#153689 - 07/04/2003 12:04 Emptool arithmetic problem
tms13
Loc: Lochcarron and Edinburgh
Emptool can't do its sums properly:
1260 Drive 0 size: 18976M, free: 1489M, used: 17487M (92%)
1260 Drive 1 size: 28497M, free: 16042M, used: 12455M (43%)
1260 = Total size: 33241M, free: 16414M, used: 16827M (50%)
Last time I checked, 18976+28497=47473...and the total used is really wierd!
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#153690 - 07/04/2003 12:56 Re: Emptool arithmetic problem [Re: tms13]
Yang
Loc: Raleigh, NC
Free and Used doesn't add up either.. Should be 17531M free and 29942M used.
#153691 - 07/04/2003 13:06 Re: Emptool arithmetic problem [Re: tms13]
really wierd
Due to the insane way this was coded (in emptool/playerdb.cpp:LogFreeSpace(), go and look) it gets the totals wrong if the music partitions were formatted with different block sizes. The sizes for each individual drive are correct.
#153692 - 07/04/2003 13:10 Re: Emptool arithmetic problem [Re: peter]
Would this only happen if the drives hadn't been prepared with the builder images (i.e., they were partitioned and formatted by hand)?
#153693 - 07/04/2003 13:15 Re: Emptool arithmetic problem [Re: tfabris]
Good question. It's quite possible that we've upgraded the builder image over the years, or even that we use mke2fs in a mode whereby it chooses the block size based on the partition size.
The Right Thing, which I've no idea whether we do, is to use big block sizes (4K) for music partitions, as almost 50% of files are much, much bigger than that and it saves space on the block-in-use bitmaps, indirect blocks, and so on.
#153694 - 07/04/2003 13:20 Re: Emptool arithmetic problem [Re: peter]
Bingo.
