#192148 - 06/12/2003 07:50 Home install
maurij
Just got my housing from coolblue
Jason
#192149 - 06/12/2003 07:52 Re: Home install [Re: maurij]
maurij
some more pics
inside is a netgear wireless ethernet adaptor and a bluetooth serial module (not actually working yet). both are powered by the main power brick
Jason
#192150 - 06/12/2003 07:53 Re: Home install [Re: maurij]
maurij
another from the front
quality of this one isn't the best
Jason
#192151 - 06/12/2003 07:54 Re: Home install [Re: maurij]
maurij
from the rear
Jason
#192152 - 06/12/2003 07:55 Re: Home install [Re: maurij]
maurij
many thanks to andy (coolblue). he did a great job
Jason
#192153 - 06/12/2003 15:11 Re: Home install [Re: maurij]
Daria
Which bluetooth serial module?
#192154 - 07/12/2003 05:31 Re: Home install [Re: Daria]
maurij
its called free2move serial port plug
the website: http://www.free2move.se/prod_spp.htm
Jason
#192155 - 07/12/2003 08:38 Re: Home install [Re: maurij]
skibum
Loc: Swindon, UK
which costs about £134 quid (at least here in the UK). Expensive just for series access.
#192156 - 08/12/2003 12:01 Re: Home install [Re: maurij]
coolblue
Loc: Switzerland
Thanks Jason
Until today I made five housings.
I made an album with some pictures of this five housings.
#192157 - 08/12/2003 13:04 Re: Home install [Re: coolblue]
These housings are great! Especially no. 3, although I wonder wether it'd look even better if it was distressed
#192158 - 08/12/2003 20:59 Re: Home install [Re: coolblue]
FireFox31
Loc: East Coast, USA
Holy !!!!, that's pretty awesome! No, that's QUITE awesome. Rack mount that sucker above an amp, DAT, EQ, CDR, and some other stuff, and it will blend right in.
But, about the cables in the back: they kinda seem to take away from it. Would it be possible to mount the empeg in the center of the box and extend the rear connectors, like you extended the front display? Shouldn't be TOO hard (though it'd be a lot of silly 4" cables) and it would clean up the appearance of the rear of the unit.
But heck, that thing looks SO nice!!
FireFox31
#192159 - 08/12/2003 21:00 Re: Home install [Re: maurij]
FireFox31
Oh yeah, and is that a FAT flat screen TV in the background reflecting off the mirror just behind the box? Haha, nice!
FireFox31
#192160 - 09/12/2003 12:32 Re: Home install [Re: FireFox31]
coolblue
Loc: Switzerland
My first idea was also to mount the empeg in the center.
This solution needs more parts an there is much more handwork.
The main problem is the standing out of the bracket to mount the handle.
After I found a good solution to extend the display-cable the solution with centered mounting died.
To extend the display-cable is normaly a no go.
I made a pcb with two 20pin connectors on it. (same type as on the mainboard of the empeg) I found also the rare 20pin 1mm pitch ribbon cable and the crimp connectors.
I use also a ground-cable to connect the display with the main unit. I made the extension short as possible.
I think with all this arrangements is quite save to take away the display unit.
