#207016 - 26/02/2004 10:00 Bizarre stormfront
It's supposed to snow here in Raleigh yet again (we've already had more snow this year than we usually see in a decade).
But not if Braniac has anything to say about it:
#207017 - 26/02/2004 10:02 Re: Bizarre stormfront [Re: wfaulk]
And a closeup. I think you can mathematically determine the focus of the hyperbola.
#207018 - 26/02/2004 11:33 Re: Bizarre stormfront [Re: wfaulk]
Heh, I think someone needs to clean off the pile of snow around the bottom half of their radar dish.
#207019 - 26/02/2004 16:15 Re: Bizarre stormfront [Re: wfaulk]
Micman2b
Loc: Central, NC, USA
The radar in Raleigh is scanning in an low upward angle. The snow over the radar site was not making it to the ground. Wnat you are seeing to the south is where it actually is snowing. To the west and to the east, the radar is picking up the snow that is not reaching the ground as the radar angle is picking up the snow echoes. I live under the N in Burlington and it was not snowing here at the time even though the radar was picking up echoes... in fact, it was only snowing in a line from Asheboro, Pittsboro, Wilson, Greenville line at the time of this radar... finally saw some here an hour later however...
_____________
Sean in NC
130gb MK2a w/ 32mb ram
80gb MK2a empeg spare
#207020 - 26/02/2004 16:26 Re: Bizarre stormfront [Re: wfaulk]
RobotCaleb
im confused. how are all of those colors significant to snow on a radar dish, upwards pointing dishes, and calculated hyperbolas?
#207021 - 26/02/2004 16:30 Re: Bizarre stormfront [Re: RobotCaleb]
im confused
Bitt was making the point that the storm front appeared to be making a nice circular path to avoid the center of the radar dish's sweep, which happened to be Raleigh. He was saying that the radar picture was funny because it looked like the storm was avoiding Raleigh.
I suggested that piled-up snow around the base of the radar might account for the visual anomoly, but a much more likely and logical explanation of low ground angle was offered.
#207022 - 26/02/2004 16:31 Re: Bizarre stormfront [Re: RobotCaleb]
Micman2b
All of those colors are depicting really heavy thundersnow just south of raleigh through Fayetteville. They were getting 3"+ an hour of snow at the time. the radar dish, on the second map, is between Garner and Clayton on Hwy 70. The green/yellow/red line just to the south is where the snow is actually reaching the ground.
Sean
_____________
Sean in NC
#207023 - 26/02/2004 16:33 Re: Bizarre stormfront [Re: tfabris]
RobotCaleb
roger
i now understand. thanks
#207024 - 26/02/2004 16:39 Re: Bizarre stormfront [Re: Micman2b]
Micman2b
Do you want another cool explaination??? Ok. since there were thunderstorms to the south, the radar may have actually been correct. There may have been no snow to the north of the storms since the Tstorm updrafts were blocking the moisture in upper air flow. To the west and east there was no blocking updrafts to limit the moistures path to the north...
Sean in NC
_____________
Sean in NC
#207025 - 26/02/2004 16:53 Re: Bizarre stormfront [Re: Micman2b]
You left out aliens. It could be aliens, too.
#207026 - 26/02/2004 17:10 Re: Bizarre stormfront [Re: tfabris]
Micman2b
Sunspots... I forgot sunspots...
Sean
_____________
Sean in NC
#207027 - 26/02/2004 18:58 Re: Bizarre stormfront [Re: Micman2b]
An interesting explanation. Sounds like you have some knowledge in the area of meteorology.
#207028 - 26/02/2004 20:13 Re: Bizarre stormfront [Re: wfaulk]
Micman2b
I am just an amateur. No degree or anything... the only reason I got a internet connection back in 1995 was to get radar data...
Sean
_____________
Sean in NC
