#164991 - 10/06/2003 07:50 Problem with display
miko
Loc: Poland
Hello, I am looking for advise. I own Rio Player (Mk2), which worked fine for some months. Then It "died", ie. it was keeping resetting after about one second, with the display "dead".
I found out that my external power supply probably broke out.
I have replaced it, and now it works - except that only half of the
VFD works. Ie, the right half of the display is working correctly, and
the left half is not working.
Do you have any clue if it could be software problem (I could upgrade
the kernel) or a hardware problem? What could I check to find out
where the problem is? Any chances to get it repaired?
Thanks for your time,
Michal
Michal
#164992 - 10/06/2003 09:59 Re: Problem with display [Re: miko]
only half of the VFD works. Ie, the right half of the display is working correctly, and the left half is not working.
This is a defect that can only be corrected by support. Right now, support is a bit backlogged, but definitely contact them about this ASAP.
I do not know if this is a problem in the display board or in the VFD glass itself. Yours is the third time I've seen it reported. Cambridge folks: Is this a board problem or a VFD problem? Can the fix be outlined here so I can FAQ it?
#164993 - 10/06/2003 15:45 Re: Problem with display [Re: tfabris]
It's a VFD problem; one of the column driver chips embedded in the glass has died. Rare, but can happen. Only solution is to replace the VFD.
#164994 - 10/06/2003 16:25 Re: Problem with display [Re: altman]
Thanks, Hugo. I'll FAQ that now.
#164995 - 11/06/2003 14:55 Re: Problem with display [Re: altman]
miko
Loc: Poland
Thanks for the answer. Is it the only reason? Could it be also a software problem? It looks like I am having also software problem (look at a topic "Problem with uploading a kernel"), and just wonder if it could be related somehow.
Michal
#164996 - 11/06/2003 15:00 Re: Problem with display [Re: miko]
Yes.
No.
No, it is not related.
#164997 - 11/06/2003 15:39 Re: Problem with display [Re: tfabris]
miko
Loc: Poland
Well... It does not make me very happy, but it is good to know for sure... Thanks for the answers!
Michal
