#161301 - 13/05/2003 18:55
Problem with EXEC command
Loc: Atlanta, GA
I have the 2.0 final (developer) and Hijack 335 and having this issue:
[hijack]
;@EXEC /usr/local/bin/emphatic
;@EXEC /usr/local/bin/empacman
;@EXEC /usr/local/bin/emptris
This is in my config.ini yet only emphatic is on the Hijack menu. I verified these programs are located in /usr/local/bin... any ideas?
One of the last MK2's from SonicBlue...
Blue/60gig
S/N: 030103111
#161302 - 13/05/2003 19:01
Re: Problem with EXEC command
[Re: jbradshw]
As always, look at the serial logs..
#161303 - 13/05/2003 19:21
Loc: Atlanta, GA
How would I do that?
Blue/60gig
S/N: 030103111
#161304 - 13/05/2003 19:25
[Re: jbradshw]
Loc: Erie, CO
#161305 - 13/05/2003 19:27
[Re: jbradshw]
I verified these programs are located in /usr/local/bin... Did you also verify that they are tagged as executable?
How would I do that? Like this.
#161306 - 13/05/2003 19:28
Ooo, Cushman-san gets the pebble!
#161307 - 13/05/2003 19:36
Loc: Atlanta, GA
Actually I think I know what's going on.. I can't synchronize anything right now for some reason. I was just uploading a bunch of music which worked awhile ago. Then I tried entering those lines and was getting stuck on that. I reopened the player database and the config.ini and those lines I just mentioned aren't even there. Even if I try re-entering them and Synchronizing, they don't stay. I'll check the serial log here in a min and get back to you guys.
Blue/60gig
S/N: 030103111
#161308 - 13/05/2003 19:39
Loc: Erie, CO
*laughs*
Cushman-san 1
Fabris-san 1,223,345
#161309 - 13/05/2003 19:39
[Re: jbradshw]
Even if I try re-entering them and Synchronizing, they don't stay. This is a classic symptom of the player being unable to unmount/remount the drives as read-only or read-write because there's a live program running from /drive0 at synchronize time. That folder you put those programs in... is it on /drive0?
/me goes to beef up the FAQ entry about FSCK...
#161310 - 13/05/2003 19:52
Loc: Atlanta, GA
OK I saw the FAQ entry and I'm trying those steps but I'm running into this problem.
I hit 'q' to get to the shell prompt. RO worked, but when I do 'unmount /dev/hda4' it says:
bash: unmount: command not found
Am I doing this right?
Blue/60gig
S/N: 030103111
#161311 - 13/05/2003 19:54
[Re: jbradshw]
bash: unmount: command not found Check your spelling very very carefully, one letter at a time. This goes for all Unix commands.
Remember that Unix commands aren't always spelled the same as the english words that they represent. Look CLOSELY at those instructions in the FAQ...
#161312 - 13/05/2003 19:55
Loc: Atlanta, GA
Geez.. I'm an idiot... haha
Blue/60gig
S/N: 030103111
#161313 - 13/05/2003 19:59
Loc: Erie, CO
I work in the Knowledge Management arena in my company and we have a phrase that we use often when we are developing a new knowledge base or knowledge tool. I think that this applies to a lot of your posts, Tony:
Leading them to the door of their own understanding
#161314 - 13/05/2003 20:21
[Re: cushman]
Loc: Atlanta, GA
Well I followed that list of commands and after the SYNC command I unplugged the power cord and cycled power but I still can't synchronize. Here's a paste of the serial log after I first started up. For some reason, in Hyperterminal when i scrolls up beyond the screen the text gets garbled somewhat so hopefully you can see something in this:
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v335 (root@ibbm) (gcc version 2.95r pump...VFS: Mounted
Linux NET4.0 for Linux 2.2donly.
Based
.3 20010315 (release)) #2 Tue May 13 15:01:19 EDT 2003_root: old root has d_count=1
NET
Processor: Intel StrongARM-1100 revision 11ay
IP Protocols: ICMP, UDP
NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp.84 bhash 16384)
Ir
empeg-car player (hardware revision 9, serial number 30103111)usic partition
IrCOMM protocol (Dag Brattli) /d
Command line: mem=16mt go
Starting kswapd
IrCOMM protocol (Dag Brattli)D12 id 1012
Starting kswapd v 1.5
empeg state support
player.
empeg RDS driver initialis
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UARTiver initialised (first boot)empeg car - 2.1434
ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UARTialized: 16 RAM disks of 4096K sizeisk.cpp
ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UARTg single channel IDE
Pro
Signature is 206f6972 'rio 'fsck 1.19, 13-Jul-2000 f
hda
Found custom animation at offset 0x9a38c
hdb: FU
Tuner: loopback=0, ID=-1 drivedirectory while de
empeg display initialised.t 0x000-0x007,0x038 on irq
empeg dsp audio initialised
hda: FUJITSU MHL23
empeg dsp mixer initialised, CHS=58140/16/63oved menu
empeg dsp initialised
empeg audio-in initialised, CS4231A revision a08kB Cache, CH
Remounting first music
Probing primary interface...
You don't exist. Go away.
R
hda: FUJITSU MHL2300AT, ATA DISK driveo ram disk... done.
hdb: FUJITSU MHL2300AT, ATA DISK drive
empeg-pump v0.03 (19980601) -a:
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63 root (ext2 fil
Mounting first
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0c:2 but got error 19: Force fsck on reboot.
Mounting
7c
Partition check:on -n:
hda: hda1 < hda5 hda6 > hda2 hda3 hda4 partition read-only
hdb: hdb1 < hdb5 hdb6 > hdb2 hdb3 hdb4d music partition read-onlyc: canc
RAMDISK: ext2 filesystem found at block 0now to go into development mode. You Have
Starting player
Mounting proc
Press 'q' now to go into development mode. You Have Zero Seconds To Comply.ūStar
ting player
hijack_exec("/usr/local/bin/emphatic"), rc=0 (okay)
khttpd: listening on port 80
kftpd: listening on port 21
opening display...
Using non-standard cache size 86 (adjustment 48)
starting notify thread...
notify thread started (tid=1026)...
lyrics thread started (tid=2051)...
emphatic v1.10 (built Feb 18 2003 20:15:18) running as pid 11
Vcb: 0x4056d000
And then this is when I synchronize:
Adding Swap: 16596k swap-space (priority -2)
disk.cpp : 876:Couldn't cleanly unmount drive 0 (c0041010)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
hda4 is mounted.
hijack: removed menu entry: "emphatic"
Restored terminal settings
Restart code received
Starting player
opening display...
emphatic v1.10 (built Feb 18 2003 20:15:18) running as pid 55
Hope this helps.
Blue/60gig
S/N: 030103111
#161315 - 13/05/2003 20:23
[Re: jbradshw]
Eeew. That doesn't look healthy. Have you been having other drive trouble?
#161317 - 13/05/2003 20:34
Loc: Atlanta, GA
Hold up.. I did a capture to file and here it is correct:
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v335 (root@ibbm) (gcc version 2.95.3 20010315 (release)) #2 Tue May 13 15:01:19 EDT 2003
Memory: 14996k/16M available (996k code, 20k reserved, 368k data, 4k init)
IP Protocols: ICMP, UDP, TCP
empeg state support initialised 0089/88c1 (save to d0004080).
empeg RDS driver initialised
empeg single channel IDE
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0c:27
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
Mounting proc
Starting player
opening display...
Vcb: 0x4056d000
And then when I synchronize:
Adding Swap: 16596k swap-space (priority -1)
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
Starting player
opening display...
emphatic v1.10 (built Feb 18 2003 20:15:18) running as pid 33
Vcb: 0x4056d000
Blue/60gig
S/N: 030103111
#161318 - 13/05/2003 20:36
[Re: jbradshw]
Loc: Atlanta, GA
No other drive trouble that I could tell. Though I've always had issues from day 1 with issues like synching a lot of files at once.. I would always have to synch some files again for them to remain on the EMPEG.
Blue/60gig
S/N: 030103111
#161319 - 13/05/2003 20:44
[Re: jbradshw]
Kill emphatic before you sync.
It's a good idea to prefix your EXEC lines with ";@DC" so that they only run in the car;
#161320 - 13/05/2003 20:47
[Re: genixia]
Loc: Atlanta, GA
Yep that fixed it. Thanks!
Blue/60gig
S/N: 030103111
