#209713 - 18/03/2004 02:13
Re: buying tires
[Re: Daria]
Loc: Texas, USA
Have you tried www.tirerack.com? They can be a little thickheaded over fitting non-standard tires to your car but I've used them before with good results.
#209714 - 18/03/2004 06:35
Re: buying tires
[Re: Mach]
Ditto on TireRack. My local tire shop was happy to receive my TireRack shipment. They called me when the tires arrived; I dropped in and had my tires replaced while eating lunch across the street at a fine Turkish kebab joint. Couldn't have been any easier!
#209715 - 18/03/2004 09:49
Re: buying tires
[Re: Daria]
TireRack doesn't seem to offer the Zero Pressure variant, but their review mentions it, and says they're original equipment on the Lincoln Continental.
User reviews and ratings are so-so on the non-ZP variety.
#209716 - 18/03/2004 09:53
Re: buying tires
[Re: tonyc]
More than anything, I think TireRack's reviews are extraordinarily helpful. You might want to change your mind on the tire, Derrick.
They even have a tire selection wizard now which you might want to check out, plus it seems that they have a suggested list of installers. (I've always had qualms with that, since the good installers might be mad you didn't buy the tires from them and the ones that don't sell them are more likely to be bad installers.)
Edited by wfaulk (18/03/2004 10:02)
#209717 - 18/03/2004 11:02
Re: buying tires
None of the low rolling resistance tires seem to be popular, that's the scope I mean to choose from.
As far as installers, there's a small garage 2 blocks from me whose main business is towing; They'd install them with no qualms (and previously they've installed tires for me after calling me and getting approval to go buy them elsewhere).
Or I could take the car to the dealer and they wouldn't give me flak either. Well, no more flak than my father's going to give me anyway
#209719 - 18/03/2004 11:11
Re: buying tires
[Re: Daria]
Tiresavings has a few MXV4 varieties. I am not sure which model is runflat. I came close to buying Champiro tires from them since they are one of the few stores that carry them. Eventually I just bought some Kumhos from TireRack, so I can't comment on Tiresavings' performance as a vendor.
#209720 - 18/03/2004 11:14
Re: buying tires
[Re: Daria]
Those michelins are rediculously overpriced because they are what came on the car new. Look in to a Michelin pilot.
Catapultam habeo. Nisi pecuniam omnem mihi dabis, ad caput tuum saxum immane mittam.
#209721 - 18/03/2004 19:35
Re: buying tires
[Re: Daria]
Does anyone have suggestions for finding hard-to-find tires?
Before you invest a lot of money in run-flats, investigate the repairability of the tires you choose.
There are differing opinions (perhaps different brands have different requirements) about whether a run flat tire that has actually been run flat can be repaired. Some manufacturers state that running them without air causes irreparable sidewall damage.
Also, give some consideration to why you want run-flat tires? They are considerably more expensive, and may have inherent performance disadvantages compared to a conventional tire. If your only reason for wanting them is to be able to change a flat tire at a place of your choosing rather than where you are at the moment, then ask yourself how often that situation actually arises. Is it worth it?
The only time in the last 40 years that I really would have liked run flat tires was two winters ago when I had to change a flat tire on my station wagon at 45 degrees below zero.
#209725 - 19/03/2004 02:34
Re: buying tires
Well, the Bristol comes with run-flats as standard mainly because of what would happen if a normal one would blow at 100 mph...
#209726 - 19/03/2004 04:02
Re: buying tires
[Re: julf]
The size and build of the bristol it probably to stop bristol shaped holes appearing all over the place.
Aberdeen Scotland
#209727 - 19/03/2004 04:05
Re: buying tires
[Re: Daria]
well how about one of those cans of get you home tyre repair stuff that name completely escapes me at the moment. it goes in and reapirs the hole and then said gunk inflates the tyre. Some cars now come with a can of that instead of a spare wheel.
Aberdeen Scotland
#209728 - 19/03/2004 04:18
Re: buying tires
[Re: thinfourth2]
Always carry the stuff on my motorbike on any longer trips. But it doesn't always help. If the puncture is a big enough cut, the spray stuff won't seal/fill enough.
#209729 - 19/03/2004 04:19
Re: buying tires
[Re: thinfourth2]
Hmm... You might have a point
Always amazed at how heavy it is despite all the aluminum.
#209730 - 19/03/2004 04:19
Re: buying tires
[Re: thinfourth2]
Yeah, I've got a can of that stuff. It's in the car at the moment (obviously) so I can't remember what it's called. I've also got a space-saver tyre* in the boot** as
well.
* tire
** trunk
#209731 - 19/03/2004 10:16
Re: buying tires
[Re: Roger]
