#173207 - 01/08/2003 05:23 What Do I need for WI-FI (WLAN) on my empeg!
Zebulon
Hello everybody!
I have browsed to the whole Forum but find not the key answers to my questions.
First of all:
I am thinking about to build a WLAN. What do I need? Which are the best hardware for the Access Point.
Next what do I need to buy for the empeg? I am thinking about to use GPSapp and tcpdump. What is the best hardware. What are known problems/solutions?
I am located in Germany, so sorry for my bad english.
Hope I can get a clue on how to get the things done.
Hopefully awaiting your responses
Zebulon
#173208 - 01/08/2003 06:59 Re: What Do I need for WI-FI (WLAN) on my empeg! [Re: Zebulon]
This is discussed (even recently!) in at least a couple of other threads.
The answer is that you need a wireless ethernet bridge, which plugs into the ethernet port of the Empeg, and converts that ethernet into 802.11b. Zero configuration changes on the Empeg. D-Link apparently has a decent one that sometimes appears for insanely cheap prices. There are other brands as well.
#173209 - 01/08/2003 07:45 Re: What Do I need for WI-FI (WLAN) on my empeg! [Re: mlord]
Zebulon
Yes I have read the others but this D-Link is very huge. WLAN Cards vor Notebooks are much smaller. Why is it so big?
Or is the D-LInk the Access Point of my WLan?
Thanx a lot for your answers
Zebulon
#173210 - 01/08/2003 07:59 Re: What Do I need for WI-FI (WLAN) on my empeg! [Re: Zebulon]
Are you looking at the DWL-810? It's larger than one might like, but far from huge.
#173211 - 10/08/2003 03:09 Re: What Do I need for WI-FI (WLAN) on my empeg! [Re: wfaulk]
fz750
Loc: Bern, Switzerland
I think that what Zebulon is getting at is (correct me if I'm wrong though..) is that he already has a wi-fi network in his home/garage etc and is referring to the tiny network adapters that you see for laptops and PCs (e.g. a little USB dongle).
I guess (not being an expert) the answer is that these are all USB devices and I guess Empeg doesn't have a USB port hence the need to connect via the ethernet -correct?
Kevin
#173212 - 10/08/2003 03:50 Re: What Do I need for WI-FI (WLAN) on my empeg! [Re: fz750]
julf
Well, has the wrong type of USB port.
#173213 - 10/08/2003 10:06 Re: What Do I need for WI-FI (WLAN) on my empeg! [Re: fz750]
Right, as Julf said, it's got USB, just not USB master. FAQ entry here.
#173214 - 10/08/2003 10:51 Re: What Do I need for WI-FI (WLAN) on my empeg! [Re: Zebulon]
It's probably bigger because it includes it's own power regulators. The USB and PC-Card ones draw nice regulated electricity from the PC. But the external ethernet ones currently (pun intended) have to supply their own power. So, yet another AC-Adapter, and some voltage/current regulation inside the device itself.
#173215 - 11/08/2003 06:55 Re: What Do I need for WI-FI (WLAN) on my empeg! [Re: mlord]
Zebulon
Thanks everybody for the answers. And yes: fz750 you are right. But I don´t have a WLAN yet. :-)
#173216 - 15/08/2003 15:29 Re: What Do I need for WI-FI (WLAN) on my empeg! [Re: Zebulon]
jarob10
Loc: Stockport, UK
For streaming music, WLAN is ok, but I find 802.11b too flakey for synching. I was mever able to resolve problems with inconsistent pings.
Perhaps a range of 20ft (and passing through a floor) is asking too much for 802.11b
#173217 - 18/08/2003 23:07 Re: What Do I need for WI-FI (WLAN) on my empeg! [Re: jarob10]
paulj
Loc: Austin, TX
I sync across a wireless bridge from my upstairs office to my downstairs entertainment center all the time. I'm not sure if it does the find-via-broadcast correctly, but it works to specify an IP for Jemplote to look for specifically.
Heh, actaully there's a bunch of netwok hardware between my PC and my empeg:
[pc]---[hub]----[802.11bridge]--/\/\/\/--[802.11bridge]----[hub]---[empeg]
Ain't technology wonderful?
--pj
#173218 - 20/08/2003 10:36 Re: What Do I need for WI-FI (WLAN) on my empeg! [Re: paulj]
jarob10
Loc: Stockport, UK
What sort of ping performance do you get ? By way of comparison, after much tweaking, my setup is pretty consistent at about 26ms average round trip time, with a 12% packet loss
