#165016 - 10/06/2003 11:18 Mozilla Problems
MadDog
I've just upgraded to the latest Ximian Desktop, and mozilla has given up the ghost for being able to read the empeg xml data. I'm running Mozilla 1.3.1.. Are there any other Linux geeks that could confirm/deny this problem?
#165017 - 11/06/2003 19:50 Re: Mozilla Problems [Re: MadDog]
If you're trying to use the charcoalgray9? XML web interface to the Hijack web server (just say yes if you didn't understand that), then I also have never had much luck with it. I use only Mozilla and Konqueror here, and the charcoalgray thingie hals always seemed IE-centric.. or at least it only seems to work with IE.
I'm currently using Mozilla-1.4beta, and still no joy.
#165018 - 12/06/2003 00:27 Re: Mozilla Problems [Re: mlord]
MadDog
Yes, I'm Using Charcolgrey's XML interface. Ug, is there a way to get it to just display html when I'm at work?
#165019 - 12/06/2003 06:58 Re: Mozilla Problems [Re: MadDog]
#165020 - 12/06/2003 08:08 Re: Mozilla Problems [Re: mlord]
cushman
Loc: Erie, CO
Mark, I've narrowed down the problem with Charcoalgray99's web interface with Mozilla. One thing that is a problem is the way Hijack sends the mime type for .xsl files - it should be text/xml just like you have noted on line 833 in kftpd.c. Mozilla will not recognize the xsl transformation unless the mime type sent by the server is text/xml. If you could change this line in Hijack, we'll be one step closer.
Secondly, there is a problem with either the linked .css file or the linked .js file in Charcoalgray99's xsl file that makes Mozilla hang when viewing the playlists. Here are the steps I took to get the playlist view working (somewhat) with Mozilla:
1. Commented out the two lines 17 and 18 in default.xsl:
<!--link rel="stylesheet" type="text/css" href="/drive0/opt/khttpd/charcoalgray99/css/default.css"/-->
<!--script language="javascript" src="/drive0/opt/khttpd/charcoalgray99/js/jscripts.js"/-->
2. FTP'd the new default.xsl file into the root directory
3. When going to a link, use the URL http://empeg/?fid=101&ext=.xml NOT http://empeg/?fid=101&ext=.xml&style=/drive0/opt/khttpd/charcoalgray99/xsl/default.xsl. The latter does not work in Mozilla.
4. Alternately, if you would like to have the default.xsl file in another location, you will need to set the khttpd_style entry in config.ini to the full path to the default.xsl. By default, the .xml documents are generated linking to /default.xsl unless this config.ini entry is set.
Here's a screenshot of the playlist running on Mozilla:
I will PM Charcoalgray99 to see if he wants to fix his stuff. If he doesn't, I will consider writing a new xsl stylesheet to work with Mozilla. I might anyway, just because I like to have a lightweight interface with no graphics.
Mark Cushman
#165021 - 12/06/2003 09:46 Re: Mozilla Problems [Re: cushman]
That's cool. The next Hijack release will include the one-liner you suggested.
#165022 - 12/06/2003 10:33 Hijack v339 [Re: cushman]
Done. Hijack v339 is now available.
#165023 - 12/06/2003 10:47 Re: Hijack v339 [Re: mlord]
cushman
Loc: Erie, CO
Thanks, Mark!
Mark Cushman
#165024 - 13/06/2003 18:03 Re: Mozilla Problems [Re: mlord]
cushman
Loc: Erie, CO
I pm'd charcoalgray99 and he said he would not have the time to work on the web interface to make it compatible with Mozilla. He did tell me to feel free to modify anything in the web interface to make it work with Mozilla, and I am assuming that means that anyone else is free to do so also. If someone decides to modify his current web interface to make it work with Moz, I would probably check with him first to arrange hosting/distribution of the new web interface.
I won't be doing this, though. I will probably be rewriting the web interface to learn more about XSL and Mozilla, and I prefer a simpler, more graphics (and javascript) free interface anyway. There will be one more release of Palantir before this, then I'll work on the web interface for Mozilla (and standards-compliant browsers).
Mark Cushman
#165025 - 14/06/2003 01:14 Re: Mozilla Problems [Re: cushman]
mcomb
Loc: San Carlos, CA
Hallelujah and thank you. If someone can come up with something that runs properly in Mozilla and its derivatives (Safari would be a nice bonus for me) I am sure there are at least a few of us who would appreciate it.
-Mike
#165026 - 26/11/2004 20:33 Re: Mozilla Problems [Re: cushman]
Anyone ever have a chance to look at this?
(Mmmm... 18 month old threads....)
#165027 - 26/11/2004 21:00 Re: Mozilla Problems [Re: wfaulk]
cushman
Loc: Erie, CO
Nope, no progress yet. It did get put into the front of my mind, though!
Mark Cushman
