#176017 - 20/08/2003 10:41 Karma- runs Linux?
siberia37
Loc: Tacoma,WA
Maybe this was already answered somewhere but I couldn't find it. Does the Karma run Linux under the hood like the Empeg does? Or is Karma a more strict embedded system with no multi-purpose capabilities- like every other portable player.
#176018 - 20/08/2003 10:43 Re: Karma- runs Linux? [Re: siberia37]
Definitely the latter. You're unlikely to find a WMA DRM-capable player that has multi-purpose capabilities.
#176019 - 20/08/2003 10:44 Re: Karma- runs Linux? [Re: peter]
siberia37
Loc: Tacoma,WA
That's a shame- but expected considered the tigher pricing and design specs for a portable player.
#176020 - 20/08/2003 10:55 Re: Karma- runs Linux? [Re: peter]
DLF
Loc: Colorado, N.A.
{May be about to expose my ignorance, but}
so you can transfer to Karma and play the WM9 Series DRM stuff? Or just stuff with the v6/v7 flavor of DRM? Or the player firmware just doesn't care at all?
-- DLF
#176021 - 20/08/2003 11:48 Re: Karma- runs Linux? [Re: siberia37]
I think they just got fed up making Linux work in a realtime enviroment. The guys did a great job with the empeg, but it's not as if Linux was ever designed to run something like the empeg/Karma. It is a miracle they managed as good a jobs as they did with empeg/Linux.
With the Karma they are using ecos, which was designed from the start to be a realtime OS.
#176022 - 20/08/2003 12:07 Re: Karma- runs Linux? [Re: andy]
I am not certain it was the real time nature as the embedded systems environment. Don't forget, the empeg is not as power limited as a portable player would be.
#176023 - 20/08/2003 15:07 Re: Karma- runs Linux? [Re: andy]
Actually, I did ask Hugo and Rob about that when I was visiting, and they basically said they'd love to have used Linux, but due to the MS DRM constraints they couldn't open source it. So they had to find a different OS platform to use, and Hugo said he'd really have prefered Linux over that one (for various reasons).
So it's not a lack of Linux capability at all here, just DRM concerns.
Rob & Hugo are welcome to correct me if I've misunderstood any of that.
#176024 - 20/08/2003 15:14 Re: Karma- runs Linux? [Re: mlord]
Loc: Los Angeles, CA
i dont understand what the problem could be... the player from my understanding is from the same tree as v3 on the empeg, which if i recall correctly, is going to be module based, right? so shouldnt that mean that while the player/kernel/os is open source on the karma, the modules that have DRM could stay closed.
#176025 - 20/08/2003 15:19 Re: Karma- runs Linux? [Re: image]
Yeah, wouldn't that be nice if MS let you do that.
#176026 - 20/08/2003 15:25 Re: Karma- runs Linux? [Re: tfabris]
happens all the time, in principle at least. MS hasn't gone ahead and restricted wine/winex use of their dll libraries. No permission required, on the assumption that you really own the license for the windows product.
#176027 - 20/08/2003 17:41 Re: Karma- runs Linux? [Re: image]
I believe there's good concern that someone like me might hack a backdoor into a driver to extract PCM audio samples as DRM content is played back.
Not that audiograbber doesn't already do that on Windows!
#176028 - 21/08/2003 08:32 Re: Karma- runs Linux? [Re: mlord]
Well, that and the fact there's no MMU so speak of!
#176029 - 21/08/2003 08:46 Re: Karma- runs Linux? [Re: rob]
That's why ucLinux exists!
#176030 - 21/08/2003 11:28 Re: Karma- runs Linux? [Re: mlord]
julf
I was actually going to ask about ucLinux in Amersfoort. Decided to leave the question until later, over a few drinks. Unfortunately Alzheimers set in...
