#193621 - 15/12/2003 09:35
Why are only the rear sled RCAs grounded?
Loc: Bucks, UK.
Hi,
Firstly (Tony), apologies if this has been covered before as I can't seem to find this one in the FAQ or by searching.
I have just spent a very long time chasing out the dreaded alternator whine, and traced it to the fact that by design, only the rear RCAs are grounded inside the Empeg.
Why are only the rear sled outputs grounded and not the fronts and AUX? Is this a design feature to prevent formation of ground loops, or an oversight? as when using a multiple amplifier system, the front signal ground is left floating and is open to induced noise in the RCA lead.
This was cured by the addition of ground leads from my RCA plugs to my new SUPERgound(tm) wire installed in a previous attempt to rid my system of the aforementioned whine.
Oli.
#193622 - 15/12/2003 11:30
Re: Why are only the rear sled RCAs grounded?
[Re: Oli]
Loc: New Jersey
Did I hear 'alternator whine'?
I am the King of alternator whine as my many posts in the past can attest to......
Please provide some details on what you did to rid yourself of this harrowing experience so maybe i can put my system to rest!
Thanks,
Ed
#193623 - 15/12/2003 11:59
[Re: Oli]
Firstly (Tony), apologies if this has been covered before as I can't seem to find this one in the FAQ or by searching. It's not in the FAQ because I didn't know about it. This is news to me.
How certain are you that this is by design and not just a flaw on your unit? Can you give a description or photos of exactly what the problem is with your unit? Something to check... are you sure that the RCAs that you say are floating are really the rear output RCAs and not the aux-in RCA's?
It's definitely a FAQ-able item if it turns out to be true.
#193624 - 15/12/2003 12:09
Given that he claimed the fronts were floating, confirming the rears were seems a bit silly.
#193626 - 15/12/2003 12:20
Loc: New Jersey
..ok...indulge me..what is a 'floating ground'?
#193627 - 15/12/2003 12:25
Loc: Bucks, UK.
Hi Tony,
Cue the mists of time....
It all started when I transferred my set up from my trusty old 1986 MK2 Golf 1.3 to my new 1990 MK2 Golf GTI. My set up consists of an Empeg MK2a, one amp running two subs, and another running components in the front. I have stinger triple screened RCAs and 8 gauge ground cable from both amps to a very secure ground.
The trouble started when I picked up a nasty alternator whine which I attributed to a normal ground loop. I double checked all my grounds, cleaned all battery and earth strap points, ran a new ground solely for the Empeg's harness and also running to the sled itself, I was satistied that it wasn't a 'normal' ground loop problem.
I then went after signal. I knew the whine entered the system as a result of docking the empeg, as with the amps powered up, and the Empeg undocked, the noise disappeared. I first tried earthing the RCAs at the amp end knowing that the amps provided a balanced input. No improvement. I then tested the harness to check continuity of the grounds. I discovered that only the rear RCA ground leads were going to ground. So I checked the harness for loose pins, and narrowed it down to something inside the player, I dismantled the player to check the internal connections, and when these tested ok, I removed the main board and started tracing tracks. To my surprise, the front and AUX grounds have nothing connected to them while the rear output has a thick ground connection.
The problem arose because when transferring the system, I decided to run the subs from the rear RCAs and the components from the front RCAs thus separating the grounds that were previously tied together in the old set up.
So I modified the RCA plugs at the head unit end to incorporate two flying ground leads to which I soldered eyelets to and then bolted them to the new ground connection on the back of the sled.
The silence is golden.
Problem solved.
Oli.
#193628 - 15/12/2003 12:35
[Re: Oli]
If I recall correctly, the PCB is multilayered. If you found the problem by visually tracing tracks, it's possible that you're missing one of the inner layers.
However, if you actually continuity tested the traces themselves, the odds are better that your diagnosis could be accurate.
You mentioned something about your amp having a floating ground? In that case, grounding the RCA shrouds might merely have been solving that issue as opposed to solving a problem in the player?
#193629 - 15/12/2003 12:37
[Re: Oli]
Loc: Bucks, UK.
Maybe someone else with a multimeter can confirm this.
Pins numbered 16, 19 & 22 of the docking connector should connect to the chassis. Only pin 16 is on mine.
The numbers are printed on the inside of the connector at either end.
they are numbered line this looking from at the back of the empeg:
1 2 3 4 5 6 7 8 9 10 11 12
13 14 15 16 17 18 19 20
#193630 - 15/12/2003 12:59
[Re: Oli]
Well thankyou Oli. I now have whine free audio thanks to you. I always thought it sounded odd and then I realised the whine was only coming from the rears. I popped a ground lifter in circuit and hey presto crystal clear silence.
The mistake I'd made last time was that I was lifting both pairs. It was only your post that made me think about it again.
#193631 - 15/12/2003 13:20
[Re: Oli]
Loc: Atlanta, Georgia
I'll verify this on both of my Ml2's (an early, early model, and a later one) see what I get..
I'll take care of it tonight and post tomorrow..
Me.
Mike 'Fox' Morrey
128BPM@124MPH. Love it!
2002 BRG Mini Cooper
#193632 - 15/12/2003 14:03
[Re: foxtrot_xray]
This find could make a lot of folks happy. Good catch if it turns out to be a universal problem!
#193633 - 15/12/2003 14:37
[Re: andym]
Loc: New Jersey
ummm..what do u mean by 'ground lifter'????
#193634 - 15/12/2003 14:42
[Re: edsmiata]
ground isolator
#193635 - 15/12/2003 14:56
[Re: andym]
Loc: New Jersey
ahhh..is that the little black box with male/female connectors and the little ground wires leading out?
#193636 - 15/12/2003 15:03
[Re: edsmiata]
is that the little black box with male/female connectors and the little ground wires leading out? Depends on the system and on what you're talking about.
A ground loop isolator is a third party device (a black box with RCA leads) that goes inline between the amp and the head unit to remove a ground loop between the two.
A ground lift is a feature built into some amplifiers which deliberately disconnects the RCA ground shields from the amplifier's chassis ground.
edit: To clarify. A ground loop isolator is not the same thing as a ground lift. It's feasible that either one of these things could be built into a black box with RCA leads, but they have two completely different functions. The former separates all electrical connections on the RCA leads between the head and amp while still providing a method for the audio signal to be sent down the wire. A ground lift simply disconnects the shields while leaving the center pin untouched.
#193637 - 15/12/2003 15:06
[Re: edsmiata]
Yes, thats the one. The lifting is simply describing what is actually being done.
#193638 - 15/12/2003 21:57
[Re: Oli]
The most common way this happens on mk2s is that there's a fault with the main power ground, and the player tries to power itself via the audio grounds - which burn out. We thickened up the traces a bit on the mk2a, but I can believe it could still happen.
#193639 - 15/12/2003 22:13
[Re: Oli]
Could you explain this sentence to me again? I'm suffering from what sounds like exactly the same issue, but I can't figure out what this sentence means. Are you saying you have permanently connected the empeg to the sled? How do you take it out of your car? Perhaps I'm totally failing to understand. I guess I don't know what a flying ground lead is, as opposed to a regular ground lead.
#193640 - 16/12/2003 01:22
[Re: Defiler]
I quickly drew this in ms paint, hopefully you can get a better idea.. I think I understand the concept..
#193641 - 16/12/2003 07:30
[Re: Narkotic]
Loc: Bucks, UK.
I unscrewed the housing of the plugs on the end of each RCA lead from the amps and then soldered a ground wire to the screen inside the plug. I then attached the ground wire to one of the bolts on the back of the sled bypassing the empeg's harness and going straight to ground.
diagram attached.
Has anyone else managed to verify whether this issue is present on other players?
Oli.
Edited by Oli (16/12/2003 07:31)
#193642 - 16/12/2003 07:32
[Re: Oli]
Loc: Bucks, UK.
diagram
#193643 - 16/12/2003 08:39
[Re: andym]
Andy M:
You described an issue with whine from the REAR, whereas the title of this thread suggests to me that the original poster thought the problem was only with the fronts..
Weird.
Anybody with a Home Dock (from me) can very easily check the FRONT grounds with an ohm meter -- just dock your player, and check resistance between the player's case (use the side vent holes for access) and the rear mounted RCA plugs. Mine measure about 0.0 Ohms: definitely grounded.
#193644 - 16/12/2003 08:40
[Re: Daria]
The fronts in my Mk2a units are definitely all grounded -- anyone with a Home Dock can check this rather easily.
#193645 - 16/12/2003 09:12
Loc: Bucks, UK.
Hi Mark, thanks for checking your players.
Maybe i have burnt out some tracks somehow. That could be possible with the front ground, but I find it is strange that the AUX ground has also failed as I have never had this connected to anything.
Hugo- do you have a copy of the mk2a PCB design that would make it possible to see if a burnt out front ground would also take out the aux ground?
Also, my front amp is a Rockford with floating ground inputs, so it wouldn't seem unlikely that the empeg could ground through it.
#193646 - 16/12/2003 10:09
Mark,
I have to say the plugs have been switched round so many times I may have got them mixed up. It was definately the rear speakers, although I hardly ever use the fader/balance control, so it could have been the front pre outs feeding the rear channels on the amp. It's all still repeatable, there's whine on one pair and silence on the others. I'm not in the mood to remove the sled and have a look as it's far too cold outside. I'll probably have another look when it gets a bit warmer.
#193647 - 16/12/2003 10:09
[Re: altman]
I'd love to FAQ this. Is there a clear visual inspection method or a certain way to continuity test it?
#193648 - 16/12/2003 10:12
You described an issue with whine from the REAR, whereas the title of this thread suggests to me that the original poster thought the problem was only with the fronts. This would be consistent with the title of the thread. If the front connectors were ungrounded, then the rear connectors would act as the ground path and thus have whine.
#193649 - 16/12/2003 10:25
Loc: Bucks, UK.
you can test it with a multimeter like this:
#193650 - 16/12/2003 10:54
[Re: Oli]
Loc: Louisiana, USA
On mine 16 and 19 are grounded, but not 22.
Stu
