02:d7:26:09:3
Linux NET4.0 for Linux 2.2e.
Based upon Swansea Universit
5
Partition
Starting kswapd v 1.5
0
SA1100 serial driver version 4.27 with no serial options enabledmounted
dev 03:44 blksize=1024
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UARTnt=1
mke2fs
Filesystem label=Por
empeg dsp mixer initialised
empeg dsp initialised4 (log=0)
empeg audio-in initialised, CS4231A revision a0ul 24 2002
81
empeg remote control/panel button initialised.6d000
64 inodes per groupk/16M available (
empeg state support initialised 0089/88c1 (save to d0004080).ored on blocks:init)
empeg RDS driver initialised57345, 73729, 204801, 221185
RAM disk driver initialized: 16 RAM
NET4: Linux T
hdstress.cpp
hda: IC=Nzwqmvss04-0, ATA DISK drive
hda: IC=Nzwqmvss04-0, ATA DISK drivenning down.ision:Tue May 18 03:11:39
hd
hda: IC=Nzwqmvss04-0, ATA DISK drive0 on fd=5
ide0 at 0x000-0x007,0x038 on irq 6irtual tty driver for
hda: IC=Nzwqmvss04-0, 57231MB w/2042kB Cache, CHS=7295/255/63 )
hdstress.cpp 1
empeg-flash driver initialized=5
smc chip id/revision 0x3349ng kswapd v 1.5
Scheduli
empeg-pump v0.03 (19980601)
Mounting proc
VFS: Can't find an ext2 filesystem on dev ide0(3,4).
Tried to mount /dev/hda4 as ext2 but got error 22
No primary hard disk
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComplùStarti
ng player
! tags.cpp : 61:Failed to open tags (0xc0041002).
Vcb: 0x4086d000
19:03:40.718 protocolclient.cpp(1278) : I [0394] ProtocolClient::SendCommand()=0
19:03:40.718 protocolclient.cpp(1351) : I [0394] Restart command sent, waiting for player to begin responding
19:03:42.218 protocolclient.cpp(992) : I [0394] ProtocolClient::WaitForUnitConnected(timeout=90)
19:03:43.140 connection_win32.cpp(1058) : W [0394] connect() failed: 10061
19:03:43.140 packets.cpp(77) : I [0394] NEW request, id=0x808080cb
19:03:44.140 connection_win32.cpp(1058) : W [0394] connect() failed: 10061
19:03:44.640 connection_win32.cpp(1063) : I [0394] Created connection to '192.168.2.7' (0x702a8c0)
19:03:44.640 connection_win32.cpp(1000) : D [0394] Select timed out (0ms)
19:03:44.640 protocolclient.cpp(1041) : I [0394] ProtocolClient::WaitForUnitConnected()=0
19:03:44.640 protocolclient.cpp(1366) : I [0394] ProtocolClient::InternalRestart()=0
19:03:44.640 database_fetcher.cpp(159) : E [0394] CheckPlayerDatabase failed, status = 0xc0041016
19:03:44.640 DatabaseOperation.cpp(109) : I [0394] DatabaseOperation::CloseConnection
any suggestions?
