#195137 - 27/12/2003 19:52 HELP!. i Fu**ed up mu empeg
coregbg
When i smoked my empeg hdd, replaced it and ran the empeg upgrade wizard with the 2.0 software (developer), then boot it with the com cable attached i get: Tried to mount /dev/hda4 as reiserfs but got error 19, WHY?
//coregbg
#195138 - 27/12/2003 20:02 Re: HELP!. i Fu**ed up mu empeg [Re: coregbg]
That message can be ignored -- perfectly normal. Anything else the matter?
#195139 - 27/12/2003 20:21 Re: HELP!. i Fu**ed up mu empeg [Re: mlord]
coregbg
yupp, i cant save anything to the player.... not via emplode nor via jemplode 47,
not even owner info....
//coregbg
#195140 - 27/12/2003 20:34 Re: HELP!. i Fu**ed up mu empeg [Re: coregbg]
Did you run the builder image before attempting to install the player firmware?
#195141 - 27/12/2003 20:38 Re: HELP!. i Fu**ed up mu empeg [Re: tfabris]
coregbg
yes, now ive restarted with builder image 2.0, then v3.0alpha5, and now ime getting this:
Mounting proc
No secondary hard disk
Starting player
allocating_buffer_pool.cpp: 49:sizeof(BufferEntry) = 32
allocating_buffer_pool.cpp: 50:sizeof(BlockEntry) = 16
player.cpp : 569:empeg-car 3.00-alpha5 2003/12/24.
! tags.cpp : 61:Failed to open tags (0xc0041002).
! memory_stream.cpp : 42:MemoryStream failed to allocate memory.
! tunedb_disk.cpp : 878:Failed to build database. Bad. 0xc007000e
LAC construct 0x405ae008
Prolux 4 empeg car - 2.1490 Dec 24 2003
Vcb: 0x4066e000
all OK?
//coregbg
#195142 - 27/12/2003 20:40 Re: HELP!. i Fu**ed up mu empeg [Re: coregbg]
coregbg
and this...
//coregbg
#195143 - 27/12/2003 20:43 Re: HELP!. i Fu**ed up mu empeg [Re: coregbg]
and this...
This is related to Alpha5. I would personally stay with 2.00 final first, to make sure it works. Only after I would proceed with alpha3 first, and alpha5 after (but before moving to alpha5, you should read this topic: http://empeg.comms.net/php/showflat.php?Cat=&Board=empeg_general&Number=193841&page=0&view=collapsed&sb=5&o=21&fpart= very carefully)
#195144 - 27/12/2003 20:45 Re: HELP!. i Fu**ed up mu empeg [Re: Taym]
coregbg
i know, i used to run alpha3 without probs, but now when i try to run 2.0 i get the very same error...
//coregbg
#195145 - 27/12/2003 20:48 Re: HELP!. i Fu**ed up mu empeg [Re: coregbg]
Sure you're using 2.00final EMPLODE?
#195146 - 27/12/2003 20:50 Re: HELP!. i Fu**ed up mu empeg [Re: Taym]
coregbg
yepp, donno what to do next ....
//coregbg
#195147 - 27/12/2003 21:08 Re: HELP!. i Fu**ed up mu empeg [Re: coregbg]
Out of curiosity, I would ftp the player, delete the dbase file, reboot the player and make sure it rebuilds the dbase properly. No Emplote/Jemplode involved.
#195148 - 27/12/2003 21:11 Re: HELP!. i Fu**ed up mu empeg [Re: Taym]
coregbg
finally,. i got it working .... woll post up later on...
//coregbg
