#205279 - 17/02/2004 21:13 array of strings in STL C++?
Loc: Los Angeles, CA
i want to read a text file into an array of strings. this isn't possible, is it? i'm going to have to use characters instead? anyone have a suggestion?
#205280 - 18/02/2004 02:22 Re: array of strings in STL C++? [Re: image]
Hold on a second, I'll cobble something together.
#205281 - 18/02/2004 02:36 Re: array of strings in STL C++? [Re: Roger]
/* read_lines.cpp
#include <stdio.h>
#include <string>
#include <vector>
int main(int argc, char *argv[])
if (argc < 2)
fprintf(stderr, "Usage: read_lines filename\n");
return 1;
FILE *fp = fopen(argv[1], "r");
if (!fp)
fprintf(stderr, "Failed to open %s\n", argv[1]);
return 2;
typedef std::vector< std::string > lines_t;
lines_t lines;
const size_t buffer_size = 1024;
char *buffer = new char[buffer_size];
std::string residue;
while (!feof(fp) && !ferror(fp))
size_t bytes_read = fread(buffer, 1, buffer_size, fp);
const char *buffer_end = buffer + bytes_read;
const char *b = buffer;
const char *e;
while((e = (const char *)memchr(b, '\n', buffer_end - b)) != NULL)
std::string line(b, e);
residue += line;
lines.push_back(residue);
residue.clear();
b = e + 1;
// Is there any residue?
if (b < buffer_end)
// There's some residue
residue += std::string(b, buffer_end);
if (!residue.empty())
delete [] buffer;
fclose(fp);
int n = 0;
for (lines_t::const_iterator i = lines.begin(); i != lines.end(); ++i)
++n;
printf("%d: %s\n", n, i->c_str());
return 0;
#205282 - 18/02/2004 02:40 Re: array of strings in STL C++? [Re: Roger]
And a quick description of how it works. The main body of the program reads the named file into a vector of strings.
It does this by allocating a buffer and reading the file into it until it runs out of file. For each buffer of data that it reads from the file, it looks through for line-breaks, using memchr.
Because the buffer might not finish with a complete line, we collect the last part of the buffer into a string called 'residue'. So we need to remember to keep it around for the start of the next buffer.
When we run out of file, we might still have some residue, so we add this to the vector as well.
Then, when we're done, we print out the vector to the screen.
#205283 - 18/02/2004 09:14 Re: array of strings in STL C++? [Re: Roger]
Oh, my lord. Fifty-five lines just to read in a file line-by-line and print it back out! And people complain about C being too low-level.
#205284 - 18/02/2004 09:17 Re: array of strings in STL C++? [Re: Roger]
cool. funny how i could understand what needs to happen much easier using c functions, when i was trying to do it with fstream and ending up with really jumbled up code. thanks roger.
#205285 - 18/02/2004 13:52 Re: array of strings in STL C++? [Re: image]
siberia37
Loc: Tacoma,WA
Use delphi instead:
procedure ReadTextFile(AFile : String);
var
SL : TStringList;
begin
SL := TStringList.Create;
try
SL.LoadFromFile(AFile);
// strings are now in the stringlist object
finally
SL.Free;
end;
end;
#205286 - 18/02/2004 14:01 Re: array of strings in STL C++? [Re: siberia37]
C'mon... be fair to Roger...he did print them back out...
Or Perl:
#!/usr/bin/perl
open F,"test.pl";@l=<F>;close F;print @l;
#205287 - 18/02/2004 14:12 Re: array of strings in STL C++? [Re: JBjorgen]
or Python:
f = file("file.txt", "r")
l = f.readlines()
f.close()
#205288 - 18/02/2004 14:14 Re: array of strings in STL C++? [Re: JBjorgen]
julf
Or shell:
#/bin/sh
cat $MYFILE
#205289 - 18/02/2004 14:20 Re: array of strings in STL C++? [Re: julf]
julf - requirement was that it had to read the lines of the file into an array.
#205290 - 18/02/2004 15:21 Re: array of strings in STL C++? [Re: JBjorgen]
Have to use ksh. No lesser sh has arrays.
#!/usr/bin/ksh
exec 5<file.txt
set -A array
i=0
while read -ru5 array[$i]; do
i=$(($i+1))
done
# And, to be complete
i=0
j=${#array[@]}
while [ $i -lt $j ]; do
echo ${array[$i]}
i=$(($i+1))
done
#205291 - 19/02/2004 12:54 Re: array of strings in STL C++? [Re: JBjorgen]
julf
Duhh. Guess I should learn to read
