#197345 - 08/01/2004 22:03 How to install Alpha 5
kendrick
Ok, so i have emplode 2.10. And i go to upgrade player , and i choose the alpha 5 and it goes through the whole process and then empeg restarts and none of my database is up there. The player says ALPHA 5 when it starts but none of my playlists show up. Any ideas? If i put version 2.00 back up there my playlists show up fine.
#197346 - 08/01/2004 22:22 Re: How to install Alpha 5 [Re: kendrick]
Ezekiel
Loc: NH USA
Alpha 5 can't build databases. Install Alpha 3, build the databases and then install Alpha 5 (someone correct me if I have this wrong).
-Zeke
WWFSMD?
#197347 - 08/01/2004 22:47 Re: How to install Alpha 5 [Re: Ezekiel]
kendrick
Where can i find alpha 3?
#197348 - 08/01/2004 23:22 Re: How to install Alpha 5 [Re: kendrick]
crazymelki
Loc: Switzerland
crazymelki.com
#197349 - 08/01/2004 23:49 Re: How to install Alpha 5 [Re: crazymelki]
kendrick
Well i installed alpha 3 and the playlists showed up fine.
Then i installed alpha5 and none of the playlists showed up.
#197350 - 08/01/2004 23:52 Re: How to install Alpha 5 [Re: kendrick]
SE_Sport_Driver
Quoting Mark Lord from the "Merry Christmas" thread in General:
After your v3alpha boots, do a SYNC from emplode to write the databases to disk (on boot, they are not written to disk -- read-only filesystem).
After the sync, v3alpha5 should work just fine.
You mgiht want to keep sync'ing in 3Alpha until it can boot from a power-up without needing to "Rebuild the Database". This will ensure it's properly built.
Edited by SE_Sport_Driver (08/01/2004 23:55)
#197351 - 09/01/2004 00:05 Re: How to install Alpha 5 [Re: SE_Sport_Driver]
kendrick
When i try to sync in emplod with alpha 3
I get Download Failed while checking database Error 0Xc0041002
#197352 - 09/01/2004 00:09 Re: How to install Alpha 5 [Re: kendrick]
Chaosium
"Well i installed alpha 3 and the playlists showed up fine.
Then i installed alpha5 and none of the playlists showed up."
Heh, same thing happens to me.
"After your v3alpha boots, do a SYNC from emplode to write the databases to disk (on boot, they are not written to disk -- read-only filesystem).
After the sync, v3alpha5 should work just fine."I
I'd do that if I could. For some reason in v3alpha5 every version of emplode (or jEmplode) doesn't seem to work properly, even the updated alpha version.
#197353 - 09/01/2004 00:20 Re: How to install Alpha 5 [Re: kendrick]
crazymelki
Loc: Switzerland
Have you installed JEmplode Version 48 or higher....If yes, then make a sync first with that and try then again with the Emplode 2.x. This should work work..I did fix a cupple of time in this way.
bye
crazymelki.com
#197354 - 09/01/2004 00:41 Re: How to install Alpha 5 *DELETED* [Re: crazymelki]
kendrick
Post deleted by kendrick
#197355 - 09/01/2004 00:45 Re: How to install Alpha 5 [Re: kendrick]
kendrick
When i try to use the newest jemplode.jar i get an error when tryin to open the jemplode app.
#197356 - 09/01/2004 01:32 Re: How to install Alpha 5 [Re: kendrick]
mschrag
Loc: Richmond, VA
jEmplode can explicitly produce 346 different errors ... If you were to pick one in particular that would be helpful. I could try to guess, but the odds are definitely against me.
#197357 - 09/01/2004 02:06 Re: How to install Alpha 5 [Re: SE_Sport_Driver]
Daria
Except it's not enough. If you don't believe me, I'll film it and put a movie online.
#197358 - 09/01/2004 02:16 Re: How to install Alpha 5 [Re: Daria]
kendrick
Cool finally got it working.
I used jemplode 44 with alpha 3 and synch a few times, tehn i use jemplode to update to alpha 5 and then synch a few more times.
#197359 - 09/01/2004 02:53 Re: How to install Alpha 5 [Re: kendrick]
kendrick
Well it was working, then i tried to add some playlists and delete some playlists and now nothing shows up.
Using version alpha 3, i can sync in emplode 2.10 or jemplode v44.
In version alpha 3 i can delete playlists and rebuild fine in jemplode v44, but in version alpha 5 it freezes when im tryin to synch after making a playlist change and then when i restart the empeg it shows no playlist
#197360 - 09/01/2004 03:13 Re: How to install Alpha 5 [Re: kendrick]
kendrick
When i try to use the newest jemplode.rar i get this error
The error says
Unable to locate the application's 'main' class. The class 'org.jempeg.empeg.emplode.Main' must be public and have a 'public static void main(String[])' method. (LAX)
#197361 - 09/01/2004 09:32 Re: How to install Alpha 5 [Re: kendrick]
Yes, that behaviour makes perfect sense. Allow me to repeat for you:
v3-alpha5 cannot CANNOT CANNOT rebuild databases.
So don't try modifying the player's content while running alpha5. No new tunes, no new playlists. v3alpha3 is required for such.
#197362 - 09/01/2004 11:29 Re: How to install Alpha 5 [Re: mlord]
Loc: Los Angeles, CA
unless you use the fast database rebuild option in the newer jemplodes. but ignore me if i add to your confusion.
#197363 - 09/01/2004 11:33 Re: How to install Alpha 5 [Re: image]
The fast rebuilds are not reliable yet -- they worked sometimes for me, and failed other times. I'm back at v2final now.
#197364 - 09/01/2004 11:51 Re: How to install Alpha 5 [Re: mlord]
kendrick
Oh ok, well that makes sense.
#197365 - 09/01/2004 12:46 Re: How to install Alpha 5 [Re: image]
mschrag
Loc: Richmond, VA
Yeah .. I wouldn't really depend on this for a couple releases. I hope it will be there soon, but it's definitely not yet.
#197366 - 10/01/2004 07:39 Re: How to install Alpha 5 [Re: kendrick]
thinfourth2
Okay it worked i went on a ship and the next alpha came out
Can i come home now
#197367 - 10/01/2004 08:40 Re: How to install Alpha 5 [Re: thinfourth2]
Sorry. Nope. Stay away and maybe we'll get another release
#197368 - 10/01/2004 10:05 Re: How to install Alpha 5 [Re: tman]
mtempsch
Hmm, doesn't he need to come home, and then leave again, for a new release to be possible?
#197369 - 10/01/2004 10:24 Re: How to install Alpha 5 [Re: mtempsch]
SE_Sport_Driver
How far does he have to go for a Beta as opposed to an Alpha?
