#180136 - 20/09/2003 22:07 My empeg is blowing fuses!?
Ruffles
In the last week or so, my Empeg (Rio Car) has blown the 3 amp fuse twice. It's never done that in the last 2 years that I've owned it. It still appears to be funcitoning fine however. About 3 months ago, I had Stans illuminated buttons and knob installed. Thats the only change I've made but why has it worked fine until now? Should I up the fuse to a 5 amp? Every time I have an fuse blow, I get paranoid trying to figure out the cause.
On a side note, 2 months ago, my Soundstream Reference 405 blew. It's served me well for 10 years. It was completely fused and isolated so I don't think it had anything to do with my empeg blowing fuses now. In fact, my empeg isn't connected to anything at the moment and it was just there to provide a clock when it blew the 3 amp tonight.
What do you guys think?
#180137 - 21/09/2003 07:18 Re: My empeg is blowing fuses!? [Re: Ruffles]
Greetings!
The illuminated button kit in no way should be blowing fuses. Check very carefully for a loose or grounded wire. You have a short somewhere...
#180138 - 21/09/2003 11:17 Re: My empeg is blowing fuses!? [Re: Ruffles]
Definitely check for wiring faults along the entire length between the battery and empeg.
Also check for this problem.
#180139 - 22/09/2003 09:57 Re: My empeg is blowing fuses!? [Re: Ruffles]
Ruffles
Thanks for the replies. I'll check the wiring.
#180140 - 22/09/2003 19:13 Re: My empeg is blowing fuses!? [Re: tfabris]
Uhhh.... no.
Check between the 3-amp fuse and the empeg. If the wiring fault is between the battery and the 3-amp fuse, it will not have any affect on that fuse.
