#162753 - 26/05/2003 13:44
Player takes longer to boot?
Just replaced the stock 10gb drive with a 60gb - (have one drive in player). I've noticed that it takes 5 secs to boot but it used to be almost instant. This is before I've put any music on it as I'm starting from scratch. Is this normal?
Edit: More like 14 seconds, not 5!
Edited by PhilipOHare (26/05/2003 16:34)
#162754 - 26/05/2003 14:12
Re: Player takes longer to boot?
[Re: CrackersMcCheese]
Greetings!
I think it is normal. I would guessing that the larger partition, even empty, requires a little longer to mount. Either that, or the drive spin up is a little longer. I notice that my player takes a few seconds when starting, but it does not seem to increase with the amount of music on it.
#162755 - 26/05/2003 16:00
[Re: pgrzelak]
Mmmh... more like 14 seconds from switch on to 'loading visuals'. Does this look normal?
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #12 Tue Apr 1 18:51:41 BST 2003
empeg-car player (hardware revision 9, serial number 30102506)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004800).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IC25T060ATCS05-0, ATA DISK drive
hda: IC25T060ATCS05-0, 57231MB w/1768kB Cache, CHS=7296/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:c
a
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init player.cpp : 385:empeg-car 2.00 20
03/04/01.
Vcb: 0x4086d000
#162756 - 26/05/2003 16:16
15 seconds until Loading Visuals appears? Hm... That does seem a bit long. I did not notice anything unual in your boot log, though, except that you do not run hijack.
#162757 - 26/05/2003 16:17
[Re: pgrzelak]
No I haven't got around to that yet! (Sorry Mark). I did notice it seems to probe the primary interface for 5 of 6 times - its here that the boot logo stays on and makes me wonder if its going to start.
#162758 - 26/05/2003 16:20
The multiple probe is not unusual on the player. Basically, it is probing to see if two hard drives will answer. It will then time out an accept the responses from whoever replied.
You might want to run a quick comparison with the hijack kernel - it may have some optimizations in it.
#162759 - 26/05/2003 16:27
[Re: pgrzelak]
I'll add Hijack tomorrow, its getting late here and I'll probably lose patience with it if I do it now!
I followed the upgrade guide to the letter and it was a straight swap for the 10gb one. I then ran the builder file and let it do its thing until I got fed up with it stress testing, so I quit that and then ran the developer upgrade. All seems well apart from the boot time. Maybe its totally normal, i don't know.
Thanks for your help, no doubt Tony will chip in at some point!
#162760 - 26/05/2003 16:31
Greetings!
All of your boot logs look normal. Is the machine completely blank? That might be part of the problem. You may want to sync at least one track to it, see if that helps.
#162761 - 26/05/2003 16:33
[Re: pgrzelak]
Yes, totally empty. I'll put on Hijack and some tracks in the morning and see whats what.
#162762 - 26/05/2003 17:30
Once you do install Hijack, go into the Hijack menu and select the "Hard Disk Detection" entry, and set the value to "one drive only" for faster boots!
#162763 - 27/05/2003 03:28
I'll do that when I get back from work. Didn't have time this morning.
In the meantime, if anyone else wants to pitch in...
#162764 - 27/05/2003 11:02
Loc: Los Angeles, CA
i had this problem before. its taking a long time for hda to acknowledge. usually only has 1-2 lines max before it goes on. could be the hdd itself, dry joint, or ide cable. for me, it ended up to be a dry joint.
#162765 - 27/05/2003 11:17
Better... now about 8 seconds. Would that be about correct for one 60gb drive?
e000 v1.04
Copying kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v335 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Tue May 13 15:01:19 EDT 2003
Memory: 14996k/16M available (996k code, 20k reserved, 368k data, 4k init)
IrCOMM protocol (Dag Brattli)
Tuner: loopback=0, ID=-1
empeg state support initialised 0089/88c1 (save to d0004b00).
a
Partition check:
Freeing unused kernel memory: 4k initHijack: intercepting config.ini
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
#162766 - 27/05/2003 11:21
Better... now about 8 seconds. Would that be about correct for one 60gb drive? 8 seconds is optimum/expected for any size drive.
#162767 - 27/05/2003 13:11
On a side note I just got a shock from the player when unplugging the AC adapter (was off at mains). Serial and ethernet was plugged in however.
I also noticed electrical noises when plugging in the serial last night - is this cause for concern?
#162768 - 27/05/2003 13:49
Yeah, try a different power supply and see if that solves the problem.
#162769 - 27/05/2003 13:56
Power supply was not plugged into mains though. So it can;t be that.
#162770 - 27/05/2003 20:44
Loc: NH USA
"Power supply was not plugged into mains though. So it can;t be that. "
If the power supply has left over charge in the AC to DC conversion circuitry, it can.
-Zeke
WWFSMD?
