#184658 - 15/10/2003 16:00 Max HDD Capacity on empeg
NT2OOO
Loc: ITALY
empeg can support 80gb HDD?
i want buy 2 80gb drives
thanks for reply
Rio Green 60Gb
#184659 - 15/10/2003 16:32 Re: Max HDD Capacity on empeg [Re: NT2OOO]
No problems anywhere, up to dual 120GB drives. So two 80GB drives are just peachy.
#184660 - 15/10/2003 16:38 Re: Max HDD Capacity on empeg [Re: mlord]
jbauer
Loc: San Francisco, CA
Do they MAKE 120 GB HDs in the right form factor for the empeg? I thought that 80 was the largest... at least the largest that IBM makes now... right?
- Jon
#184661 - 15/10/2003 16:43 Re: Max HDD Capacity on empeg [Re: jbauer]
No, they don't make 120GB laptop drives quite yet. It's the addressing limit for LBA which means you end up with a max of roughly 120GB. If you want to go bigger then you need a LBA48 capable kernel. Mark has a patch but I can't remember if he normally includes it in Hijack.
#184662 - 15/10/2003 16:44 Re: Max HDD Capacity on empeg [Re: jbauer]
Not yet. But they will someday.
The empeg kernel has (I think) been upgraded to handle drives larger than 128, but the disk builder images have not (at least not yet). So if they make drives larger than 120, we'll need to do some work to make sure all the support files can run with drives that big.
#184663 - 15/10/2003 17:25 Re: Max HDD Capacity on empeg [Re: tfabris]
And depending on your exact situation, you may run into some interesting quirks. Nothing major - I have been running dual 80s for a while now...
#184664 - 15/10/2003 20:55 Re: Max HDD Capacity on empeg [Re: tfabris]
Daria
The magic number isn't 137?
#184665 - 15/10/2003 21:02 Re: Max HDD Capacity on empeg [Re: Daria]
137,438,953,512 bytes, or 128GB. Your choice.
#184666 - 15/10/2003 21:22 Re: Max HDD Capacity on empeg [Re: mlord]
Daria
"Not 120".
