#162153 - 19/05/2003 13:16 tuner problem
NT2OOO
Loc: ITALY
today i have installed V2 +h335
auto seek in FM don't work, only manual tune, with front panel button and Sony RM X4S too
any info?
Rio Green 60Gb
#162154 - 19/05/2003 13:34 Re: tuner problem [Re: NT2OOO]
I've sent Alberto the IR_Translate commands for the front panel:
[ir_translate]
Left.LT=b9460c.L
Right.LT=b9460d.L
What are the corresponding commands for the Sony stalk controller?
#162155 - 19/05/2003 13:46 Re: tuner problem [Re: tfabris]
NT2OOO
Loc: ITALY
can i do without you?
THANKS
Rio Green 60Gb
#162156 - 19/05/2003 13:48 Re: tuner problem [Re: tfabris]
Probably the same thing, except with "Kprev" instead of "Left" and "Knext" instead of "Right".
Oh, and here's a new improved version for the front panel:
[ir_translate]
Left.LT=b9460c.LN,Left.LU
Right.LT=b9460d.LN,Right.LU
#162157 - 19/05/2003 13:59 Re: tuner problem [Re: mlord]
NT2OOO
Loc: ITALY
thank MlordS
Kprev and knext works very well!!!
Rio Green 60Gb
#162158 - 19/05/2003 14:01 Re: tuner problem [Re: NT2OOO]
NT2OOO
Loc: ITALY
can i increase speed to volume?
Rio Green 60Gb
#162159 - 19/05/2003 15:54 Re: tuner problem [Re: NT2OOO]
EtN
Hi!
I'm another Empeg Owner (MK2a Blue 30G) from Italy.
Since I can't find a tuner for the MK2 at a reasonable price (PCATS' one is out of my budget, plus I can't solder), did someone out there managed to find an external RDS tuner (not another HU, just a tuner) for use with the Empeg via Aux port?
Etn
EtN - Stony Stratford, Milton Keynes, United Kingdom
30 Gb MKIIa # 040104160
#162160 - 09/06/2003 14:53 Re: tuner problem [Re: tfabris]
tarkie
Did anyone ever get this working, as this only moves 0.3 no matter how long you hold down left or right.
I've tried both Tony's and Mark's versions. Same result.
M2a/Smoke/60gb/Tuner!! Thanks Joe M2a/Blue10gb Thanks Ian!
#162161 - 11/06/2003 12:21 Re: tuner problem [Re: EtN]
az_max2
EtN:
I ended up with a second head unit in the glove compartment for now. It's pretty much fixed on one station because it's a hassle to open the glovebox door to change the station. I tried a portable radio (several actually), and the reception Just Sucked. I've looked for remote mounted tuners and only found one.
SecretAudio make a tuner/cd controller that can mount anywhere. the control part is like 1.5x4.5 inches. You could mount this on a stalk, or replace your ashtray with it. But it's more expensive than PCA's tuner at $199usd. (cd changer extra).
I already have a Sony cd changer I want to mount in the glove box, so I'm patiently waiting for PCA's tuner kit.
