#191732 - 04/12/2003 01:47 3.00 alpha upgrade error.
MiloDC
Couldn't find this in the FAQ.
Just got a Karma, want to re-rip all of my stuff to OGG format. Need OGG on my empeg so I don't have to keep MP3 duplicates of everything.
So, I downloaded emplode 2.10 and the 3.00 alpha firmware.
Two issues have arisen:
(1) Whenever I fire up my empeg, it rebuilds the database.
(2) When I fire up emplode and the program starts reading the player's database, I get "Download failed while checking database. Error 0xc0041002"
The player does actually seem to work fine beyond the rebuilding issue.
Help, please!
-- Milo D. Cooper http://www.miloonline.net/
#191733 - 04/12/2003 02:48 Re: 3.00 alpha upgrade error. [Re: MiloDC]
Do one sync with Emolode 2.0 to get a database built on the empeg, then go ahead and use Emplode 2.10.
#191734 - 04/12/2003 03:02 Re: 3.00 alpha upgrade error. [Re: drakino]
MiloDC
Heh, yeah, I tried that a minute or two before your post came up. Thanks for the response, just the same.
The database appeared to be back in action after this, but now I get "software aborted connection" errors while emplode attempts to upload my test OGG file to the player.
This blows. I think I'll just skip attempting to OGG my empeg until the next revision of emplode/firmware.
#191735 - 04/12/2003 03:12 Re: 3.00 alpha upgrade error. [Re: MiloDC]
Loc: Los Angeles, CA
try to use jemplode 47 w/ v3a3. i've had a lot more luck with that combination.
#191736 - 04/12/2003 10:13 Re: 3.00 alpha upgrade error. [Re: MiloDC]
foxtrot_xray
Loc: Atlanta, Georgia
Oddball thought, but try down-grading to 2.00, then RE-upgrading to 3.00a3..
I had the same issue with MP3 (Player giving memory errors). I just down-graded, then re-upgraded. Issue gone. ..
Dunno why..
Me.
#191737 - 04/12/2003 11:38 Re: 3.00 alpha upgrade error. [Re: image]
MiloDC
At the jEmplode page, I'm seeing versions up to 44 only. Where's 47?
#191738 - 04/12/2003 11:43 Re: 3.00 alpha upgrade error. [Re: MiloDC]
ricin
Loc: US: CA
That would be here. He intentionally left it separate because he wasn't sure of its stability.
ricin
MkII/080000565
MkIIa/010101253
ricin.io
#191739 - 04/12/2003 12:07 Re: 3.00 alpha upgrade error. [Re: MiloDC]
One thing not mentioned in this thread yet...
Version 3 is currently in a very very "Alpha" state. It's not stable and you're going to run into problems using it. Problems like those mentioned here in this thread.
If you're the kind of person who wants your player to "just work", then you should stick with version 2.0 for now.
#191740 - 04/12/2003 13:23 Re: 3.00 alpha upgrade error. [Re: tfabris]
MiloDC
I understand that, although I can't imagine why anyone, "just work" type or not, would want to use an alpha that can't reliably do something as crucial as file transfer.
I can (and have, in the past) run with glitches as long as they don't impair basic functionality.
As I wrote earlier, though, I'm content to wait for a future release, and have gone back to 2.0/non-OGG.
Thanks for the response.
P.S. Your mugshot reminds me of the kid who played Pyro in X-Men 2.
#191741 - 04/12/2003 13:27 Re: 3.00 alpha upgrade error. [Re: MiloDC]
robricc
File transfers work fine for me in 3a3 as long as I use USB to sync. Ethernet is extremely unstable.
I recently sync'd over 30GB worth of tunes with Emplode 2.00 and 3a3 over USB and it worked perfectly.
#191742 - 04/12/2003 13:29 Re: 3.00 alpha upgrade error. [Re: MiloDC]
brendanhoar
> transfer.
Get to know the people here, then you'll understand!
But seriously, I too avoid v3 alpha completely. Neato things in there, but I'm happy just dealing with all my hardware quirks at this point in time, no need to add additional software ones.
-brendan
#191743 - 04/12/2003 13:34 Re: 3.00 alpha upgrade error. [Re: MiloDC]
The same reason anyone would want to be an alpha or beta tester for any product. In this case, to help the empeg guys test it, to reports specific results, so that future releases can fix those bugs and be stable enough for the general public.
Also, you might want to be a tester because you want to see new features before everyone else does. In your case, that feature was Ogg playback.
Usually, the "just work" types aren't in the same category as people who would want to be beta testers.
#191744 - 04/12/2003 13:50 Re: 3.00 alpha upgrade error. [Re: robricc]
MiloDC
Well, there's the rub. I'm using Ethernet on an XP Pro box, so unless there's been an XP USB fix for the Mark II, I'm screwed (no way am I using serial port for file transfer).
Thanks, that was vital info.
#191745 - 04/12/2003 13:54 Re: 3.00 alpha upgrade error. [Re: MiloDC]
robricc
There is an XP USB fix in the 2.00final software. The updated driver is included with emplode 2.00 final. Load it up!
#191746 - 04/12/2003 14:07 Re: 3.00 alpha upgrade error. [Re: tfabris]
MiloDC
You left out a pretty significant part of my sentence, which was "I can't imagine why anyone, 'just work' type or not, would want to use an alpha that can't reliably do something as crucial as file transfer."
My point was that essential functionality shouldn't require outside testing. Moreover, if basic operations don't check out, then that prevents the testing of everything else in the new release.
That's just a perspective that I've developed after twelve years of releasing commercial software for multiple platforms.
Elsewhere in this thread, I was informed that Ethernet transfer is jacked with 3a3 (or perhaps emplode 2.10). I didn't see any mention of this in the release notes. I might try a serial transfer (I'm using XP Pro, so no USB for me) just to see if that is indeed my issue.
Thanks again for your prompt replies.
#191747 - 04/12/2003 14:07 Re: 3.00 alpha upgrade error. [Re: robricc]
Yes, make sure to read the release notes, because that driver requires installation by hand in order to work.
#191748 - 04/12/2003 14:12 Re: 3.00 alpha upgrade error. [Re: MiloDC]
robricc
Please read my post above this one and Tony's reply. USB does work for XP now.
Version 3a3 was not meant to be released on the internet to the masses. It was originally released only to alpha testers and those who attended the yearly meet in Europe.
#191749 - 04/12/2003 14:12 Re: 3.00 alpha upgrade error. [Re: MiloDC]
That's why they called it an alpha. Basically, we pestered the guys so much that they released it early, as it sorta-kinda worked. If you want to blame anyone, blame the posters here, not the software developers.
#191750 - 04/12/2003 14:19 Re: 3.00 alpha upgrade error. [Re: robricc]
MiloDC
A-ha, now it gets interesting...
Thanks, that's great news!
#191751 - 04/12/2003 14:28 Re: 3.00 alpha upgrade error. [Re: wfaulk]
MiloDC
Ah, well, that's different. tfabris made it sound as though it was proactively released for testing.
If it was never meant to be tested by the public at large, then all bets are off.
Okay, rant done. Thanks for all your help, everyone.
#191752 - 04/12/2003 15:04 Re: 3.00 alpha upgrade error. [Re: MiloDC]
jem7784
OK I had problems with V3a3 also at first. Then got those resolved. But I was finding this non-playability issue. It was what everyone seemed to be saying they were having with 128k files. Skipping or just stoppage. Well, all of my files are 128K. When I first did the upgrade there was no problem. But as I got more and more files on the player the problem showed up. It had gotten so frustrating taking the player out 3 or 4 times in 10 minutes to reboot it. I also was having issues with doing a down-down-down shuffle where it would completely reboot the player. This was VERY frustrating. I finally got the player inside my house and on a serial cable for another reason and saw the VM_try and free pages error or something. So I went into my config file and changed the reserve cache setting from 32 to 64 (32 had been recommended for people who kept getting a lockup on the "loading visuals" aspect of bootup). This completely fixed the problem. On the serial port I get something like using non standard cache of 26 with an adjustment of 64 so I'm guessing that I was correct in my guess and I've not had a single problem since doing this. Hope this helps some
Jemmi
#191753 - 05/12/2003 09:58 Re: 3.00 alpha upgrade error. [Re: ricin]
Where is the jemplode.jar file? I don't need nor want the silly bloated installers.
#191754 - 05/12/2003 10:58 Re: 3.00 alpha upgrade error. [Re: mlord]
foxtrot_xray
Me neither, personally. If you want, I can e-mail you JUST the 47 .jar..
Me.
#191755 - 06/12/2003 21:03 Re: 3.00 alpha upgrade error. [Re: robricc]
If you hassle me some more you might get an updated alpha when I get back to the UK next week. The emplode issues will probably still exist, but there has been a *lot* of development for Pearl over the last several months that the car player may benefit from.
Thanks to Peter it even builds now
#191756 - 07/12/2003 01:29 Re: 3.00 alpha upgrade error. [Re: rob]
[metal note]start poking rob to release next alpha in a week. ok, now in my treo600.[/mental note]
#191757 - 07/12/2003 10:19 Re: 3.00 alpha upgrade error. [Re: rob]
genixia
Please consider yourself duly hassled.
#191758 - 07/12/2003 22:42 Re: 3.00 alpha upgrade error. [Re: rob]
adavidw
Loc: Utah, USA
hassle, hassle
-Aaron
#191759 - 12/12/2003 15:31 Re: 3.00 alpha upgrade error. [Re: rob]
Mataglap
So, uh, Rob, how was your trip?
--Nathan
#191760 - 12/12/2003 16:32 Re: 3.00 alpha upgrade error. [Re: rob]
Narkotic
hassel hassel hassel !!
#191761 - 12/12/2003 16:38 Hassles [Re: Narkotic]
Hey, get in line you guys. He has to get the most recent builds of Jupiter and Mercury up before any recent builds of carplayer. I asked first.
If it's any consolation, those product builds don't need to be compiled, they simply need to be officially posted somewhere. So they're easier to put up than carplayer.
