#170292 - 13/07/2003 02:29 Mark1 dead?
vbezemer
PANIC!
I've finally gotten my Empeg car! I all worked great... but the first time I dismounted it from my car the player seamed to be locked...On the PC the Empeg booted, went to the radio source and then freezed.
The only cure was re-building the disk and add the tunes.
Back at the car it played great! But again, when i dismounted the player from the car and hung it on the PC it freezed (this time after the boot it seams to go to standby (right bottom light burns).
Does anyone have an idear what the problem can be? The FAQ and BB does not offer a solution.
PLEASE HELP!
Vince
#170293 - 13/07/2003 02:36 Re: Mark1 dead? [Re: vbezemer]
mtempsch
What does the boot log say?
#170294 - 13/07/2003 03:11 Re: Mark1 dead? [Re: mtempsch]
vbezemer
please see attachments
168701-bootlog.txt (289 downloads)
#170295 - 13/07/2003 04:54 Re: Mark1 dead? [Re: vbezemer]
Greetings!
Disclaimer: I have never worked on a Mark1 before.
Hmm... The boot log looks okay so far. Is it able to respond to any keyboard command through hyperterminal or from button input? What kind of symptoms are you seeing?
#170296 - 13/07/2003 06:16 Re: Mark1 dead? [Re: pgrzelak]
vbezemer
No ctrl+A and the buttons on the empeg does not work...
After booting, I do not get an prompt in hyperterminal
#170297 - 13/07/2003 06:41 Re: Mark1 dead? [Re: vbezemer]
When you rebuilt the unit, did you use the Mark1 developer version and Mark1 version of hijack? Version mismatch is usually the first thing to check.
#170298 - 13/07/2003 06:48 Re: Mark1 dead? [Re: pgrzelak]
vbezemer
Yes, I did.
It looks like I have to rebuild it again... After the first rebuild the player worked perfect (again). Untill I 'undocked' the player from the car... then It freezes. Now it just boots but goed to standby after i see the message 'Loading visuals' on the player.
It played very well in the car... perhaps there is something wrong with the wires?
Vince
#170299 - 13/07/2003 06:55 Re: Mark1 dead? [Re: vbezemer]
I am not certain what is wrong with it.
From your description, it played fine in the car, but you cannot get the player to respond when in AC mode. The player appears to boot fine in AC, but after the boot you cannot get to shell or get the buttons / remote to respond.
When you reflash or upgrade the kernel, this should in no way touch the music partitions. When you said you had to reload your music, was your music gone??? If so, that implies something is wrong with the disk or that there are some other problems.
Can you reload the Mark1 developer image, and let me kjnow if that helps? Do not load hijack yet, just the image. This should not change your music or playlists...
#170300 - 13/07/2003 07:35 Re: Mark1 dead? [Re: pgrzelak]
vbezemer
Well, it doesn't play in the car anymore. Just one time after coming of the PC to the car-dock. After that dead.
I have put back the consumer 2.0 image. Still the samen problem.
The fist time we have tried about everything. Nothing worked. When we rebuilded the hdd and then put the image back, it worked. It will probable work again, but just one time (after putting it in the car (thats where the rpoblems start (i guess))).
Vince
#170301 - 13/07/2003 07:37 Re: Mark1 dead? [Re: vbezemer]
Greetings!
Please load the developer image. The consumer image will not allow you to drop to a shell prompt to assist in debugging. Thanks.
#170302 - 13/07/2003 09:41 Re: Mark1 dead? [Re: pgrzelak]
vbezemer
OK, it's on there.
Still the same problem. The bootlog looks the same. I cant enter empeg (no prompt after Vcb: 0x4028d000
Vince
#170303 - 13/07/2003 10:33 Re: Mark1 dead? [Re: vbezemer]
You haven't tried altering the visuals files, have you?
Can you connect with Emplode? Also, try removing the config.ini file.
Also check to see if it's this problem.
#170304 - 13/07/2003 10:40 Re: Mark1 dead? [Re: vbezemer]
schofiel
What version of the software are you using?
Are you using any third party applications (HiJack, etc.)?
Have you recently opened the unit/added new disks, etc.?
For the unit to run though a boot sequence and then start winking the LED seems to me to say that the unit is sleeping. Have you tried a button press to wake it (this is normal behaviour)?
#170305 - 13/07/2003 10:42 Re: Mark1 dead? [Re: vbezemer]
schofiel
Why on Earth are you rebuilding the disks? Totally uneccessary.
This sounds to me like the player is hanging up due to lack of memory. Are using some application on the player?
#170306 - 13/07/2003 10:43 Re: Mark1 dead? [Re: vbezemer]
schofiel
OK, have you got the correct terminal settings (115k, 8N1, No Handshaking)?
#170307 - 13/07/2003 10:44 Re: Mark1 dead? [Re: schofiel]
Or is it just a stuck top button?
#170308 - 13/07/2003 11:01 Re: Mark1 dead? [Re: tfabris]
schofiel
Yep, good catch - you should try pressing each button to see that they release and "click" out again. If they don't, then you should undo the fascia screws on the button side by one quarter turn and check them again - repeat until they all click in, and click out again.
#170309 - 13/07/2003 11:05 Re: Mark1 dead? [Re: schofiel]
Hmm. I never knew the Mark1 had that problem. I always thought it was based on the fascia design of the Mark2 that cause the buttons to bind.
#170310 - 13/07/2003 11:10 Re: Mark1 dead? [Re: pgrzelak]
schofiel
No, it can happen on them both. Not so often reported these days - but Hugo posted about this very early on in the lifetime of the BBS.
It may also be this problem, which is also in the FAQ. However, he has not reported whether or not the drives are spinning, or the case is getting hot.
He also needs to check the harness fuse.
#170311 - 13/07/2003 13:41 Re: Mark1 dead? [Re: schofiel]
foxtrot_xray
Loc: Atlanta, Georgia
Also, make sure you're trying to DROP to a command prompt. One just won't show up by itself. CTRL-C will kill the player, and actually pull up the prompt. (Hey. I have a 'technical support' job. I look for the obvious..)
Me.
#170312 - 14/07/2003 00:52 Re: Mark1 dead? [Re: schofiel]
vbezemer
Schofiel,
I'm using the developer image 2. Hijack was on there the second time it happened. The first time it was totally clean.
AFter the second freeze (after the rebuild) I have checked inside to see if there where any components not in their sockets (but all was good). So the original disk is still in there.
The buttons or the remote does not trigger a response.
Vince
#170313 - 14/07/2003 00:53 Re: Mark1 dead? [Re: tfabris]
vbezemer
No, the buttons still click normal.
Vince
#170314 - 14/07/2003 00:55 Re: Mark1 dead? [Re: vbezemer]
It's not socketed components you have to worry about, read Robs post on regulators shorting themselves out on the chassis.
#170315 - 14/07/2003 00:59 Re: Mark1 dead? [Re: schofiel]
vbezemer
the disk spinns and the case doesn't get hot at all.
The red connector is not that tight on the case, but i can't (without using abnomal power) tightnen the crews.
Vince
#170316 - 14/07/2003 01:00 Re: Mark1 dead? [Re: schofiel]
vbezemer
The power issue you refered to: I stilll have the light flickering... And the first time the screen just freezed with the message: Source: Radio
Vince
#170317 - 14/07/2003 01:09 Re: Mark1 dead? [Re: tfabris]
vbezemer
No I haven't tried to alter the visual files.
I can not connect to the player through HT. (I do get all the boot results, but after Vcb: it freezes) The player is not recognized by emplode...
The disk runs so my guess would not be the ' serial srews' .
Vince
#170318 - 14/07/2003 01:15 Re: Mark1 dead? [Re: foxtrot_xray]
vbezemer
Hmmm.... I'm seriously starting to doubt my abilities
But after "Vcb:" the cursor comes up, i press ctrl+c.... nothing happens...
Vince
#170319 - 14/07/2003 01:17 Re: Mark1 dead? [Re: schofiel]
vbezemer
Yes, I use these settings... I can read the bootlog... but I can't imput...
Vince
#170320 - 14/07/2003 01:19 Re: Mark1 dead? [Re: vbezemer]
schofiel
Yeah, but have you installed a new disk or some such recently?
#170321 - 14/07/2003 01:21 Re: Mark1 dead? [Re: schofiel]
vbezemer
Well... all other thing did not work. So the first time we turned to this last resort... And it worked (the player worked great again).
But the second time this happened we have not rebuild the disk yet...
I have loaded the development image... I do not run any other programms... Or can't Mark1 handle v2?
Vince
Vince
