#151215 - 28/03/2003 12:12 Playlists disappeared
dinkum
Loc: ca, usa
Can anyone help me with this problem? While I was downloading music onto my player, my computer (XP via Ethernet) froze in the middle of it. I rebooted my computer and opened Jemplode again but it locked up. It locks up at various places now. I cannot sync the player anymore. The player still works in car and home but when I go to playlist menu it says “none.” I can only use the remote to access music. Did some reading in FAQ which points to a problem with the second hard drive (which I have) or IDE cable… The cable seems fine. If there is a problem with the second hard drive, could it still be playing music like it does? What am I to do next?
#151216 - 28/03/2003 12:16 Re: Playlists disappeared [Re: dinkum]
Also look at this FAQ entry, and since you said it was in XP, this one, too, although that latter one has nothing to do with the playlist problem.
#151217 - 28/03/2003 12:23 Re: Playlists disappeared [Re: tfabris]
dinkum
Loc: ca, usa
Thanks, I'll try that when I can find time.
#151218 - 28/03/2003 12:26 Re: Playlists disappeared [Re: dinkum]
I still think that the original first FAQ entry you saw (the one that says your second drive may have gone south) is still the most likely cause. Remember that a cable isn't the only reason a drive can stop working. Go through every single possible diagnostic listed in the section about hard disk trouble.
#151219 - 28/03/2003 13:52 Re: Playlists disappeared [Re: tfabris]
dinkum
Loc: ca, usa
Ok Tony, I did "rm .../database." Open Jemplode but it locks up at "updating interface" everytime... I go thru the list of hard disk trouble but everything appears grossly intact as far as I can tell. Maybe one of the drives had it like you said but can it still play? Can I save any data at all before i go thru formatting a drive?
#151220 - 28/03/2003 14:22 Re: Playlists disappeared [Re: dinkum]
You should not be thinking about formatting a drive. The drive is either working or it isn't. Formatting a drive that doesn't work isn't going to result in anything positive.
Have you determined from looking at the serial output whether or not there are two drives being recognized at bootup? What does the relevant section of the bootup text look like ("probing primary interface")? Have you tried to navigate to /drive0 and /drive1 from the shell prompt?
#151221 - 28/03/2003 17:04 Re: Playlists disappeared [Re: tfabris]
dinkum
Loc: ca, usa
This is what I got from booting thru hyperterminal but I have no idea what it means:
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v320 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Wed Feb 19 21:53:19 EST 2003
empeg-car player (hardware revision 9, serial number 30103010)
Command line: mem=16m
Memory: 14996k/16M available (996k code, 20k reserved, 368k data, 4k init)
Page cache hash table entries: 4096 (order
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
IrCOMM protocol (Dag Brattli)
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9c37c
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004480).
empeg RDS driver initialised
empeg power-pic driver initialised (first bo
empeg single channel IDE
Probing primary interface...
hda: TOSHIBA MK4018GAP, ATA DISK drive
hdb: TOSHIBA MK4018GAP, ATA DISK drive
hda: TOSHIBA MK4018GAP, 38154MB w/0kB Cache, CHS=4864/255/63
hdb: TOSHIBA MK4018GAP, 38154MB w/0kB Cache, CHS=4864/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:61
2
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
! mp3_decoder.cpp :1049:Failed to find valid sync after seeking to offset 3522
273, error=0xc0044000
#151222 - 28/03/2003 17:06 Re: Playlists disappeared [Re: tfabris]
dinkum
Loc: ca, usa
I wouldn't know how to do that.
Email BBS Admin | Privacy statement
#151223 - 28/03/2003 19:10 Re: Playlists disappeared [Re: dinkum]
Since you have Hijack installed, just connect to the built-in webserver and browse around.
Eg. http://your_players_ip_address/drive0/
#151224 - 28/03/2003 20:30 Re: Playlists disappeared [Re: mlord]
dinkum
Loc: ca, usa
I've used http://your_players_ip_address/drive0/ before and had streaming audio but not this time because playlists are empty in both drive0 and drive1. Whatelse do I look for when browsing around? Thanks for any further instructions.
BTW, this is what i got:
Index of /drive0
drwxr-xr-x 6 0 0 1024 Jul 17 2002 ./
drwxr-xr-x 6 0 0 1024 Jul 17 2002 ../
drwxr-xr-x 2 0 0 12288 Jan 1 1970 lost+found/
drwxr-xr-x 2 0 0 220160 Mar 11 01:12 fids/
drwxr-xr-x 2 0 0 1024 Mar 28 20:30 var/
drwxr-xr-x 3 0 0 1024 Jul 17 2002 opt/
[Click here for playlists]
Hijack v320 by Mark Lord
Index of /drive1
drwxr-xr-x 5 0 0 1024 Jan 1 1970 ./
drwxr-xr-x 5 0 0 1024 Jan 1 1970 ../
drwxr-xr-x 2 0 0 185344 Mar 11 01:13 fids/
drwxr-xr-x 2 0 0 1024 Jan 1 1970 var/
Edited by dinkum (28/03/2003 20:31)
#151225 - 28/03/2003 20:34 Re: Playlists disappeared [Re: dinkum]
Hm. You've got both drives there. Dunno what it could be.
Oh... checked your config. ini file for that beta-11 favorite-visuals bug? That sometimes makes weird stuff happen...
#151226 - 29/03/2003 01:34 Re: Playlists disappeared [Re: tfabris]
dinkum
Loc: ca, usa
This problem is probably atypical and certainly beyond me. I don't have the technical know-how to explore every possibility. Is there a simple way to start over? (scratching head)
#151227 - 29/03/2003 07:58 Re: Playlists disappeared [Re: dinkum]
Okay, now continue to use the http method, and have a peek at:
http://your_player/proc/mounts
and
http://your_player/drive0/fids
and
http://your_player/drive1/fids
#151228 - 29/03/2003 10:49 Re: Playlists disappeared [Re: dinkum]
I know, that's why we're here to help. Look at the things Mark was suggesting, and also check for this problem that I mentioned (but did not link, sorry) in my last post.
#151229 - 29/03/2003 14:49 Re: Playlists disappeared [Re: mlord]
dinkum
Loc: ca, usa
First of all, you guys are awesome. Thanks a lot for helping out here... Sorry, I was out working all AM. Here is what I got:
/dev/root / ext2 ro 0 0
none /proc proc rw 0 0
/dev/hda4 /drive0 ext2 ro 0 0
/dev/hdc4 /drive1 ext2 ro 0 0
#151230 - 29/03/2003 14:53 Re: Playlists disappeared [Re: mlord]
dinkum
Loc: ca, usa
Index of /drive0/fids
drwxr-xr-x 2 0 0 220160 Mar 11 01:12 ./
-rw-r--r-- 1 0 0 9786386 Dec 28 2002 1a0
-rw-r--r-- 1 0 0 423 Dec 28 2002 1a1
-rw-r--r-- 1 0 0 8 Jan 8 19:50 440
-rw-r--r-- 1 0 0 77 Jan 8 19:50 441
-rw-r--r-- 1 0 0 188 Jan 8 10:40 460
-rw-r--r-- 1 0 0 81 Jan 8 10:40 461
-rw-r--r-- 1 0 0 152 Mar 1 02:04 190
-rw-r--r-- 1 0 0 82 Mar 1 02:04 191
-rw-r--r-- 1 0 0 11351884 Dec 28 2002 1b0
-rw-r--r-- 1 0 0 362 Dec 28 2002 1b1
-rw-r--r-- 1 0 0 11345250 Dec 28 2002 1c0
-rw-r--r-- 1 0 0 5656132 Nov 15 2002 260
-rw-r--r-- 1 0 0 395 Nov 15 2002 261
-rw-r--r-- 1 0 0 11041146 Nov 15 2002 270
-rw-r--r-- 1 0 0 418 Nov 15 2002 291
-rw-r--r-- 1 0 0 7245032 Nov 15 2002 2a0
-rw-r--r-- 1 0 0 408 Nov 15 2002 2b1
-rw-r--r-- 1 0 0 6468718 Nov 15 2002 2c0
-rw-r--r-- 1 0 0 429 Nov 15 2002 2d1
-rw-r--r-- 1 0 0 3410525 Nov 15 2002 2e0
-rw-r--r-- 1 0 0 409 Nov 15 2002 2e1
-rw-r--r-- 1 0 0 17010939 Nov 15 2002 2f0
-rw-r--r-- 1 0 0 398 Nov 15 2002 311
-rw-r--r-- 1 0 0 6598449 Nov 15 2002 320
-rw-r--r-- 1 0 0 359 Nov 15 2002 331
-rw-r--r-- 1 0 0 9998336 Nov 15 2002 340
-rw-r--r-- 1 0 0 329 Nov 15 2002 351
-rw-r--r-- 1 0 0 14821378 Nov 15 2002 360
-rw-r--r-- 1 0 0 414 Dec 28 2002 1c1
-rw-r--r-- 1 0 0 9492375 Nov 15 2002 390
-rw-r--r-- 1 0 0 425 Nov 15 2002 391
-rw-r--r-- 1 0 0 5621760 Nov 15 2002 3a0
-rw-r--r-- 1 0 0 352 Nov 15 2002 3b1
-rw-r--r-- 1 0 0 12174025 Nov 15 2002 3c0
-rw-r--r-- 1 0 0 485 Nov 15 2002 3d1
-rw-r--r-- 1 0 0 7210487 Nov 15 2002 3e0
-rw-r--r-- 1 0 0 378 Dec 27 2002 401
-rw-r--r-- 1 0 0 100 Mar 12 01:27 1d0
-rw-r--r-- 1 0 0 439 Nov 15 2002 431
-rw-r--r-- 1 0 0 82 Mar 12 01:27 1d1
-rw-r--r-- 1 0 0 5317823 Dec 28 2002 1e0
-rw-r--r-- 1 0 0 436 Dec 28 2002 1e1
-rw-r--r-- 1 0 0 4248631 Dec 28 2002 380
-rw-r--r-- 1 0 0 443 Dec 28 2002 381
-rw-r--r-- 1 0 0 392 Nov 15 2002 211
-rw-r--r-- 1 0 0 13369344 Nov 15 2002 220
-rw-r--r-- 1 0 0 421 Nov 15 2002 471
-rw-r--r-- 1 0 0 6538859 Dec 28 2002 410
-rw-r--r-- 1 0 0 395 Nov 15 2002 491
-rw-r--r-- 1 0 0 412 Dec 28 2002 451
-rw-r--r-- 1 0 0 393 Nov 15 2002 4b1
-rw-r--r-- 1 0 0 7088298 Nov 15 2002 4c0
-rw-r--r-- 1 0 0 361 Nov 15 2002 4d1
-rw-r--r-- 1 0 0 9887120 Nov 15 2002 4e0
-rw-r--r-- 1 0 0 373 Nov 15 2002 4f1
-rw-r--r-- 1 0 0 9659631 Dec 28 2002 4a0
-rw-r--r-- 1 0 0 360 Nov 15 2002 511
-rw-r--r-- 1 0 0 7594237 Nov 15 2002 520
-rw-r--r-- 1 0 0 376 Nov 15 2002 521
-rw-r--r-- 1 0 0 7448576 Nov 15 2002 530
-rw-r--r-- 1 0 0 350 Nov 15 2002 551
-rw-r--r-- 1 0 0 376 Dec 28 2002 561
-rw-r--r-- 1 0 0 8392331 Dec 27 2002 8e0
-rw-r--r-- 1 0 0 339 Dec 28 2002 581
-rw-r--r-- 1 0 0 5617724 Dec 28 2002 590
-rw-r--r-- 1 0 0 6135426 Dec 26 2002 5a0
-rw-r--r-- 1 0 0 336 Dec 26 2002 5a1
-rw-r--r-- 1 0 0 10398238 Dec 26 2002 5b0
-rw-r--r-- 1 0 0 375 Dec 27 2002 5c1
-rw-r--r-- 1 0 0 331 Dec 28 2002 591
-rw-r--r-- 1 0 0 394 Dec 27 2002 5f1
-rw-r--r-- 1 0 0 3936049 Dec 26 2002 600
-rw-r--r-- 1 0 0 415 Dec 26 2002 601
-rw-r--r-- 1 0 0 13099886 Dec 28 2002 5e0
-rw-r--r-- 1 0 0 9817112 Dec 28 2002 250
-rw-r--r-- 1 0 0 3959640 Dec 26 2002 630
-rw-r--r-- 1 0 0 432 Dec 26 2002 641
-rw-r--r-- 1 0 0 10602496 Dec 26 2002 650
-rw-r--r-- 1 0 0 403 Dec 26 2002 661
-rw-r--r-- 1 0 0 3339204 Dec 26 2002 670
-rw-r--r-- 1 0 0 316 Dec 27 2002 681
-rw-r--r-- 1 0 0 377 Mar 12 01:10 501
-rw-r--r-- 1 0 0 351 Dec 28 2002 5d1
-rw-r--r-- 1 0 0 11723129 Dec 28 2002 610
-rw-r--r-- 1 0 0 441 Dec 27 2002 6d1
-rw-r--r-- 1 0 0 351 Dec 28 2002 621
-rw-r--r-- 1 0 0 366 Dec 27 2002 701
-rw-r--r-- 1 0 0 8896566 Dec 26 2002 710
-rw-r--r-- 1 0 0 393 Dec 27 2002 721
-rw-r--r-- 1 0 0 7402122 Dec 26 2002 730
-rw-r--r-- 1 0 0 366 Dec 26 2002 731
-rw-r--r-- 1 0 0 10272520 Dec 26 2002 740
-rw-r--r-- 1 0 0 421 Dec 27 2002 761
-rw-r--r-- 1 0 0 7591729 Dec 26 2002 770
-rw-r--r-- 1 0 0 378 Dec 26 2002 771
-rw-r--r-- 1 0 0 4610507 Dec 26 2002 780
-rw-r--r-- 1 0 0 409 Dec 27 2002 791
-rw-r--r-- 1 0 0 12197371 Dec 26 2002 7a0
-rw-r--r-- 1 0 0 353 Dec 27 2002 3bb1
-rw-r--r-- 1 0 0 6314925 Dec 26 2002 7d0
-rw-r--r-- 1 0 0 358 Dec 27 2002 7d1
-rw-r--r-- 1 0 0 5358532 Dec 28 2002 690
-rw-r--r-- 1 0 0 410 Dec 27 2002 801
-rw-r--r-- 1 0 0 375 Dec 28 2002 691
-rw-r--r-- 1 0 0 6146241 Dec 28 2002 6a0
-rw-r--r-- 1 0 0 459 Dec 28 2002 6b1
-rw-r--r-- 1 0 0 372 Dec 27 2002 841
-rw-r--r-- 1 0 0 5401205 Dec 26 2002 850
-rw-r--r-- 1 0 0 437 Dec 27 2002 851
-rw-r--r-- 1 0 0 10696330 Dec 26 2002 860
-rw-r--r-- 1 0 0 417 Dec 26 2002 881
-rw-r--r-- 1 0 0 7687733 Dec 27 2002 32b0
-rw-r--r-- 1 0 0 5425123 Dec 27 2002 32d0
-rw-r--r-- 1 0 0 5971968 Dec 26 2002 8a0
-rw-r--r-- 1 0 0 392 Dec 27 2002 8b1
-rw-r--r-- 1 0 0 16359967 Dec 26 2002 8c0
-rw-r--r-- 1 0 0 7691164 Dec 28 2002 6e0
-rw-r--r-- 1 0 0 376 Dec 27 2002 b11
-rw-r--r-- 1 0 0 441 Dec 28 2002 8d1
-rw-r--r-- 1 0 0 402 Dec 26 2002 911
-rw-r--r-- 1 0 0 10099590 Dec 26 2002 10b0
-rw-r--r-- 1 0 0 409 Dec 27 2002 931
-rw-r--r-- 1 0 0 8327794 Dec 26 2002 940
-rw-r--r-- 1 0 0 381 Dec 26 2002 961
-rw-r--r-- 1 0 0 6174720 Dec 26 2002 970
-rw-r--r-- 1 0 0 305 Dec 27 2002 971
-rw-r--r-- 1 0 0 18802688 Dec 26 2002 980
-rw-r--r-- 1 0 0 7078138 Dec 28 2002 8f0
-rw-r--r-- 1 0 0 343 Dec 28 2002 9c1
-rw-r--r-- 1 0 0 8799086 Dec 28 2002 ad0
-rw-r--r-- 1 0 0 6902724 Dec 26 2002 9d0
-rw-r--r-- 1 0 0 390 Dec 26 2002 9e1
-rw-r--r-- 1 0 0 7336604 Dec 26 2002 9f0
-rw-r--r-- 1 0 0 392 Dec 26 2002 9f1
-rw-r--r-- 1 0 0 10977784 Dec 26 2002 a00
-rw-r--r-- 1 0 0 430 Dec 26 2002 a11
-rw-r--r-- 1 0 0 9935018 Dec 26 2002 a20
-rw-r--r-- 1 0 0 426 Dec 26 2002 a41
-rw-r--r-- 1 0 0 6163184 Dec 26 2002 a50
-rw-r--r-- 1 0 0 544 Dec 26 2002 a51
-rw-r--r-- 1 0 0 11909527 Dec 26 2002 a60
-rw-r--r-- 1 0 0 398 Dec 27 2002 a81
-rw-r--r-- 1 0 0 7058912 Dec 26 2002 a90
-rw-r--r-- 1 0 0 413 Jan 3 19:36 ab1
-rw-r--r-- 1 0 0 5775071 Dec 26 2002 ac0
-rw-r--r-- 1 0 0 360 Dec 27 2002 ac1
-rw-r--r-- 1 0 0 436 Dec 28 2002 b21
-rw-r--r-- 1 0 0 350 Jan 3 19:36 af1
-rw-r--r-- 1 0 0 10031501 Dec 26 2002 b00
-rw-r--r-- 1 0 0 9932955 Dec 28 2002 7e0
-rw-r--r-- 1 0 0 441 Dec 28 2002 811
-rw-r--r-- 1 0 0 386 Dec 27 2002 b41
-rw-r--r-- 1 0 0 6065130 Dec 26 2002 b50
-rw-r--r-- 1 0 0 10672194 Dec 27 2002 b60
-rw-r--r-- 1 0 0 9121460 Dec 26 2002 b70
-rw-r--r-- 1 0 0 374 Dec 27 2002 b91
-rw-r--r-- 1 0 0 12937010 Dec 26 2002 ba0
-rw-r--r-- 1 0 0 13824776 Dec 28 2002 820
-rw-r--r-- 1 0 0 429 Dec 28 2002 901
-rw-r--r-- 1 0 0 9090113 Dec 28 2002 9b0
-rw-r--r-- 1 0 0 5600444 Dec 26 2002 bf0
-rw-r--r-- 1 0 0 329 Dec 27 2002 bf1
-rw-r--r-- 1 0 0 377 Dec 28 2002 3f1
-rw-r--r-- 1 0 0 8084376 Dec 26 2002 c20
-rw-r--r-- 1 0 0 326 Dec 26 2002 c41
-rw-r--r-- 1 0 0 9404416 Dec 26 2002 c50
-rw-r--r-- 1 0 0 825 Dec 26 2002 c61
-rw-r--r-- 1 0 0 6692177 Dec 26 2002 c70
-rw-r--r-- 1 0 0 351 Dec 26 2002 c71
-rw-r--r-- 1 0 0 10200530 Dec 26 2002 c80
-rw-r--r-- 1 0 0 13338624 Dec 28 2002 b30
-rw-r--r-- 1 0 0 9368265 Dec 26 2002 cb0
-rw-r--r-- 1 0 0 365 Dec 27 2002 cb1
-rw-r--r-- 1 0 0 3506966 Dec 26 2002 cc0
-rw-r--r-- 1 0 0 361 Dec 26 2002 cd1
-rw-r--r-- 1 0 0 12314473 Dec 26 2002 ce0
-rw-r--r-- 1 0 0 370 Dec 27 2002 d01
-rw-r--r-- 1 0 0 342 Dec 28 2002 bc1
-rw-r--r-- 1 0 0 11229035 Dec 28 2002 bd0
-rw-r--r-- 1 0 0 5176298 Dec 26 2002 d20
-rw-r--r-- 1 0 0 528 Dec 26 2002 d31
-rw-r--r-- 1 0 0 3586176 Dec 26 2002 d40
-rw-r--r-- 1 0 0 392 Dec 26 2002 d41
-rw-r--r-- 1 0 0 5287102 Dec 26 2002 d50
-rw-r--r-- 1 0 0 326 Dec 30 2002 be1
-rw-r--r-- 1 0 0 441 Dec 30 2002 c01
-rw-r--r-- 1 0 0 2298776 Dec 28 2002 c30
-rw-r--r-- 1 0 0 451 Dec 28 2002 c31
-rw-r--r-- 1 0 0 4630698 Dec 28 2002 ca0
-rw-r--r-- 1 0 0 12726049 Mar 1 02:04 a780
-rw-r--r-- 1 0 0 375 Dec 26 2002 dc1
-rw-r--r-- 1 0 0 5767168 Dec 26 2002 dd0
-rw-r--r-- 1 0 0 319 Dec 26 2002 df1
-rw-r--r-- 1 0 0 9850026 Dec 26 2002 e00
-rw-r--r-- 1 0 0 398 Dec 26 2002 e11
-rw-r--r-- 1 0 0 9648922 Dec 26 2002 e20
-rw-r--r-- 1 0 0 386 Dec 26 2002 e41
-rw-r--r-- 1 0 0 10309381 Dec 28 2002 d10
-rw-r--r-- 1 0 0 369 Dec 26 2002 e61
-rw-r--r-- 1 0 0 4990431 Dec 26 2002 e70
-rw-r--r-- 1 0 0 353 Dec 26 2002 e71
-rw-r--r-- 1 0 0 10066884 Dec 26 2002 e80
-rw-r--r-- 1 0 0 360 Dec 26 2002 e91
-rw-r--r-- 1 0 0 7859764 Dec 26 2002 ea0
-rw-r--r-- 1 0 0 422 Dec 26 2002 eb1
-rw-r--r-- 1 0 0 3911808 Dec 26 2002 ec0
-rw-r--r-- 1 0 0 411 Dec 26 2002 ed1
-rw-r--r-- 1 0 0 3819439 Dec 26 2002 ee0
-rw-r--r-- 1 0 0 431 Jan 3 19:36 ef1
-rw-r--r-- 1 0 0 11249562 Dec 26 2002 f00
-rw-r--r-- 1 0 0 399 Dec 26 2002 f01
-rw-r--r-- 1 0 0 11602412 Dec 26 2002 f10
-rw-r--r-- 1 0 0 309 Dec 28 2002 f31
-rw-r--r-- 1 0 0 5689597 Dec 26 2002 1070
-rw-r--r-- 1 0 0 333 Dec 26 2002 f51
-rw-r--r-- 1 0 0 10069902 Dec 26 2002 f60
-rw-r--r-- 1 0 0 322 Dec 26 2002 f71
-rw-r--r-- 1 0 0 7077215 Dec 26 2002 f80
-rw-r--r-- 1 0 0 325 Dec 27 2002 fa1
-rw-r--r-- 1 0 0 429 Dec 28 2002 d71
-rw-r--r-- 1 0 0 19162584 Dec 28 2002 d80
-rw-r--r-- 1 0 0 4989180 Dec 26 2002 fd0
-rw-r--r-- 1 0 0 358 Dec 26 2002 fe1
-rw-r--r-- 1 0 0 11891401 Dec 26 2002 ff0
-rw-r--r-- 1 0 0 376 Dec 26 2002 1011
-rw-r--r-- 1 0 0 7201437 Dec 26 2002 1020
-rw-r--r-- 1 0 0 418 Dec 26 2002 1031
-rw-r--r-- 1 0 0 11677489 Dec 26 2002 1040
-rw-r--r-- 1 0 0 429 Dec 28 2002 921
-rw-r--r-- 1 0 0 10638026 Dec 26 2002 1060
-rw-r--r-- 1 0 0 5430853 Dec 26 2002 1080
-rw-r--r-- 1 0 0 382 Dec 26 2002 10b1
-rw-r--r-- 1 0 0 385 Dec 27 2002 10a1
-rw-r--r-- 1 0 0 415 Dec 26 2002 1081
-rw-r--r-- 1 0 0 3735552 Dec 26 2002 1050
-rw-r--r-- 1 0 0 344 Dec 27 2002 10c1
-rw-r--r-- 1 0 0 431 Dec 27 2002 b61
-rw-r--r-- 1 0 0 5426276 Dec 27 2002 bb0
-rw-r--r-- 1 0 0 328 Dec 28 2002 da1
-rw-r--r-- 1 0 0 7816173 Dec 28 2002 e50
-rw-r--r-- 1 0 0 369 Dec 28 2002 fc1
-rw-r--r-- 1 0 0 12080676 Dec 28 2002 10e0
-rw-r--r-- 1 0 0 11738864 Dec 29 2002 fb0
-rw-r--r-- 1 0 0 4780536 Dec 28 2002 10f0
-rw-r--r-- 1 0 0 427 Dec 28 2002 10f1
-rw-r--r-- 1 0 0 5196995 Dec 27 2002 1130
-rw-r--r-- 1 0 0 417 Dec 27 2002 1131
-rw-r--r-- 1 0 0 418 Dec 27 2002 1141
-rw-r--r-- 1 0 0 5409983 Dec 27 2002 1150
-rw-r--r-- 1 0 0 439 Dec 27 2002 1151
-rw-r--r-- 1 0 0 7275230 Dec 27 2002 1160
-rw-r--r-- 1 0 0 349 Dec 27 2002 1171
-rw-r--r-- 1 0 0 5391390 Dec 27 2002 1180
-rw-r--r-- 1 0 0 381 Dec 27 2002 1191
-rw-r--r-- 1 0 0 6082350 Dec 27 2002 11a0
-rw-r--r-- 1 0 0 4767744 Dec 28 2002 1110
-rw-r--r-- 1 0 0 529 Dec 28 2002 1121
-rw-r--r-- 1 0 0 7418115 Dec 28 2002 11b0
-rw-r--r-- 1 0 0 5574032 Dec 27 2002 11e0
-rw-r--r-- 1 0 0 374 Dec 27 2002 11f1
-rw-r--r-- 1 0 0 400 Dec 28 2002 11c1
-rw-r--r-- 1 0 0 348 Dec 29 2002 11d1
-rw-r--r-- 1 0 0 379 Dec 28 2002 1201
-rw-r--r-- 1 0 0 336 Dec 27 2002 1241
-rw-r--r-- 1 0 0 7089424 Dec 27 2002 1250
-rw-r--r-- 1 0 0 5720318 Dec 28 2002 1210
-rw-r--r-- 1 0 0 10317824 Dec 27 2002 1270
-rw-r--r-- 1 0 0 326 Jan 10 08:52 7bc1
-rw-r--r-- 1 0 0 8251963 Dec 27 2002 1290
-rw-r--r-- 1 0 0 420 Dec 28 2002 1211
-rw-r--r-- 1 0 0 7628786 Dec 28 2002 1220
-rw-r--r-- 1 0 0 355 Dec 28 2002 1231
-rw-r--r-- 1 0 0 339 Jan 3 10:03 12b1
-rw-r--r-- 1 0 0 363 Dec 27 2002 1301
-rw-r--r-- 1 0 0 5398511 Dec 27 2002 1310
-rw-r--r-- 1 0 0 330 Dec 27 2002 1321
-rw-r--r-- 1 0 0 5976662 Dec 27 2002 1330
-rw-r--r-- 1 0 0 345 Dec 27 2002 1341
-rw-r--r-- 1 0 0 5038784 Dec 27 2002 1350
-rw-r--r-- 1 0 0 336 Dec 27 2002 1361
-rw-r--r-- 1 0 0 5122900 Dec 27 2002 1370
-rw-r--r-- 1 0 0 356 Dec 27 2002 1381
-rw-r--r-- 1 0 0 9487691 Dec 27 2002 13b0
-rw-r--r-- 1 0 0 333 Dec 27 2002 13b1
-rw-r--r-- 1 0 0 9240888 Dec 27 2002 13c0
-rw-r--r-- 1 0 0 359 Dec 27 2002 13d1
-rw-r--r-- 1 0 0 7428471 Dec 27 2002 13e0
-rw-r--r-- 1 0 0 346 Dec 27 2002 13f1
-rw-r--r-- 1 0 0 9658456 Dec 27 2002 1400
-rw-r--r-- 1 0 0 342 Dec 27 2002 1411
-rw-r--r-- 1 0 0 8930705 Dec 27 2002 1420
-rw-r--r-- 1 0 0 351 Dec 27 2002 1431
-rw-r--r-- 1 0 0 8544805 Dec 27 2002 1440
-rw-r--r-- 1 0 0 357 Dec 27 2002 1451
-rw-r--r-- 1 0 0 4240186 Dec 27 2002 1480
-rw-r--r-- 1 0 0 409 Dec 27 2002 1491
-rw-r--r-- 1 0 0 4404461 Dec 27 2002 14a0
-rw-r--r-- 1 0 0 352 Dec 27 2002 14b1
-rw-r--r-- 1 0 0 7100530 Dec 27 2002 14c0
-rw-r--r-- 1 0 0 336 Dec 27 2002 14d1
-rw-r--r-- 1 0 0 7924782 Dec 27 2002 14e0
-rw-r--r-- 1 0 0 385 Dec 27 2002 14f1
-rw-r--r-- 1 0 0 5533668 Dec 27 2002 1500
-rw-r--r-- 1 0 0 347 Dec 27 2002 1521
-rw-r--r-- 1 0 0 6029711 Dec 27 2002 1550
-rw-r--r-- 1 0 0 361 Dec 27 2002 1561
-rw-r--r-- 1 0 0 6712205 Dec 27 2002 1570
-rw-r--r-- 1 0 0 384 Dec 27 2002 1581
-rw-r--r-- 1 0 0 5136226 Dec 27 2002 1590
-rw-r--r-- 1 0 0 371 Dec 27 2002 15a1
-rw-r--r-- 1 0 0 8603521 Dec 27 2002 15b0
-rw-r--r-- 1 0 0 371 Dec 27 2002 15c1
-rw-r--r-- 1 0 0 7529757 Dec 27 2002 15d0
-rw-r--r-- 1 0 0 369 Dec 27 2002 15f1
-rw-r--r-- 1 0 0 3985010 Dec 27 2002 1600
-rw-r--r-- 1 0 0 389 Dec 27 2002 1601
-rw-r--r-- 1 0 0 5442107 Dec 27 2002 1610
-rw-r--r-- 1 0 0 366 Dec 27 2002 1621
-rw-r--r-- 1 0 0 5383520 Dec 27 2002 1630
-rw-r--r-- 1 0 0 315 Dec 27 2002 1651
-rw-r--r-- 1 0 0 5198075 Dec 27 2002 1660
-rw-r--r-- 1 0 0 311 Dec 27 2002 1671
-rw-r--r-- 1 0 0 7184662 Dec 27 2002 1680
-rw-r--r-- 1 0 0 302 Dec 27 2002 1691
-rw-r--r-- 1 0 0 6783620 Dec 27 2002 16a0
-rw-r--r-- 1 0 0 308 Dec 27 2002 16b1
-rw-r--r-- 1 0 0 9590255 Dec 27 2002 16c0
-rw-r--r-- 1 0 0 373 Dec 27 2002 1701
-rw-r--r-- 1 0 0 6729883 Dec 27 2002 1710
-rw-r--r-- 1 0 0 360 Dec 27 2002 1721
-rw-r--r-- 1 0 0 8241310 Dec 27 2002 1730
-rw-r--r-- 1 0 0 362 Dec 27 2002 1731
-rw-r--r-- 1 0 0 4829861 Dec 27 2002 1740
-rw-r--r-- 1 0 0 384 Dec 27 2002 1751
-rw-r--r-- 1 0 0 8702323 Dec 27 2002 1760
-rw-r--r-- 1 0 0 358 Dec 27 2002 1771
-rw-r--r-- 1 0 0 6644158 Dec 27 2002 1780
-rw-r--r-- 1 0 0 368 Dec 27 2002 1791
-rw-r--r-- 1 0 0 7391774 Dec 27 2002 17a0
-rw-r--r-- 1 0 0 350 Dec 27 2002 17c1
-rw-r--r-- 1 0 0 7706038 Dec 27 2002 1800
-rw-r--r-- 1 0 0 341 Dec 27 2002 1811
-rw-r--r-- 1 0 0 9448238 Dec 27 2002 1820
-rw-r--r-- 1 0 0 321 Dec 27 2002 1831
-rw-r--r-- 1 0 0 10689480 Dec 27 2002 1840
-rw-r--r-- 1 0 0 334 Dec 27 2002 1861
-rw-r--r-- 1 0 0 6475295 Dec 27 2002 1870
-rw-r--r-- 1 0 0 365 Dec 27 2002 1881
-rw-r--r-- 1 0 0 3779835 Dec 27 2002 1890
-rw-r--r-- 1 0 0 327 Dec 27 2002 1891
-rw-r--r-- 1 0 0 10750631 Dec 27 2002 18a0
-rw-r--r-- 1 0 0 362 Dec 27 2002 18e1
-rw-r--r-- 1 0 0 6951939 Dec 27 2002 18f0
-rw-r--r-- 1 0 0 357 Dec 27 2002 1921
-rw-r--r-- 1 0 0 8565676 Dec 27 2002 1930
-rw-r--r-- 1 0 0 363 Dec 27 2002 1941
-rw-r--r-- 1 0 0 7850561 Dec 27 2002 1950
-rw-r--r-- 1 0 0 360 Dec 27 2002 1961
-rw-r--r-- 1 0 0 9203335 Dec 27 2002 1970
-rw-r--r-- 1 0 0 339 Dec 27 2002 19a1
-rw-r--r-- 1 0 0 7124724 Dec 27 2002 19b0
-rw-r--r-- 1 0 0 321 Dec 27 2002 19c1
-rw-r--r-- 1 0 0 1281591 Dec 27 2002 19f0
-rw-r--r-- 1 0 0 335 Dec 27 2002 19f1
-rw-r--r-- 1 0 0 8460568 Dec 27 2002 1a00
-rw-r--r-- 1 0 0 329 Dec 27 2002 1a11
-rw-r--r-- 1 0 0 9495937 Dec 27 2002 1a20
-rw-r--r-- 1 0 0 358 Dec 27 2002 1a31
-rw-r--r-- 1 0 0 7703394 Dec 27 2002 1a40
-rw-r--r-- 1 0 0 370 Dec 27 2002 1a51
-rw-r--r-- 1 0 0 4231032 Dec 27 2002 1a60
-rw-r--r-- 1 0 0 341 Dec 27 2002 1a61
-rw-r--r-- 1 0 0 7870427 Dec 27 2002 1a70
-rw-r--r-- 1 0 0 339 Dec 27 2002 1a81
-rw-r--r-- 1 0 0 6236522 Dec 27 2002 1a90
-rw-r--r-- 1 0 0 337 Dec 27 2002 1aa1
-rw-r--r-- 1 0 0 7708334 Dec 27 2002 1ab0
-rw-r--r-- 1 0 0 365 Dec 27 2002 1ac1
-rw-r--r-- 1 0 0 8671199 Dec 27 2002 1ad0
-rw-r--r-- 1 0 0 327 Dec 27 2002 1ae1
-rw-r--r-- 1 0 0 1173937 Dec 27 2002 1af0
-rw-r--r-- 1 0 0 382 Dec 27 2002 1af1
-rw-r--r-- 1 0 0 6553481 Dec 27 2002 1b00
-rw-r--r-- 1 0 0 367 Dec 27 2002 1b11
-rw-r--r-- 1 0 0 9192286 Dec 27 2002 1b20
-rw-r--r-- 1 0 0 335 Dec 27 2002 1b31
-rw-r--r-- 1 0 0 7448901 Dec 27 2002 1b40
-rw-r--r-- 1 0 0 347 Dec 27 2002 1b51
-rw-r--r-- 1 0 0 8137967 Dec 27 2002 1b60
-rw-r--r-- 1 0 0 337 Dec 30 2002 1ba1
-rw-r--r-- 1 0 0 3115892 Dec 27 2002 1bd0
-rw-r--r-- 1 0 0 344 Dec 27 2002 1bd1
-rw-r--r-- 1 0 0 18472402 Dec 27 2002 1be0
-rw-r--r-- 1 0 0 358 Dec 27 2002 1c21
-rw-r--r-- 1 0 0 16221290 Dec 27 2002 1c30
-rw-r--r-- 1 0 0 326 Dec 27 2002 1c71
-rw-r--r-- 1 0 0 7025101 Dec 27 2002 1c80
-rw-r--r-- 1 0 0 318 Dec 27 2002 1c81
-rw-r--r-- 1 0 0 9434094 Dec 27 2002 1c90
-rw-r--r-- 1 0 0 347 Dec 27 2002 1cb1
-rw-r--r-- 1 0 0 7915960 Dec 27 2002 1cc0
-rw-r--r-- 1 0 0 335 Dec 27 2002 1cc1
-rw-r--r-- 1 0 0 6322778 Dec 27 2002 1cd0
-rw-r--r-- 1 0 0 332 Dec 27 2002 1ce1
-rw-r--r-- 1 0 0 7529026 Dec 27 2002 1cf0
-rw-r--r-- 1 0 0 348 Dec 27 2002 1d41
-rw-r--r-- 1 0 0 9195688 Dec 27 2002 1d50
-rw-r--r-- 1 0 0 345 Dec 27 2002 1d71
-rw-r--r-- 1 0 0 7201434 Dec 27 2002 1d80
-rw-r--r-- 1 0 0 338 Dec 27 2002 1d91
-rw-r--r-- 1 0 0 6053846 Dec 27 2002 1da0
-rw-r--r-- 1 0 0 348 Dec 27 2002 1db1
-rw-r--r-- 1 0 0 294620 Dec 27 2002 1dc0
-rw-r--r-- 1 0 0 349 Dec 27 2002 1dc1
-rw-r--r-- 1 0 0 9121064 Dec 27 2002 1dd0
-rw-r--r-- 1 0 0 458 Dec 27 2002 1df1
-rw-r--r-- 1 0 0 10231222 Dec 27 2002 1e00
-rw-r--r-- 1 0 0 367 Dec 27 2002 1e21
-rw-r--r-- 1 0 0 7095542 Dec 27 2002 1e30
-rw-r--r-- 1 0 0 363 Dec 27 2002 1e41
-rw-r--r-- 1 0 0 7587918 Dec 27 2002 1e50
-rw-r--r-- 1 0 0 331 Jan 8 19:39 7771
-rw-r--r-- 1 0 0 12442315 Dec 27 2002 1ec0
-rw-r--r-- 1 0 0 357 Dec 27 2002 1ee1
-rw-r--r-- 1 0 0 8754535 Dec 27 2002 1ef0
-rw-r--r-- 1 0 0 343 Dec 27 2002 1f01
-rw-r--r-- 1 0 0 6114391 Dec 27 2002 1f10
-rw-r--r-- 1 0 0 347 Dec 27 2002 1f21
-rw-r--r-- 1 0 0 7206534 Dec 27 2002 1f30
-rw-r--r-- 1 0 0 338 Dec 27 2002 1f41
-rw-r--r-- 1 0 0 6598733 Dec 27 2002 1f50
-rw-r--r-- 1 0 0 380 Jan 3 21:01 1f81
-rw-r--r-- 1 0 0 7894478 Dec 27 2002 1f90
-rw-r--r-- 1 0 0 408 Jan 3 21:01 1fb1
-rw-r--r-- 1 0 0 9491468 Dec 27 2002 1fc0
-rw-r--r-- 1 0 0 410 Jan 3 21:01 1fd1
-rw-r--r-- 1 0 0 4989427 Dec 27 2002 1fe0
-rw-r--r-- 1 0 0 402 Jan 3 21:01 1fe1
-rw-r--r-- 1 0 0 8722015 Dec 27 2002 1ff0
-rw-r--r-- 1 0 0 364 Jan 3 21:01 2001
-rw-r--r-- 1 0 0 7188483 Dec 27 2002 2010
-rw-r--r-- 1 0 0 383 Jan 3 21:01 2021
-rw-r--r-- 1 0 0 4 Dec 27 2002 12e0
-rw-r--r-- 1 0 0 46 Dec 27 2002 12e1
-rw-r--r-- 1 0 0 36 Dec 27 2002 12f0
-rw-r--r-- 1 0 0 37 Dec 27 2002 12f1
-rw-r--r-- 1 0 0 4 Dec 27 2002 1390
-rw-r--r-- 1 0 0 38 Dec 27 2002 1391
-rw-r--r-- 1 0 0 44 Dec 27 2002 13a0
-rw-r--r-- 1 0 0 49 Dec 27 2002 13a1
-rw-r--r-- 1 0 0 4 Dec 27 2002 1460
-rw-r--r-- 1 0 0 43 Dec 27 2002 1461
-rw-r--r-- 1 0 0 44 Dec 27 2002 1470
-rw-r--r-- 1 0 0 41 Dec 27 2002 1471
-rw-r--r-- 1 0 0 8 Dec 27 2002 1530
-rw-r--r-- 1 0 0 44 Dec 27 2002 1531
-rw-r--r-- 1 0 0 60 Dec 27 2002 1540
-rw-r--r-- 1 0 0 53 Dec 27 2002 1541
-rw-r--r-- 1 0 0 40 Jan 16 22:12 1640
-rw-r--r-- 1 0 0 35 Jan 16 22:12 1641
-rw-r--r-- 1 0 0 12 Jan 7 17:52 16d0
-rw-r--r-- 1 0 0 47 Jan 7 17:52 16d1
-rw-r--r-- 1 0 0 56 Dec 27 2002 16e0
-rw-r--r-- 1 0 0 47 Dec 27 2002 16e1
-rw-r--r-- 1 0 0 44 Feb 17 00:00 17d0
-rw-r--r-- 1 0 0 80 Feb 17 00:00 17d1
-rw-r--r-- 1 0 0 4 Dec 27 2002 17e0
-rw-r--r-- 1 0 0 37 Dec 27 2002 17e1
-rw-r--r-- 1 0 0 48 Dec 27 2002 17f0
-rw-r--r-- 1 0 0 42 Dec 27 2002 17f1
-rw-r--r-- 1 0 0 4 Dec 27 2002 18c0
-rw-r--r-- 1 0 0 42 Dec 27 2002 18c1
-rw-r--r-- 1 0 0 12 Dec 30 2002 18d0
-rw-r--r-- 1 0 0 37 Dec 30 2002 18d1
-rw-r--r-- 1 0 0 4 Dec 27 2002 1900
-rw-r--r-- 1 0 0 54 Dec 27 2002 1901
-rw-r--r-- 1 0 0 28 Dec 27 2002 1910
-rw-r--r-- 1 0 0 44 Dec 27 2002 1911
-rw-r--r-- 1 0 0 48 Dec 27 2002 1990
-rw-r--r-- 1 0 0 39 Dec 27 2002 1991
-rw-r--r-- 1 0 0 8 Dec 27 2002 19d0
-rw-r--r-- 1 0 0 42 Dec 27 2002 19d1
-rw-r--r-- 1 0 0 56 Feb 3 19:34 19e0
-rw-r--r-- 1 0 0 45 Feb 3 19:34 19e1
-rw-r--r-- 1 0 0 20 Jan 7 20:41 1b80
-rw-r--r-- 1 0 0 42 Jan 7 20:41 1b81
-rw-r--r-- 1 0 0 371 Jan 7 17:13 5521
-rw-r--r-- 1 0 0 6264832 Jan 7 17:13 5530
-rw-r--r-- 1 0 0 12 Jan 7 20:41 1bb0
-rw-r--r-- 1 0 0 37 Jan 7 20:41 1bb1
-rw-r--r-- 1 0 0 28 Dec 27 2002 1bc0
-rw-r--r-- 1 0 0 40 Dec 27 2002 1bc1
-rw-r--r-- 1 0 0 20 Dec 30 2002 1c40
-rw-r--r-- 1 0 0 45 Dec 30 2002 1c41
-rw-r--r-- 1 0 0 48 Jan 7 23:57 1c50
-rw-r--r-- 1 0 0 36 Jan 7 23:57 1c51
-rw-r--r-- 1 0 0 8 Dec 27 2002 1d10
-rw-r--r-- 1 0 0 43 Dec 27 2002 1d11
-rw-r--r-- 1 0 0 84 Jan 3 19:38 1d20
-rw-r--r-- 1 0 0 42 Jan 3 19:38 1d21
-rw-r--r-- 1 0 0 5487775 Jan 8 19:39 7780
-rw-r--r-- 1 0 0 431 Jan 8 19:40 7791
-rw-r--r-- 1 0 0 6757274 Jan 8 19:40 77a0
-rw-r--r-- 1 0 0 344 Jan 8 19:40 77b1
-rw-r--r-- 1 0 0 8 Jan 8 09:36 1ea0
-rw-r--r-- 1 0 0 40 Jan 8 09:36 1ea1
-rw-r--r-- 1 0 0 40 Dec 27 2002 1eb0
-rw-r--r-- 1 0 0 37 Dec 27 2002 1eb1
-rw-r--r-- 1 0 0 8 Dec 28 2002 1f60
-rw-r--r-- 1 0 0 37 Dec 28 2002 1f61
-rw-r--r-- 1 0 0 44 Dec 27 2002 1f70
-rw-r--r-- 1 0 0 57 Dec 27 2002 1f71
-rw-r--r-- 1 0 0 6853591 Dec 27 2002 2080
-rw-r--r-- 1 0 0 350 Dec 27 2002 2081
-rw-r--r-- 1 0 0 8965935 Dec 27 2002 2090
-rw-r--r-- 1 0 0 359 Dec 27 2002 20a1
-rw-r--r-- 1 0 0 7426365 Dec 27 2002 20b0
-rw-r--r-- 1 0 0 351 Dec 27 2002 20b1
-rw-r--r-- 1 0 0 10408657 Dec 27 2002 20c0
-rw-r--r-- 1 0 0 376 Dec 27 2002 20e1
-rw-r--r-- 1 0 0 8783479 Dec 27 2002 20f0
-rw-r--r-- 1 0 0 354 Dec 27 2002 20f1
-rw-r--r-- 1 0 0 10260487 Dec 27 2002 2120
-rw-r--r-- 1 0 0 345 Dec 27 2002 2131
-rw-r--r-- 1 0 0 10087891 Dec 27 2002 2140
-rw-r--r-- 1 0 0 352 Dec 27 2002 2161
-rw-r--r-- 1 0 0 8940360 Dec 27 2002 2170
-rw-r--r-- 1 0 0 351 Dec 27 2002 2171
-rw-r--r-- 1 0 0 7657592 Dec 27 2002 2180
-rw-r--r-- 1 0 0 340 Dec 27 2002 2191
-rw-r--r-- 1 0 0 10076207 Dec 27 2002 21a0
-rw-r--r-- 1 0 0 346 Dec 27 2002 21b1
-rw-r--r-- 1 0 0 9863197 Dec 27 2002 21c0
-rw-r--r-- 1 0 0 351 Dec 27 2002 21d1
-rw-r--r-- 1 0 0 7504257 Dec 27 2002 21e0
-rw-r--r-- 1 0 0 324 Dec 27 2002 2201
-rw-r--r-- 1 0 0 8614911 Dec 27 2002 2210
-rw-r--r-- 1 0 0 343 Dec 27 2002 2221
-rw-r--r-- 1 0 0 8489905 Dec 27 2002 2230
-rw-r--r-- 1 0 0 350 Dec 27 2002 2241
-rw-r--r-- 1 0 0 7822945 Dec 27 2002 2270
-rw-r--r-- 1 0 0 337 Dec 27 2002 2281
-rw-r--r-- 1 0 0 6474307 Dec 27 2002 2290
-rw-r--r-- 1 0 0 339 Dec 27 2002 22c1
-rw-r--r-- 1 0 0 6597311 Dec 27 2002 22d0
-rw-r--r-- 1 0 0 340 Dec 27 2002 22e1
-rw-r--r-- 1 0 0 7165627 Dec 27 2002 2310
-rw-r--r-- 1 0 0 343 Dec 27 2002 2321
-rw-r--r-- 1 0 0 7808096 Dec 27 2002 2330
-rw-r--r-- 1 0 0 337 Dec 27 2002 2341
-rw-r--r-- 1 0 0 9766753 Dec 27 2002 2350
-rw-r--r-- 1 0 0 8406614 Dec 27 2002 2370
-rw-r--r-- 1 0 0 347 Dec 27 2002 2391
-rw-r--r-- 1 0 0 8834798 Dec 27 2002 23a0
-rw-r--r-- 1 0 0 331 Dec 27 2002 23b1
-rw-r--r-- 1 0 0 7929128 Dec 27 2002 23c0
-rw-r--r-- 1 0 0 366 Dec 27 2002 23d1
-rw-r--r-- 1 0 0 7652246 Dec 27 2002 23e0
-rw-r--r-- 1 0 0 328 Dec 27 2002 23f1
-rw-r--r-- 1 0 0 7377211 Dec 27 2002 2400
-rw-r--r-- 1 0 0 340 Dec 27 2002 2411
-rw-r--r-- 1 0 0 7811938 Dec 27 2002 2420
-rw-r--r-- 1 0 0 344 Dec 27 2002 2431
-rw-r--r-- 1 0 0 6775589 Dec 27 2002 2440
-rw-r--r-- 1 0 0 338 Dec 27 2002 2451
-rw-r--r-- 1 0 0 8082709 Dec 27 2002 2460
-rw-r--r-- 1 0 0 335 Dec 27 2002 2481
-rw-r--r-- 1 0 0 8209328 Dec 27 2002 2490
-rw-r--r-- 1 0 0 328 Dec 27 2002 24a1
-rw-r--r-- 1 0 0 7762289 Dec 27 2002 24b0
-rw-r--r-- 1 0 0 342 Dec 27 2002 24c1
-rw-r--r-- 1 0 0 6697463 Dec 27 2002 24d0
-rw-r--r-- 1 0 0 342 Dec 27 2002 24e1
-rw-r--r-- 1 0 0 6611934 Dec 27 2002 24f0
-rw-r--r-- 1 0 0 340 Dec 27 2002 2501
-rw-r--r-- 1 0 0 6810745 Dec 27 2002 2510
-rw-r--r-- 1 0 0 333 Dec 27 2002 2521
-rw-r--r-- 1 0 0 8041832 Dec 27 2002 2530
-rw-r--r-- 1 0 0 339 Dec 27 2002 2541
-rw-r--r-- 1 0 0 40 Feb 6 18:58 1980
-rw-r--r-- 1 0 0 78 Feb 6 18:58 1981
-rw-r--r-- 1 0 0 72 Feb 17 00:00 2030
-rw-r--r-- 1 0 0 78 Feb 17 00:00 2031
-rw-r--r-- 1 0 0 76 Mar 7 22:21 2040
-rw-r--r-- 1 0 0 80 Mar 7 22:21 2041
-rw-r--r-- 1 0 0 12 Jan 15 23:57 2050
-rw-r--r-- 1 0 0 80 Jan 15 23:57 2051
-rw-r--r-- 1 0 0 8 Jan 9 10:14 2060
-rw-r--r-- 1 0 0 39 Jan 9 10:14 2061
-rw-r--r-- 1 0 0 32 Jan 9 10:14 2070
-rw-r--r-- 1 0 0 49 Jan 9 10:14 2071
-rw-r--r-- 1 0 0 12 Dec 27 2002 2100
-rw-r--r-- 1 0 0 46 Dec 27 2002 2101
-rw-r--r-- 1 0 0 52 Dec 27 2002 2110
-rw-r--r-- 1 0 0 41 Dec 27 2002 2111
-rw-r--r-- 1 0 0 56 Dec 27 2002 21f0
-rw-r--r-- 1 0 0 42 Dec 27 2002 21f1
-rw-r--r-- 1 0 0 4 Dec 27 2002 2250
-rw-r--r-- 1 0 0 43 Dec 27 2002 2251
-rw-r--r-- 1 0 0 48 Dec 27 2002 2260
-rw-r--r-- 1 0 0 40 Dec 27 2002 2261
-rw-r--r-- 1 0 0 4 Dec 27 2002 22a0
-rw-r--r-- 1 0 0 41 Dec 27 2002 22a1
-rw-r--r-- 1 0 0 40 Dec 27 2002 22b0
-rw-r--r-- 1 0 0 45 Dec 27 2002 22b1
-rw-r--r-- 1 0 0 4 Dec 27 2002 22f0
-rw-r--r-- 1 0 0 44 Dec 27 2002 22f1
-rw-r--r-- 1 0 0 44 Dec 27 2002 2300
-rw-r--r-- 1 0 0 46 Dec 27 2002 2301
-rw-r--r-- 1 0 0 8266986 Dec 27 2002 2570
-rw-r--r-- 1 0 0 327 Dec 27 2002 2581
-rw-r--r-- 1 0 0 6218806 Dec 27 2002 2590
-rw-r--r-- 1 0 0 319 Dec 27 2002 25a1
-rw-r--r-- 1 0 0 4797410 Dec 27 2002 25b0
-rw-r--r-- 1 0 0 328 Dec 27 2002 25c1
-rw-r--r-- 1 0 0 4705051 Dec 27 2002 25d0
-rw-r--r-- 1 0 0 312 Dec 27 2002 25d1
-rw-r--r-- 1 0 0 5701236 Dec 27 2002 25e0
-rw-r--r-- 1 0 0 345 Dec 27 2002 25f1
-rw-r--r-- 1 0 0 6591355 Dec 27 2002 2600
-rw-r--r-- 1 0 0 382 Dec 27 2002 2631
-rw-r--r-- 1 0 0 8014433 Dec 27 2002 2640
-rw-r--r-- 1 0 0 389 Dec 27 2002 2651
-rw-r--r-- 1 0 0 7349394 Dec 27 2002 2660
-rw-r--r-- 1 0 0 373 Dec 27 2002 2671
-rw-r--r-- 1 0 0 5493387 Dec 27 2002 2680
-rw-r--r-- 1 0 0 368 Dec 27 2002 2691
-rw-r--r-- 1 0 0 5876179 Dec 27 2002 26a0
-rw-r--r-- 1 0 0 382 Dec 27 2002 26b1
-rw-r--r-- 1 0 0 6567147 Dec 27 2002 26c0
-rw-r--r-- 1 0 0 371 Dec 27 2002 26d1
-rw-r--r-- 1 0 0 8327910 Dec 27 2002 26e0
-rw-r--r-- 1 0 0 380 Dec 27 2002 2701
-rw-r--r-- 1 0 0 5500234 Dec 27 2002 2710
-rw-r--r-- 1 0 0 374 Dec 27 2002 2711
-rw-r--r-- 1 0 0 4326909 Dec 27 2002 2720
-rw-r--r-- 1 0 0 387 Dec 27 2002 2731
-rw-r--r-- 1 0 0 6142893 Dec 27 2002 2740
-rw-r--r-- 1 0 0 375 Dec 27 2002 2771
-rw-r--r-- 1 0 0 7064976 Dec 27 2002 2780
-rw-r--r-- 1 0 0 377 Dec 27 2002 2791
-rw-r--r-- 1 0 0 8077175 Dec 27 2002 27a0
-rw-r--r-- 1 0 0 363 Dec 27 2002 27b1
-rw-r--r-- 1 0 0 6736584 Dec 27 2002 27e0
-rw-r--r-- 1 0 0 408 Dec 27 2002 27f1
-rw-r--r-- 1 0 0 9079669 Dec 27 2002 2800
-rw-r--r-- 1 0 0 6065273 Dec 27 2002 2820
-rw-r--r-- 1 0 0 390 Dec 27 2002 2851
-rw-r--r-- 1 0 0 8582936 Dec 27 2002 2860
-rw-r--r-- 1 0 0 333 Dec 27 2002 2871
-rw-r--r-- 1 0 0 5969550 Dec 27 2002 2880
-rw-r--r-- 1 0 0 387 Dec 27 2002 2891
-rw-r--r-- 1 0 0 5726141 Dec 27 2002 28a0
-rw-r--r-- 1 0 0 368 Dec 27 2002 28b1
-rw-r--r-- 1 0 0 6290106 Dec 27 2002 28c0
-rw-r--r-- 1 0 0 307 Dec 27 2002 28c1
-rw-r--r-- 1 0 0 4606678 Dec 27 2002 28d0
-rw-r--r-- 1 0 0 326 Dec 27 2002 28e1
-rw-r--r-- 1 0 0 9104672 Dec 27 2002 28f0
-rw-r--r-- 1 0 0 320 Dec 27 2002 2941
-rw-r--r-- 1 0 0 6755387 Dec 27 2002 2950
-rw-r--r-- 1 0 0 301 Dec 27 2002 2961
-rw-r--r-- 1 0 0 4437281 Dec 27 2002 2970
-rw-r--r-- 1 0 0 319 Dec 27 2002 2981
-rw-r--r-- 1 0 0 4755452 Dec 27 2002 2990
-rw-r--r-- 1 0 0 319 Dec 27 2002 29b1
-rw-r--r-- 1 0 0 6900920 Dec 27 2002 29c0
-rw-r--r-- 1 0 0 341 Dec 27 2002 29d1
-rw-r--r-- 1 0 0 7639065 Dec 27 2002 29e0
-rw-r--r-- 1 0 0 332 Dec 27 2002 29e1
-rw-r--r-- 1 0 0 7291245 Dec 27 2002 29f0
-rw-r--r-- 1 0 0 335 Dec 27 2002 2a01
-rw-r--r-- 1 0 0 6684123 Dec 27 2002 2a10
-rw-r--r-- 1 0 0 321 Dec 27 2002 2a21
-rw-r--r-- 1 0 0 5899564 Dec 27 2002 2a30
-rw-r--r-- 1 0 0 375 Dec 27 2002 2a41
-rw-r--r-- 1 0 0 6855334 Dec 27 2002 2a60
-rw-r--r-- 1 0 0 397 Dec 27 2002 2a61
-rw-r--r-- 1 0 0 5594767 Dec 27 2002 2a70
-rw-r--r-- 1 0 0 9971463 Jan 14 21:22 8460
-rw-r--r-- 1 0 0 8431994 Dec 27 2002 2a50
-rw-r--r-- 1 0 0 386 Dec 27 2002 2a91
-rw-r--r-- 1 0 0 12446174 Dec 27 2002 2aa0
-rw-r--r-- 1 0 0 386 Dec 27 2002 2ab1
-rw-r--r-- 1 0 0 21520100 Dec 27 2002 2ac0
-rw-r--r-- 1 0 0 387 Dec 27 2002 2ac1
-rw-r--r-- 1 0 0 18383924 Dec 27 2002 2ad0
-rw-r--r-- 1 0 0 454 Jan 6 10:50 2b11
-rw-r--r-- 1 0 0 14423397 Dec 27 2002 2b20
-rw-r--r-- 1 0 0 426 Jan 6 10:50 2b21
-rw-r--r-- 1 0 0 16318006 Dec 27 2002 2b30
-rw-r--r-- 1 0 0 425 Jan 6 10:50 2b41
-rw-r--r-- 1 0 0 26944618 Dec 27 2002 2b50
-rw-r--r-- 1 0 0 369 Dec 27 2002 2b81
-rw-r--r-- 1 0 0 13173126 Dec 27 2002 2b90
-rw-r--r-- 1 0 0 380 Dec 27 2002 2bb1
-rw-r--r-- 1 0 0 7743892 Dec 27 2002 2bc0
-rw-r--r-- 1 0 0 366 Dec 27 2002 2bd1
-rw-r--r-- 1 0 0 3246946 Dec 27 2002 2be0
-rw-r--r-- 1 0 0 357 Dec 27 2002 2c01
-rw-r--r-- 1 0 0 6974211 Dec 27 2002 2c10
-rw-r--r-- 1 0 0 338 Dec 27 2002 2c11
-rw-r--r-- 1 0 0 7915556 Dec 27 2002 2c20
-rw-r--r-- 1 0 0 344 Dec 27 2002 2c31
-rw-r--r-- 1 0 0 8702708 Dec 27 2002 2c40
-rw-r--r-- 1 0 0 352 Dec 27 2002 2c61
-rw-r--r-- 1 0 0 7733139 Dec 27 2002 2c70
-rw-r--r-- 1 0 0 326 Dec 27 2002 2c71
-rw-r--r-- 1 0 0 6462883 Dec 27 2002 2c80
-rw-r--r-- 1 0 0 347 Dec 27 2002 2c91
-rw-r--r-- 1 0 0 8860436 Dec 27 2002 2ca0
-rw-r--r-- 1 0 0 334 Dec 27 2002 2ce1
-rw-r--r-- 1 0 0 5648508 Dec 27 2002 2cf0
-rw-r--r-- 1 0 0 337 Dec 27 2002 2cf1
-rw-r--r-- 1 0 0 9033630 Dec 27 2002 2d00
-rw-r--r-- 1 0 0 367 Dec 27 2002 2d21
-rw-r--r-- 1 0 0 9412686 Dec 27 2002 2d30
-rw-r--r-- 1 0 0 313 Dec 27 2002 2d41
-rw-r--r-- 1 0 0 6296205 Dec 27 2002 2d50
-rw-r--r-- 1 0 0 355 Dec 27 2002 2d61
-rw-r--r-- 1 0 0 690403 Dec 27 2002 2d80
-rw-r--r-- 1 0 0 333 Dec 27 2002 2d81
-rw-r--r-- 1 0 0 5919913 Dec 27 2002 2d90
-rw-r--r-- 1 0 0 348 Dec 27 2002 2db1
-rw-r--r-- 1 0 0 183279 Dec 27 2002 2dc0
-rw-r--r-- 1 0 0 345 Dec 27 2002 2dc1
-rw-r--r-- 1 0 0 7102746 Dec 27 2002 2dd0
-rw-r--r-- 1 0 0 341 Dec 27 2002 2df1
-rw-r--r-- 1 0 0 85133 Dec 27 2002 2e00
-rw-r--r-- 1 0 0 350 Dec 27 2002 2e01
-rw-r--r-- 1 0 0 7353751 Dec 27 2002 2e10
-rw-r--r-- 1 0 0 347 Dec 27 2002 2e21
-rw-r--r-- 1 0 0 404998 Dec 27 2002 2e30
-rw-r--r-- 1 0 0 341 Dec 27 2002 2e31
-rw-r--r-- 1 0 0 7841341 Dec 27 2002 2e40
-rw-r--r-- 1 0 0 344 Dec 27 2002 2e61
-rw-r--r-- 1 0 0 252044 Dec 27 2002 2e70
-rw-r--r-- 1 0 0 342 Dec 27 2002 2e71
-rw-r--r-- 1 0 0 6393880 Dec 27 2002 2e80
-rw-r--r-- 1 0 0 334 Dec 27 2002 2ea1
-rw-r--r-- 1 0 0 233779 Dec 27 2002 2eb0
-rw-r--r-- 1 0 0 347 Dec 27 2002 2eb1
-rw-r--r-- 1 0 0 8938120 Dec 27 2002 2ec0
-rw-r--r-- 1 0 0 369 Dec 27 2002 2ee1
-rw-r--r-- 1 0 0 518605 Dec 27 2002 2ef0
-rw-r--r-- 1 0 0 330 Dec 27 2002 2ef1
-rw-r--r-- 1 0 0 9577410 Dec 27 2002 2f00
-rw-r--r-- 1 0 0 347 Dec 27 2002 2f21
-rw-r--r-- 1 0 0 6930812 Dec 27 2002 2f40
-rw-r--r-- 1 0 0 378 Dec 27 2002 2f51
-rw-r--r-- 1 0 0 6555928 Dec 27 2002 2f60
-rw-r--r-- 1 0 0 392 Dec 27 2002 2f71
-rw-r--r-- 1 0 0 10794652 Dec 27 2002 2f80
-rw-r--r-- 1 0 0 383 Dec 27 2002 2fa1
-rw-r--r-- 1 0 0 6902353 Dec 27 2002 2fb0
-rw-r--r-- 1 0 0 375 Dec 27 2002 2fc1
-rw-r--r-- 1 0 0 3099682 Dec 27 2002 2fd0
-rw-r--r-- 1 0 0 391 Dec 27 2002 2fd1
-rw-r--r-- 1 0 0 36 Dec 27 2002 2af0
-rw-r--r-- 1 0 0 53 Dec 27 2002 2af1
-rw-r--r-- 1 0 0 48 Dec 27 2002 2bf0
-rw-r--r-- 1 0 0 43 Dec 27 2002 2bf1
-rw-r--r-- 1 0 0 28 Jan 3 09:03 2cc0
-rw-r--r-- 1 0 0 35 Jan 3 09:03 2cc1
-rw-r--r-- 1 0 0 36 Dec 27 2002 2cd0
-rw-r--r-- 1 0 0 43 Dec 27 2002 2cd1
-rw-r--r-- 1 0 0 108 Dec 27 2002 2d70
-rw-r--r-- 1 0 0 37 Dec 27 2002 2d71
-rw-r--r-- 1 0 0 40 Dec 27 2002 2f30
-rw-r--r-- 1 0 0 65 Dec 27 2002 2f31
-rw-r--r-- 1 0 0 419 Dec 27 2002 2fe1
-rw-r--r-- 1 0 0 9191552 Dec 27 2002 2ff0
-rw-r--r-- 1 0 0 363 Dec 27 2002 3021
-rw-r--r-- 1 0 0 11119105 Dec 27 2002 3040
-rw-r--r-- 1 0 0 416 Dec 27 2002 3051
-rw-r--r-- 1 0 0 6853694 Dec 27 2002 3060
-rw-r--r-- 1 0 0 391 Dec 27 2002 3071
-rw-r--r-- 1 0 0 3692544 Dec 27 2002 3080
-rw-r--r-- 1 0 0 347 Dec 27 2002 3081
-rw-r--r-- 1 0 0 9451476 Dec 27 2002 3090
-rw-r--r-- 1 0 0 380 Dec 27 2002 30b1
-rw-r--r-- 1 0 0 6919651 Dec 27 2002 30c0
-rw-r--r-- 1 0 0 324 Dec 27 2002 30c1
-rw-r--r-- 1 0 0 7131264 Dec 27 2002 30d0
-rw-r--r-- 1 0 0 384 Dec 27 2002 30e1
-rw-r--r-- 1 0 0 431 Dec 28 2002 12c1
-rw-r--r-- 1 0 0 400 Dec 27 2002 3101
-rw-r--r-- 1 0 0 14206958 Dec 28 2002 12d0
-rw-r--r-- 1 0 0 312 Dec 27 2002 3121
-rw-r--r-- 1 0 0 9851843 Dec 27 2002 3130
-rw-r--r-- 1 0 0 327 Dec 27 2002 3151
-rw-r--r-- 1 0 0 8722211 Dec 27 2002 3160
-rw-r--r-- 1 0 0 322 Dec 27 2002 3171
-rw-r--r-- 1 0 0 9831155 Dec 27 2002 3180
-rw-r--r-- 1 0 0 332 Dec 28 2002 30f1
-rw-r--r-- 1 0 0 11712512 Dec 27 2002 31a0
-rw-r--r-- 1 0 0 302 Dec 27 2002 31b1
-rw-r--r-- 1 0 0 13999837 Dec 27 2002 31c0
-rw-r--r-- 1 0 0 412 Dec 27 2002 31d1
-rw-r--r-- 1 0 0 7261676 Dec 27 2002 31e0
-rw-r--r-- 1 0 0 344 Dec 27 2002 31f1
-rw-r--r-- 1 0 0 10025107 Dec 27 2002 3200
-rw-r--r-- 1 0 0 10668032 Dec 28 2002 3d20
-rw-r--r-- 1 0 0 8277012 Dec 27 2002 3220
-rw-r--r-- 1 0 0 348 Dec 27 2002 3231
-rw-r--r-- 1 0 0 4905924 Dec 27 2002 3240
-rw-r--r-- 1 0 0 320 Dec 27 2002 3251
-rw-r--r-- 1 0 0 5011876 Dec 27 2002 3260
-rw-r--r-- 1 0 0 331 Dec 27 2002 3261
-rw-r--r-- 1 0 0 28 Dec 28 2002 1260
-rw-r--r-- 1 0 0 398 Dec 28 2002 3111
-rw-r--r-- 1 0 0 5363840 Dec 27 2002 3280
-rw-r--r-- 1 0 0 307 Dec 27 2002 3291
-rw-r--r-- 1 0 0 5360988 Dec 27 2002 32a0
-rw-r--r-- 1 0 0 407 Feb 14 09:53 32e1
-rw-r--r-- 1 0 0 7168650 Dec 27 2002 32f0
-rw-r--r-- 1 0 0 370 Dec 27 2002 3301
-rw-r--r-- 1 0 0 8126592 Dec 27 2002 3310
-rw-r--r-- 1 0 0 364 Dec 27 2002 3321
-rw-r--r-- 1 0 0 13668020 Dec 27 2002 3330
-rw-r--r-- 1 0 0 392 Dec 27 2002 3341
-rw-r--r-- 1 0 0 13686711 Dec 27 2002 3350
-rw-r--r-- 1 0 0 391 Mar 10 23:07 9421
-rw-r--r-- 1 0 0 9699328 Dec 27 2002 3370
-rw-r--r-- 1 0 0 3920376 Dec 28 2002 3190
-rw-r--r-- 1 0 0 7636870 Dec 27 2002 3390
-rw-r--r-- 1 0 0 417 Dec 27 2002 3391
-rw-r--r-- 1 0 0 8853504 Dec 27 2002 33a0
-rw-r--r-- 1 0 0 444 Dec 27 2002 33b1
-rw-r--r-- 1 0 0 367 Dec 28 2002 3191
-rw-r--r-- 1 0 0 415 Dec 27 2002 33f1
-rw-r--r-- 1 0 0 10893694 Dec 28 2002 3270
-rw-r--r-- 1 0 0 392 Dec 27 2002 3411
-rw-r--r-- 1 0 0 8406938 Dec 27 2002 3420
-rw-r--r-- 1 0 0 323 Dec 27 2002 3431
-rw-r--r-- 1 0 0 11334566 Dec 27 2002 3440
-rw-r--r-- 1 0 0 389 Dec 27 2002 3461
-rw-r--r-- 1 0 0 12688742 Dec 27 2002 3470
-rw-r--r-- 1 0 0 345 Dec 30 2002 3491
-rw-r--r-- 1 0 0 10589124 Dec 27 2002 34a0
-rw-r--r-- 1 0 0 410 Dec 30 2002 34b1
-rw-r--r-- 1 0 0 9101168 Dec 27 2002 34c0
-rw-r--r-- 1 0 0 406 Dec 30 2002 34c1
-rw-r--r-- 1 0 0 11252416 Dec 27 2002 34d0
-rw-r--r-- 1 0 0 376 Dec 27 2002 34f1
-rw-r--r-- 1 0 0 7365277 Dec 27 2002 3500
-rw-r--r-- 1 0 0 386 Dec 27 2002 3511
-rw-r--r-- 1 0 0 5221719 Dec 27 2002 3520
-rw-r--r-- 1 0 0 438 Dec 27 2002 3521
-rw-r--r-- 1 0 0 9068544 Dec 27 2002 3540
-rw-r--r-- 1 0 0 359 Dec 27 2002 3561
-rw-r--r-- 1 0 0 4032512 Dec 27 2002 3570
-rw-r--r-- 1 0 0 336 Dec 27 2002 3571
-rw-r--r-- 1 0 0 334 Dec 27 2002 3581
-rw-r--r-- 1 0 0 6854656 Dec 27 2002 3590
-rw-r--r-- 1 0 0 341 Dec 27 2002 3591
-rw-r--r-- 1 0 0 4915200 Dec 27 2002 35a0
-rw-r--r-- 1 0 0 345 Dec 27 2002 35b1
-rw-r--r-- 1 0 0 5074944 Dec 27 2002 35c0
-rw-r--r-- 1 0 0 335 Dec 27 2002 35e1
-rw-r--r-- 1 0 0 5314560 Dec 27 2002 35f0
-rw-r--r-- 1 0 0 338 Dec 27 2002 3601
-rw-r--r-- 1 0 0 6055936 Dec 27 2002 3610
-rw-r--r-- 1 0 0 347 Dec 27 2002 3621
-rw-r--r-- 1 0 0 5072896 Dec 27 2002 3630
-rw-r--r-- 1 0 0 331 Dec 27 2002 3651
-rw-r--r-- 1 0 0 4599808 Dec 27 2002 3660
-rw-r--r-- 1 0 0 333 Dec 27 2002 3671
-rw-r--r-- 1 0 0 4259840 Dec 27 2002 3680
-rw-r--r-- 1 0 0 328 Dec 27 2002 36a1
-rw-r--r-- 1 0 0 5773312 Dec 27 2002 36b0
-rw-r--r-- 1 0 0 338 Dec 27 2002 36b1
-rw-r--r-- 1 0 0 8206336 Dec 27 2002 36c0
-rw-r--r-- 1 0 0 316 Dec 27 2002 36e1
-rw-r--r-- 1 0 0 3407872 Dec 27 2002 36f0
-rw-r--r-- 1 0 0 318 Dec 27 2002 36f1
-rw-r--r-- 1 0 0 6514688 Dec 27 2002 3700
-rw-r--r-- 1 0 0 362 Dec 27 2002 3711
-rw-r--r-- 1 0 0 4825088 Dec 27 2002 3720
-rw-r--r-- 1 0 0 319 Dec 27 2002 3731
-rw-r--r-- 1 0 0 5363712 Dec 27 2002 3740
-rw-r--r-- 1 0 0 380 Dec 27 2002 3761
-rw-r--r-- 1 0 0 4943872 Dec 27 2002 3770
-rw-r--r-- 1 0 0 381 Dec 27 2002 3781
-rw-r--r-- 1 0 0 6494208 Dec 27 2002 3790
-rw-r--r-- 1 0 0 365 Dec 27 2002 37a1
-rw-r--r-- 1 0 0 6336512 Dec 27 2002 37b0
-rw-r--r-- 1 0 0 350 Dec 27 2002 37c1
-rw-r--r-- 1 0 0 4962304 Dec 27 2002 37d0
-rw-r--r-- 1 0 0 386 Dec 27 2002 37e1
-rw-r--r-- 1 0 0 6623232 Dec 27 2002 37f0
-rw-r--r-- 1 0 0 359 Dec 27 2002 3821
-rw-r--r-- 1 0 0 5277696 Dec 27 2002 3830
-rw-r--r-- 1 0 0 333 Dec 27 2002 3841
-rw-r--r-- 1 0 0 5703680 Dec 27 2002 3850
-rw-r--r-- 1 0 0 346 Dec 27 2002 3861
-rw-r--r-- 1 0 0 4884480 Dec 27 2002 3870
-rw-r--r-- 1 0 0 381 Dec 27 2002 3871
-rw-r--r-- 1 0 0 4900864 Dec 27 2002 3880
-rw-r--r-- 1 0 0 334 Dec 27 2002 3891
-rw-r--r-- 1 0 0 4782080 Dec 27 2002 38a0
-rw-r--r-- 1 0 0 352 Dec 27 2002 38b1
-rw-r--r-- 1 0 0 3983360 Dec 27 2002 38c0
-rw-r--r-- 1 0 0 347 Dec 27 2002 38c1
-rw-r--r-- 1 0 0 5122048 Dec 27 2002 38d0
-rw-r--r-- 1 0 0 381 Dec 27 2002 38e1
-rw-r--r-- 1 0 0 7804928 Dec 27 2002 38f0
-rw-r--r-- 1 0 0 332 Dec 27 2002 3931
-rw-r--r-- 1 0 0 6807552 Dec 27 2002 3940
-rw-r--r-- 1 0 0 345 Dec 27 2002 3951
-rw-r--r-- 1 0 0 6918144 Dec 27 2002 3960
-rw-r--r-- 1 0 0 351 Dec 27 2002 3971
-rw-r--r-- 1 0 0 7868416 Dec 27 2002 3980
-rw-r--r-- 1 0 0 334 Dec 27 2002 39a1
-rw-r--r-- 1 0 0 5943296 Dec 27 2002 39b0
-rw-r--r-- 1 0 0 331 Dec 27 2002 39c1
-rw-r--r-- 1 0 0 4608000 Dec 27 2002 39d0
-rw-r--r-- 1 0 0 402 Dec 27 2002 39d1
-rw-r--r-- 1 0 0 3076096 Dec 27 2002 39e0
-rw-r--r-- 1 0 0 340 Dec 27 2002 3a11
-rw-r--r-- 1 0 0 6393856 Dec 27 2002 3a20
-rw-r--r-- 1 0 0 372 Dec 27 2002 3a31
-rw-r--r-- 1 0 0 6037504 Dec 27 2002 3a40
-rw-r--r-- 1 0 0 348 Dec 27 2002 3a51
-rw-r--r-- 1 0 0 6305792 Dec 27 2002 3a60
-rw-r--r-- 1 0 0 372 Dec 27 2002 3a81
-rw-r--r-- 1 0 0 6164480 Dec 27 2002 3a90
-rw-r--r-- 1 0 0 342 Dec 27 2002 3a91
-rw-r--r-- 1 0 0 6133760 Dec 27 2002 3aa0
-rw-r--r-- 1 0 0 344 Dec 27 2002 3ab1
-rw-r--r-- 1 0 0 7512064 Dec 27 2002 3ad0
-rw-r--r-- 1 0 0 345 Dec 27 2002 3af1
-rw-r--r-- 1 0 0 5888000 Dec 27 2002 3b00
-rw-r--r-- 1 0 0 353 Dec 27 2002 3b11
-rw-r--r-- 1 0 0 6125568 Dec 27 2002 3b20
-rw-r--r-- 1 0 0 350 Dec 27 2002 3b31
-rw-r--r-- 1 0 0 6377472 Dec 27 2002 3b40
-rw-r--r-- 1 0 0 366 Dec 27 2002 3b51
-rw-r--r-- 1 0 0 5466112 Dec 27 2002 3b60
-rw-r--r-- 1 0 0 354 Dec 27 2002 3b61
-rw-r--r-- 1 0 0 357 Dec 27 2002 3b71
-rw-r--r-- 1 0 0 7092224 Dec 27 2002 3b80
-rw-r--r-- 1 0 0 344 Dec 27 2002 3b91
-rw-r--r-- 1 0 0 6715392 Dec 27 2002 3ba0
-rw-r--r-- 1 0 0 358 Dec 27 2002 241
-rw-r--r-- 1 0 0 6713344 Dec 27 2002 3bc0
-rw-r--r-- 1 0 0 364 Dec 27 2002 3bd1
-rw-r--r-- 1 0 0 5484544 Dec 27 2002 3be0
-rw-r--r-- 1 0 0 349 Dec 27 2002 3bf1
-rw-r--r-- 1 0 0 5206016 Dec 27 2002 3c00
-rw-r--r-- 1 0 0 349 Dec 27 2002 3c11
-rw-r--r-- 1 0 0 5474304 Dec 27 2002 3c20
-rw-r--r-- 1 0 0 338 Dec 27 2002 3c31
-rw-r--r-- 1 0 0 5507072 Dec 27 2002 3c40
-rw-r--r-- 1 0 0 420 Dec 28 2002 33c1
-rw-r--r-- 1 0 0 13103680 Dec 27 2002 3c60
-rw-r--r-- 1 0 0 9623012 Dec 28 2002 3400
-rw-r--r-- 1 0 0 350 Dec 28 2002 3c51
-rw-r--r-- 1 0 0 334 Dec 28 2002 3c91
-rw-r--r-- 1 0 0 8308112 Dec 27 2002 3ca0
-rw-r--r-- 1 0 0 345 Dec 28 2002 3cb1
-rw-r--r-- 1 0 0 16842127 Dec 28 2002 3cc0
-rw-r--r-- 1 0 0 411 Dec 28 2002 3cd1
-rw-r--r-- 1 0 0 20642002 Dec 28 2002 3ce0
-rw-r--r-- 1 0 0 344 Dec 28 2002 3cf1
-rw-r--r-- 1 0 0 30542620 Dec 28 2002 3d00
-rw-r--r-- 1 0 0 462 Dec 28 2002 3d51
-rw-r--r-- 1 0 0 5709824 Dec 28 2002 3d60
-rw-r--r-- 1 0 0 408 Dec 28 2002 3d71
-rw-r--r-- 1 0 0 6234112 Dec 28 2002 3d80
-rw-r--r-- 1 0 0 468 Dec 28 2002 3d91
-rw-r--r-- 1 0 0 12097536 Dec 28 2002 3da0
-rw-r--r-- 1 0 0 406 Dec 28 2002 3db1
-rw-r--r-- 1 0 0 6899712 Dec 28 2002 3dc0
-rw-r--r-- 1 0 0 399 Dec 28 2002 3dd1
-rw-r--r-- 1 0 0 5769216 Dec 28 2002 3de0
-rw-r--r-- 1 0 0 413 Dec 28 2002 3df1
-rw-r--r-- 1 0 0 5289935 Dec 28 2002 3e20
-rw-r--r-- 1 0 0 323 Dec 28 2002 3e31
-rw-r--r-- 1 0 0 3962912 Dec 28 2002 3e40
-rw-r--r-- 1 0 0 323 Dec 28 2002 3e41
-rw-r--r-- 1 0 0 312 Dec 28 2002 3e51
-rw-r--r-- 1 0 0 4616188 Dec 28 2002 3e60
-rw-r--r-- 1 0 0 332 Dec 28 2002 3e61
-rw-r--r-- 1 0 0 4793399 Dec 28 2002 3e70
-rw-r--r-- 1 0 0 363 Dec 28 2002 3e81
-rw-r--r-- 1 0 0 4179834 Dec 28 2002 3e90
-rw-r--r-- 1 0 0 325 Dec 28 2002 3e91
-rw-r--r-- 1 0 0 5284088 Dec 28 2002 3ea0
-rw-r--r-- 1 0 0 335 Dec 28 2002 3ec1
-rw-r--r-- 1 0 0 4950989 Dec 28 2002 3ed0
-rw-r--r-- 1 0 0 364 Dec 28 2002 3ed1
-rw-r--r-- 1 0 0 6237023 Dec 28 2002 3ee0
-rw-r--r-- 1 0 0 326 Dec 28 2002 3ef1
-rw-r--r-- 1 0 0 6827492 Dec 28 2002 3f00
-rw-r--r-- 1 0 0 406 Jan 3 21:01 3f11
-rw-r--r-- 1 0 0 3657264 Dec 28 2002 3f20
-rw-r--r-- 1 0 0 377 Jan 3 21:01 3f31
-rw-r--r-- 1 0 0 7458097 Dec 28 2002 3f40
-rw-r--r-- 1 0 0 380 Jan 3 21:01 3f51
-rw-r--r-- 1 0 0 6288864 Dec 28 2002 3f60
-rw-r--r-- 1 0 0 378 Jan 3 21:01 3f61
-rw-r--r-- 1 0 0 6643591 Dec 28 2002 3f70
-rw-r--r-- 1 0 0 375 Jan 3 21:01 3f91
-rw-r--r-- 1 0 0 3535541 Dec 28 2002 3fa0
-rw-r--r-- 1 0 0 344 Jan 3 21:01 3fa1
-rw-r--r-- 1 0 0 4 Dec 28 2002 3d30
-rw-r--r-- 1 0 0 39 Dec 28 2002 3d31
-rw-r--r-- 1 0 0 52 Jan 16 08:29 3d40
-rw-r--r--
#151231 - 29/03/2003 14:58 Re: Playlists disappeared [Re: mlord]
dinkum
Loc: ca, usa
Here is some more, Mark.
Index of /drive1/fids
drwxr-xr-x 2 0 0 185344 Mar 11 01:13 ./
-rw-r--r-- 1 0 0 4 Mar 12 03:15 100
-rw-r--r-- 1 0 0 39 Mar 12 03:15 101
-rw-r--r-- 1 0 0 0 Mar 12 03:15 110
-rw-r--r-- 1 0 0 46 Mar 12 03:15 111
-rw-r--r-- 1 0 0 24 Jan 8 09:36 130
-rw-r--r-- 1 0 0 92 Jan 8 09:36 131
-rw-r--r-- 1 0 0 424 Mar 12 01:27 140
-rw-r--r-- 1 0 0 77 Mar 12 01:27 141
-rw-r--r-- 1 0 0 48 Mar 9 04:21 150
-rw-r--r-- 1 0 0 80 Mar 9 04:21 151
-rw-r--r-- 1 0 0 28 Mar 11 01:13 160
-rw-r--r-- 1 0 0 77 Mar 11 01:13 161
-rw-r--r-- 1 0 0 421 Dec 28 2002 411
-rw-r--r-- 1 0 0 9432606 Dec 28 2002 450
-rw-r--r-- 1 0 0 333 Dec 28 2002 4a1
-rw-r--r-- 1 0 0 11526269 Dec 28 2002 580
-rw-r--r-- 1 0 0 391 Dec 28 2002 5e1
-rw-r--r-- 1 0 0 6898953 Nov 15 2002 200
-rw-r--r-- 1 0 0 327 Nov 15 2002 201
-rw-r--r-- 1 0 0 7754107 Nov 15 2002 210
-rw-r--r-- 1 0 0 100 Feb 6 18:58 170
-rw-r--r-- 1 0 0 77 Feb 6 18:58 171
-rw-r--r-- 1 0 0 404 Dec 29 2002 4141
-rw-r--r-- 1 0 0 5046358 Dec 29 2002 4150
-rw-r--r-- 1 0 0 383 Nov 15 2002 221
-rw-r--r-- 1 0 0 7645584 Nov 15 2002 230
-rw-r--r-- 1 0 0 435 Nov 15 2002 231
-rw-r--r-- 1 0 0 8304976 Nov 15 2002 470
-rw-r--r-- 1 0 0 7991090 Dec 27 2002 2fe0
-rw-r--r-- 1 0 0 425 Dec 27 2002 2ff1
-rw-r--r-- 1 0 0 11656630 Dec 28 2002 1f0
-rw-r--r-- 1 0 0 433 Nov 15 2002 271
-rw-r--r-- 1 0 0 6807125 Nov 15 2002 280
-rw-r--r-- 1 0 0 422 Nov 15 2002 281
-rw-r--r-- 1 0 0 4662547 Nov 15 2002 290
-rw-r--r-- 1 0 0 395 Nov 15 2002 2a1
-rw-r--r-- 1 0 0 6788370 Nov 15 2002 2b0
-rw-r--r-- 1 0 0 374 Nov 15 2002 2c1
-rw-r--r-- 1 0 0 8710815 Nov 15 2002 2d0
-rw-r--r-- 1 0 0 355 Nov 15 2002 2f1
-rw-r--r-- 1 0 0 9110105 Nov 15 2002 300
-rw-r--r-- 1 0 0 466 Nov 15 2002 301
-rw-r--r-- 1 0 0 9567202 Nov 15 2002 310
-rw-r--r-- 1 0 0 459 Nov 15 2002 321
-rw-r--r-- 1 0 0 12555057 Nov 15 2002 330
-rw-r--r-- 1 0 0 384 Nov 15 2002 341
-rw-r--r-- 1 0 0 6416317 Nov 15 2002 350
-rw-r--r-- 1 0 0 506 Nov 15 2002 361
-rw-r--r-- 1 0 0 9124467 Nov 15 2002 370
-rw-r--r-- 1 0 0 416 Nov 15 2002 371
-rw-r--r-- 1 0 0 415 Dec 28 2002 1f1
-rw-r--r-- 1 0 0 354 Nov 15 2002 3a1
-rw-r--r-- 1 0 0 7771201 Nov 15 2002 3b0
-rw-r--r-- 1 0 0 418 Nov 15 2002 3c1
-rw-r--r-- 1 0 0 8580855 Nov 15 2002 3d0
-rw-r--r-- 1 0 0 381 Nov 15 2002 3e1
-rw-r--r-- 1 0 0 428 Dec 28 2002 251
-rw-r--r-- 1 0 0 8827997 Dec 28 2002 480
-rw-r--r-- 1 0 0 5827892 Nov 15 2002 400
-rw-r--r-- 1 0 0 368 Dec 28 2002 481
-rw-r--r-- 1 0 0 4486792 Nov 15 2002 420
-rw-r--r-- 1 0 0 353 Nov 15 2002 421
-rw-r--r-- 1 0 0 9222144 Nov 15 2002 430
-rw-r--r-- 1 0 0 5638044 Dec 28 2002 500
-rw-r--r-- 1 0 0 6536194 Nov 15 2002 490
-rw-r--r-- 1 0 0 12486427 Dec 28 2002 5d0
-rw-r--r-- 1 0 0 8100002 Nov 15 2002 4b0
-rw-r--r-- 1 0 0 412 Nov 15 2002 4c1
-rw-r--r-- 1 0 0 7602930 Nov 15 2002 4d0
-rw-r--r-- 1 0 0 350 Nov 15 2002 4e1
-rw-r--r-- 1 0 0 5048320 Nov 15 2002 4f0
-rw-r--r-- 1 0 0 360 Dec 28 2002 611
-rw-r--r-- 1 0 0 14417730 Nov 15 2002 510
-rw-r--r-- 1 0 0 360 Nov 15 2002 531
-rw-r--r-- 1 0 0 24 Mar 11 00:23 540
-rw-r--r-- 1 0 0 77 Mar 11 00:23 541
-rw-r--r-- 1 0 0 10248320 Nov 15 2002 550
-rw-r--r-- 1 0 0 11087872 Dec 28 2002 560
-rw-r--r-- 1 0 0 378 Dec 27 2002 8e1
-rw-r--r-- 1 0 0 9138260 Dec 28 2002 620
-rw-r--r-- 1 0 0 416 Dec 28 2002 6a1
-rw-r--r-- 1 0 0 310 Dec 27 2002 5b1
-rw-r--r-- 1 0 0 10257347 Dec 26 2002 5c0
-rw-r--r-- 1 0 0 4348575 Dec 28 2002 6b0
-rw-r--r-- 1 0 0 442 Dec 28 2002 6e1
-rw-r--r-- 1 0 0 5380184 Dec 28 2002 830
-rw-r--r-- 1 0 0 8293274 Dec 26 2002 5f0
-rw-r--r-- 1 0 0 494 Dec 28 2002 831
-rw-r--r-- 1 0 0 4862038 Dec 28 2002 8d0
-rw-r--r-- 1 0 0 342 Jan 14 21:22 631
-rw-r--r-- 1 0 0 8327755 Dec 26 2002 640
-rw-r--r-- 1 0 0 432 Dec 26 2002 651
-rw-r--r-- 1 0 0 5343038 Dec 26 2002 660
-rw-r--r-- 1 0 0 378 Dec 27 2002 671
-rw-r--r-- 1 0 0 7944568 Dec 26 2002 680
-rw-r--r-- 1 0 0 331 Dec 28 2002 8f1
-rw-r--r-- 1 0 0 6388088 Dec 28 2002 9c0
-rw-r--r-- 1 0 0 364 Dec 28 2002 ad1
-rw-r--r-- 1 0 0 4397581 Dec 26 2002 6c0
-rw-r--r-- 1 0 0 442 Dec 27 2002 6c1
-rw-r--r-- 1 0 0 5167104 Dec 26 2002 6d0
-rw-r--r-- 1 0 0 7975928 Dec 28 2002 b20
-rw-r--r-- 1 0 0 4341699 Dec 26 2002 6f0
-rw-r--r-- 1 0 0 378 Dec 27 2002 6f1
-rw-r--r-- 1 0 0 6375636 Dec 26 2002 700
-rw-r--r-- 1 0 0 337 Dec 27 2002 711
-rw-r--r-- 1 0 0 10699750 Dec 26 2002 720
-rw-r--r-- 1 0 0 389 Dec 26 2002 741
-rw-r--r-- 1 0 0 9226909 Dec 26 2002 750
-rw-r--r-- 1 0 0 444 Dec 26 2002 751
-rw-r--r-- 1 0 0 9798677 Dec 26 2002 760
-rw-r--r-- 1 0 0 294 Dec 27 2002 781
-rw-r--r-- 1 0 0 4386046 Dec 26 2002 790
-rw-r--r-- 1 0 0 413 Dec 27 2002 7a1
-rw-r--r-- 1 0 0 10361361 Dec 26 2002 7b0
-rw-r--r-- 1 0 0 355 Dec 27 2002 7b1
-rw-r--r-- 1 0 0 5318656 Dec 27 2002 3bb0
-rw-r--r-- 1 0 0 383 Dec 28 2002 7e1
-rw-r--r-- 1 0 0 5101529 Dec 26 2002 7f0
-rw-r--r-- 1 0 0 416 Dec 26 2002 7f1
-rw-r--r-- 1 0 0 10629120 Dec 26 2002 800
-rw-r--r-- 1 0 0 11906375 Dec 28 2002 810
-rw-r--r-- 1 0 0 448 Dec 28 2002 821
-rw-r--r-- 1 0 0 12998555 Dec 28 2002 900
-rw-r--r-- 1 0 0 9186870 Dec 26 2002 840
-rw-r--r-- 1 0 0 407 Dec 26 2002 861
-rw-r--r-- 1 0 0 7392330 Dec 26 2002 870
-rw-r--r-- 1 0 0 302 Dec 27 2002 871
-rw-r--r-- 1 0 0 10831724 Dec 26 2002 880
-rw-r--r-- 1 0 0 394 Dec 27 2002 8a1
-rw-r--r-- 1 0 0 14286472 Dec 26 2002 8b0
-rw-r--r-- 1 0 0 383 Dec 27 2002 8c1
-rw-r--r-- 1 0 0 408 Dec 28 2002 9b1
-rw-r--r-- 1 0 0 18484245 Dec 27 2002 b10
-rw-r--r-- 1 0 0 7639040 Dec 28 2002 3f0
-rw-r--r-- 1 0 0 441 Dec 28 2002 b31
-rw-r--r-- 1 0 0 15812318 Dec 28 2002 bc0
-rw-r--r-- 1 0 0 7050766 Dec 26 2002 910
-rw-r--r-- 1 0 0 10540404 Dec 26 2002 920
-rw-r--r-- 1 0 0 6887259 Dec 26 2002 930
-rw-r--r-- 1 0 0 338 Dec 27 2002 941
-rw-r--r-- 1 0 0 3844224 Dec 26 2002 950
-rw-r--r-- 1 0 0 383 Dec 27 2002 951
-rw-r--r-- 1 0 0 10420224 Dec 26 2002 960
-rw-r--r-- 1 0 0 380 Dec 27 2002 981
-rw-r--r-- 1 0 0 11450592 Dec 26 2002 990
-rw-r--r-- 1 0 0 388 Dec 27 2002 991
-rw-r--r-- 1 0 0 4844838 Dec 26 2002 9a0
-rw-r--r-- 1 0 0 375 Dec 27 2002 9a1
-rw-r--r-- 1 0 0 416 Dec 28 2002 bd1
-rw-r--r-- 1 0 0 410 Dec 26 2002 9d1
-rw-r--r-- 1 0 0 13125454 Dec 26 2002 9e0
-rw-r--r-- 1 0 0 380 Dec 27 2002 a01
-rw-r--r-- 1 0 0 7574803 Dec 26 2002 a10
-rw-r--r-- 1 0 0 387 Dec 27 2002 a21
-rw-r--r-- 1 0 0 6239044 Dec 26 2002 a30
-rw-r--r-- 1 0 0 374 Dec 26 2002 a31
-rw-r--r-- 1 0 0 11665408 Dec 26 2002 a40
-rw-r--r-- 1 0 0 435 Dec 26 2002 a61
-rw-r--r-- 1 0 0 5275626 Dec 26 2002 a70
-rw-r--r-- 1 0 0 428 Dec 26 2002 a71
-rw-r--r-- 1 0 0 7174144 Dec 26 2002 a80
-rw-r--r-- 1 0 0 343 Dec 27 2002 a91
-rw-r--r-- 1 0 0 2797291 Dec 26 2002 aa0
-rw-r--r-- 1 0 0 314 Dec 27 2002 aa1
-rw-r--r-- 1 0 0 9842071 Dec 26 2002 ab0
-rw-r--r-- 1 0 0 5619712 Dec 28 2002 be0
-rw-r--r-- 1 0 0 3918367 Dec 26 2002 ae0
-rw-r--r-- 1 0 0 356 Dec 27 2002 ae1
-rw-r--r-- 1 0 0 5024513 Dec 26 2002 af0
-rw-r--r-- 1 0 0 419 Dec 27 2002 b01
-rw-r--r-- 1 0 0 10420515 Dec 27 2002 10d0
-rw-r--r-- 1 0 0 354 Jan 3 19:36 10d1
-rw-r--r-- 1 0 0 9524246 Dec 28 2002 c00
-rw-r--r-- 1 0 0 399 Dec 28 2002 ca1
-rw-r--r-- 1 0 0 6506950 Dec 26 2002 b40
-rw-r--r-- 1 0 0 412 Dec 26 2002 b51
-rw-r--r-- 1 0 0 346 Dec 27 2002 bb1
-rw-r--r-- 1 0 0 440 Dec 26 2002 b71
-rw-r--r-- 1 0 0 4473294 Dec 26 2002 b80
-rw-r--r-- 1 0 0 443 Dec 27 2002 b81
-rw-r--r-- 1 0 0 6307132 Dec 26 2002 b90
-rw-r--r-- 1 0 0 436 Dec 26 2002 ba1
-rw-r--r-- 1 0 0 369 Dec 28 2002 d11
-rw-r--r-- 1 0 0 5011115 Dec 28 2002 d60
-rw-r--r-- 1 0 0 404 Dec 28 2002 d61
-rw-r--r-- 1 0 0 7305332 Dec 28 2002 d70
-rw-r--r-- 1 0 0 358 Dec 28 2002 d81
-rw-r--r-- 1 0 0 10169113 Dec 28 2002 da0
-rw-r--r-- 1 0 0 5575366 Dec 26 2002 c10
-rw-r--r-- 1 0 0 367 Dec 27 2002 c11
-rw-r--r-- 1 0 0 359 Dec 27 2002 c21
-rw-r--r-- 1 0 0 438 Dec 28 2002 e51
-rw-r--r-- 1 0 0 10651690 Dec 28 2002 fc0
-rw-r--r-- 1 0 0 9416704 Dec 26 2002 c40
-rw-r--r-- 1 0 0 441 Dec 26 2002 c51
-rw-r--r-- 1 0 0 12430777 Dec 26 2002 c60
-rw-r--r-- 1 0 0 435 Dec 27 2002 c81
-rw-r--r-- 1 0 0 5641761 Dec 26 2002 c90
-rw-r--r-- 1 0 0 443 Dec 27 2002 c91
-rw-r--r-- 1 0 0 393 Dec 28 2002 10e1
-rw-r--r-- 1 0 0 321 Dec 26 2002 cc1
-rw-r--r-- 1 0 0 3915151 Dec 26 2002 cd0
-rw-r--r-- 1 0 0 391 Dec 27 2002 ce1
-rw-r--r-- 1 0 0 8763557 Dec 26 2002 cf0
-rw-r--r-- 1 0 0 342 Dec 26 2002 cf1
-rw-r--r-- 1 0 0 13490241 Dec 26 2002 d00
-rw-r--r-- 1 0 0 417 Dec 27 2002 d21
-rw-r--r-- 1 0 0 10534912 Dec 26 2002 d30
-rw-r--r-- 1 0 0 419 Dec 26 2002 d51
-rw-r--r-- 1 0 0 2936958 Dec 28 2002 1100
-rw-r--r-- 1 0 0 364 Dec 28 2002 1101
-rw-r--r-- 1 0 0 5330361 Dec 26 2002 d90
-rw-r--r-- 1 0 0 454 Dec 26 2002 d91
-rw-r--r-- 1 0 0 10346580 Dec 28 2002 f40
-rw-r--r-- 1 0 0 403 Mar 1 02:04 a791
-rw-r--r-- 1 0 0 5484386 Dec 26 2002 dc0
-rw-r--r-- 1 0 0 449 Dec 27 2002 dd1
-rw-r--r-- 1 0 0 4087348 Dec 26 2002 de0
-rw-r--r-- 1 0 0 445 Dec 27 2002 de1
-rw-r--r-- 1 0 0 7764636 Dec 26 2002 df0
-rw-r--r-- 1 0 0 413 Dec 26 2002 e01
-rw-r--r-- 1 0 0 5205287 Dec 26 2002 e10
-rw-r--r-- 1 0 0 344 Dec 27 2002 e21
-rw-r--r-- 1 0 0 5750196 Dec 26 2002 e30
-rw-r--r-- 1 0 0 335 Dec 26 2002 e31
-rw-r--r-- 1 0 0 9197319 Dec 26 2002 e40
-rw-r--r-- 1 0 0 398 Dec 28 2002 f41
-rw-r--r-- 1 0 0 15138690 Dec 26 2002 e60
-rw-r--r-- 1 0 0 467 Dec 26 2002 e81
-rw-r--r-- 1 0 0 6503326 Dec 26 2002 e90
-rw-r--r-- 1 0 0 357 Dec 26 2002 ea1
-rw-r--r-- 1 0 0 8358476 Dec 26 2002 eb0
-rw-r--r-- 1 0 0 400 Dec 26 2002 ec1
-rw-r--r-- 1 0 0 5316568 Dec 26 2002 ed0
-rw-r--r-- 1 0 0 323 Jan 3 21:01 ee1
-rw-r--r-- 1 0 0 12963840 Dec 26 2002 ef0
-rw-r--r-- 1 0 0 392 Dec 26 2002 f11
-rw-r--r-- 1 0 0 9672540 Dec 26 2002 f20
-rw-r--r-- 1 0 0 446 Dec 27 2002 f21
-rw-r--r-- 1 0 0 6041572 Dec 26 2002 f30
-rw-r--r-- 1 0 0 401 Dec 26 2002 1071
-rw-r--r-- 1 0 0 5682648 Dec 26 2002 f50
-rw-r--r-- 1 0 0 343 Dec 26 2002 f61
-rw-r--r-- 1 0 0 6154240 Dec 26 2002 f70
-rw-r--r-- 1 0 0 342 Dec 26 2002 f81
-rw-r--r-- 1 0 0 5756552 Dec 26 2002 f90
-rw-r--r-- 1 0 0 316 Dec 26 2002 f91
-rw-r--r-- 1 0 0 3553199 Dec 26 2002 fa0
-rw-r--r-- 1 0 0 375 Dec 29 2002 fb1
-rw-r--r-- 1 0 0 471 Dec 28 2002 1111
-rw-r--r-- 1 0 0 336 Dec 27 2002 fd1
-rw-r--r-- 1 0 0 5420930 Dec 26 2002 fe0
-rw-r--r-- 1 0 0 684 Dec 26 2002 ff1
-rw-r--r-- 1 0 0 8467853 Dec 26 2002 1000
-rw-r--r-- 1 0 0 374 Dec 26 2002 1001
-rw-r--r-- 1 0 0 8444972 Dec 26 2002 1010
-rw-r--r-- 1 0 0 363 Dec 26 2002 1021
-rw-r--r-- 1 0 0 8180426 Dec 26 2002 1030
-rw-r--r-- 1 0 0 406 Dec 26 2002 1041
-rw-r--r-- 1 0 0 383 Dec 26 2002 1051
-rw-r--r-- 1 0 0 424 Dec 26 2002 1061
-rw-r--r-- 1 0 0 6008582 Dec 26 2002 10c0
-rw-r--r-- 1 0 0 5280051 Dec 28 2002 1120
-rw-r--r-- 1 0 0 6215321 Dec 26 2002 1090
-rw-r--r-- 1 0 0 434 Dec 26 2002 1091
-rw-r--r-- 1 0 0 6576298 Dec 26 2002 10a0
-rw-r--r-- 1 0 0 354 Dec 28 2002 11b1
-rw-r--r-- 1 0 0 4776633 Dec 28 2002 11c0
-rw-r--r-- 1 0 0 10717646 Dec 27 2002 1140
-rw-r--r-- 1 0 0 418 Dec 27 2002 1161
-rw-r--r-- 1 0 0 7224440 Dec 27 2002 1170
-rw-r--r-- 1 0 0 397 Dec 27 2002 1181
-rw-r--r-- 1 0 0 4356161 Dec 27 2002 1190
-rw-r--r-- 1 0 0 434 Jan 14 21:22 11a1
-rw-r--r-- 1 0 0 15378181 Dec 29 2002 11d0
-rw-r--r-- 1 0 0 13425267 Dec 28 2002 1200
-rw-r--r-- 1 0 0 442 Dec 29 2002 1221
-rw-r--r-- 1 0 0 349 Dec 27 2002 11e1
-rw-r--r-- 1 0 0 5092803 Dec 27 2002 11f0
-rw-r--r-- 1 0 0 13860362 Dec 28 2002 1230
-rw-r--r-- 1 0 0 8552907 Dec 30 2002 12b0
-rw-r--r-- 1 0 0 12036725 Dec 28 2002 12c0
-rw-r--r-- 1 0 0 359 Dec 28 2002 12d1
-rw-r--r-- 1 0 0 2487272 Dec 28 2002 30f0
-rw-r--r-- 1 0 0 3969483 Dec 27 2002 1240
-rw-r--r-- 1 0 0 346 Dec 27 2002 1251
-rw-r--r-- 1 0 0 84 Dec 28 2002 1261
-rw-r--r-- 1 0 0 372 Dec 27 2002 1271
-rw-r--r-- 1 0 0 10510908 Jan 10 08:45 1280
-rw-r--r-- 1 0 0 337 Dec 27 2002 1291
-rw-r--r-- 1 0 0 68 Feb 17 00:00 570
-rw-r--r-- 1 0 0 77 Feb 17 00:00 571
-rw-r--r-- 1 0 0 3464882 Dec 28 2002 12a0
-rw-r--r-- 1 0 0 323 Dec 28 2002 12a1
-rw-r--r-- 1 0 0 14543336 Dec 28 2002 3110
-rw-r--r-- 1 0 0 355 Dec 28 2002 3271
-rw-r--r-- 1 0 0 5920281 Dec 27 2002 1300
-rw-r--r-- 1 0 0 340 Dec 27 2002 1311
-rw-r--r-- 1 0 0 5369708 Dec 27 2002 1320
-rw-r--r-- 1 0 0 331 Dec 27 2002 1331
-rw-r--r-- 1 0 0 6518378 Dec 27 2002 1340
-rw-r--r-- 1 0 0 384 Dec 27 2002 1351
-rw-r--r-- 1 0 0 6430945 Dec 27 2002 1360
-rw-r--r-- 1 0 0 341 Dec 27 2002 1371
-rw-r--r-- 1 0 0 10279019 Dec 27 2002 1380
-rw-r--r-- 1 0 0 341 Dec 27 2002 13c1
-rw-r--r-- 1 0 0 9520513 Dec 27 2002 13d0
-rw-r--r-- 1 0 0 347 Dec 27 2002 13e1
-rw-r--r-- 1 0 0 9561666 Dec 27 2002 13f0
-rw-r--r-- 1 0 0 355 Dec 27 2002 1401
-rw-r--r-- 1 0 0 10021892 Dec 27 2002 1410
-rw-r--r-- 1 0 0 338 Dec 27 2002 1421
-rw-r--r-- 1 0 0 8034944 Dec 27 2002 1430
-rw-r--r-- 1 0 0 335 Dec 27 2002 1441
-rw-r--r-- 1 0 0 8900568 Dec 27 2002 1450
-rw-r--r-- 1 0 0 356 Dec 27 2002 1481
-rw-r--r-- 1 0 0 5379687 Dec 27 2002 1490
-rw-r--r-- 1 0 0 347 Dec 27 2002 14a1
-rw-r--r-- 1 0 0 5137052 Dec 27 2002 14b0
-rw-r--r-- 1 0 0 376 Dec 27 2002 14c1
-rw-r--r-- 1 0 0 7390294 Dec 27 2002 14d0
-rw-r--r-- 1 0 0 386 Dec 27 2002 14e1
-rw-r--r-- 1 0 0 4519265 Dec 27 2002 14f0
-rw-r--r-- 1 0 0 350 Dec 27 2002 1501
-rw-r--r-- 1 0 0 3054591 Dec 27 2002 1510
-rw-r--r-- 1 0 0 347 Dec 27 2002 1511
-rw-r--r-- 1 0 0 4542876 Dec 27 2002 1520
-rw-r--r-- 1 0 0 352 Dec 27 2002 1551
-rw-r--r-- 1 0 0 5071155 Dec 27 2002 1560
-rw-r--r-- 1 0 0 375 Dec 27 2002 1571
-rw-r--r-- 1 0 0 7484268 Dec 27 2002 1580
-rw-r--r-- 1 0 0 368 Dec 27 2002 1591
-rw-r--r-- 1 0 0 6736958 Dec 27 2002 15a0
-rw-r--r-- 1 0 0 353 Dec 27 2002 15b1
-rw-r--r-- 1 0 0 5508227 Dec 27 2002 15c0
-rw-r--r-- 1 0 0 376 Dec 27 2002 15d1
-rw-r--r-- 1 0 0 5060872 Dec 27 2002 15e0
-rw-r--r-- 1 0 0 396 Dec 27 2002 15e1
-rw-r--r-- 1 0 0 5885324 Dec 27 2002 15f0
-rw-r--r-- 1 0 0 373 Dec 27 2002 1611
-rw-r--r-- 1 0 0 5553654 Dec 27 2002 1620
-rw-r--r-- 1 0 0 370 Dec 27 2002 1631
-rw-r--r-- 1 0 0 5538152 Dec 27 2002 1650
-rw-r--r-- 1 0 0 303 Dec 27 2002 1661
-rw-r--r-- 1 0 0 7876948 Dec 27 2002 1670
-rw-r--r-- 1 0 0 296 Dec 27 2002 1681
-rw-r--r-- 1 0 0 5303178 Dec 27 2002 1690
-rw-r--r-- 1 0 0 323 Dec 27 2002 16a1
-rw-r--r-- 1 0 0 6329315 Dec 27 2002 16b0
-rw-r--r-- 1 0 0 295 Dec 27 2002 16c1
-rw-r--r-- 1 0 0 6488811 Dec 27 2002 16f0
-rw-r--r-- 1 0 0 367 Dec 27 2002 16f1
-rw-r--r-- 1 0 0 7278097 Dec 27 2002 1700
-rw-r--r-- 1 0 0 354 Dec 27 2002 1711
-rw-r--r-- 1 0 0 10041658 Dec 27 2002 1720
-rw-r--r-- 1 0 0 378 Dec 27 2002 1741
-rw-r--r-- 1 0 0 5826612 Dec 27 2002 1750
-rw-r--r-- 1 0 0 364 Dec 27 2002 1761
-rw-r--r-- 1 0 0 8539111 Dec 27 2002 1770
-rw-r--r-- 1 0 0 384 Dec 27 2002 1781
-rw-r--r-- 1 0 0 6431840 Dec 27 2002 1790
-rw-r--r-- 1 0 0 357 Dec 27 2002 17a1
-rw-r--r-- 1 0 0 5708425 Dec 27 2002 17b0
-rw-r--r-- 1 0 0 365 Dec 27 2002 17b1
-rw-r--r-- 1 0 0 6420901 Dec 27 2002 17c0
-rw-r--r-- 1 0 0 335 Dec 27 2002 1801
-rw-r--r-- 1 0 0 5851008 Dec 27 2002 1810
-rw-r--r-- 1 0 0 327 Dec 27 2002 1821
-rw-r--r-- 1 0 0 7308516 Dec 27 2002 1830
-rw-r--r-- 1 0 0 332 Dec 27 2002 1841
-rw-r--r-- 1 0 0 1556408 Dec 27 2002 1850
-rw-r--r-- 1 0 0 336 Dec 27 2002 1851
-rw-r--r-- 1 0 0 12142954 Dec 27 2002 1860
-rw-r--r-- 1 0 0 332 Dec 27 2002 1871
-rw-r--r-- 1 0 0 6893124 Dec 27 2002 1880
-rw-r--r-- 1 0 0 345 Dec 27 2002 18a1
-rw-r--r-- 1 0 0 5915171 Dec 27 2002 18b0
-rw-r--r-- 1 0 0 353 Dec 27 2002 18b1
-rw-r--r-- 1 0 0 6419063 Dec 27 2002 18e0
-rw-r--r-- 1 0 0 327 Dec 27 2002 18f1
-rw-r--r-- 1 0 0 9932330 Dec 27 2002 1920
-rw-r--r-- 1 0 0 379 Dec 27 2002 1931
-rw-r--r-- 1 0 0 9568201 Dec 27 2002 1940
-rw-r--r-- 1 0 0 387 Dec 27 2002 1951
-rw-r--r-- 1 0 0 7024146 Dec 27 2002 1960
-rw-r--r-- 1 0 0 368 Dec 27 2002 1971
-rw-r--r-- 1 0 0 9514042 Dec 27 2002 19a0
-rw-r--r-- 1 0 0 381 Dec 27 2002 19b1
-rw-r--r-- 1 0 0 9099383 Dec 27 2002 19c0
-rw-r--r-- 1 0 0 345 Dec 27 2002 1a01
-rw-r--r-- 1 0 0 7703571 Dec 27 2002 1a10
-rw-r--r-- 1 0 0 344 Dec 27 2002 1a21
-rw-r--r-- 1 0 0 7487298 Dec 27 2002 1a30
-rw-r--r-- 1 0 0 339 Dec 27 2002 1a41
-rw-r--r-- 1 0 0 9358933 Dec 27 2002 1a50
-rw-r--r-- 1 0 0 359 Dec 27 2002 1a71
-rw-r--r-- 1 0 0 7460164 Dec 27 2002 1a80
-rw-r--r-- 1 0 0 364 Dec 27 2002 1a91
-rw-r--r-- 1 0 0 7411683 Dec 27 2002 1aa0
-rw-r--r-- 1 0 0 361 Dec 27 2002 1ab1
-rw-r--r-- 1 0 0 7545019 Dec 27 2002 1ac0
-rw-r--r-- 1 0 0 349 Dec 27 2002 1ad1
-rw-r--r-- 1 0 0 8369555 Dec 27 2002 1ae0
-rw-r--r-- 1 0 0 343 Dec 27 2002 1b01
-rw-r--r-- 1 0 0 11815093 Dec 27 2002 1b10
-rw-r--r-- 1 0 0 341 Dec 27 2002 1b21
-rw-r--r-- 1 0 0 5709501 Dec 27 2002 1b30
-rw-r--r-- 1 0 0 374 Dec 27 2002 1b41
-rw-r--r-- 1 0 0 6042194 Dec 27 2002 1b50
-rw-r--r-- 1 0 0 357 Dec 27 2002 1b61
-rw-r--r-- 1 0 0 6077634 Dec 27 2002 1b70
-rw-r--r-- 1 0 0 355 Dec 27 2002 1b71
-rw-r--r-- 1 0 0 5202708 Dec 27 2002 1ba0
-rw-r--r-- 1 0 0 343 Dec 27 2002 1be1
-rw-r--r-- 1 0 0 6722595 Dec 27 2002 1bf0
-rw-r--r-- 1 0 0 337 Dec 27 2002 1bf1
-rw-r--r-- 1 0 0 7055304 Dec 27 2002 1c00
-rw-r--r-- 1 0 0 325 Dec 27 2002 1c01
-rw-r--r-- 1 0 0 2374222 Dec 27 2002 1c10
-rw-r--r-- 1 0 0 348 Dec 27 2002 1c11
-rw-r--r-- 1 0 0 6925180 Dec 27 2002 1c20
-rw-r--r-- 1 0 0 365 Dec 27 2002 1c31
-rw-r--r-- 1 0 0 9727810 Dec 27 2002 1c60
-rw-r--r-- 1 0 0 342 Dec 27 2002 1c61
-rw-r--r-- 1 0 0 8402417 Dec 27 2002 1c70
-rw-r--r-- 1 0 0 345 Dec 27 2002 1c91
-rw-r--r-- 1 0 0 6869229 Dec 27 2002 1ca0
-rw-r--r-- 1 0 0 358 Dec 27 2002 1ca1
-rw-r--r-- 1 0 0 9588219 Dec 27 2002 1cb0
-rw-r--r-- 1 0 0 323 Dec 27 2002 1cd1
-rw-r--r-- 1 0 0 6779737 Dec 27 2002 1ce0
-rw-r--r-- 1 0 0 347 Dec 27 2002 1cf1
-rw-r--r-- 1 0 0 4179750 Dec 27 2002 1d00
-rw-r--r-- 1 0 0 318 Dec 27 2002 1d01
-rw-r--r-- 1 0 0 1128001 Dec 27 2002 1d30
-rw-r--r-- 1 0 0 329 Dec 27 2002 1d31
-rw-r--r-- 1 0 0 7187901 Dec 27 2002 1d40
-rw-r--r-- 1 0 0 342 Dec 27 2002 1d51
-rw-r--r-- 1 0 0 474736 Dec 27 2002 1d60
-rw-r--r-- 1 0 0 359 Dec 27 2002 1d61
-rw-r--r-- 1 0 0 7127043 Dec 27 2002 1d70
-rw-r--r-- 1 0 0 343 Dec 27 2002 1d81
-rw-r--r-- 1 0 0 6744046 Dec 27 2002 1d90
-rw-r--r-- 1 0 0 361 Dec 27 2002 1da1
-rw-r--r-- 1 0 0 8930324 Dec 27 2002 1db0
-rw-r--r-- 1 0 0 342 Dec 27 2002 1dd1
-rw-r--r-- 1 0 0 459875 Dec 27 2002 1de0
-rw-r--r-- 1 0 0 353 Dec 27 2002 1de1
-rw-r--r-- 1 0 0 9167074 Dec 27 2002 1df0
-rw-r--r-- 1 0 0 332 Dec 27 2002 1e01
-rw-r--r-- 1 0 0 530335 Dec 27 2002 1e10
-rw-r--r-- 1 0 0 354 Dec 27 2002 1e11
-rw-r--r-- 1 0 0 7463887 Dec 27 2002 1e20
-rw-r--r-- 1 0 0 349 Dec 27 2002 1e31
-rw-r--r-- 1 0 0 6401502 Dec 27 2002 1e40
-rw-r--r-- 1 0 0 343 Dec 27 2002 1e51
-rw-r--r-- 1 0 0 157911 Dec 27 2002 1e60
-rw-r--r-- 1 0 0 325 Dec 27 2002 1e61
-rw-r--r-- 1 0 0 5722289 Jan 8 19:39 7760
-rw-r--r-- 1 0 0 372 Dec 27 2002 1ec1
-rw-r--r-- 1 0 0 7364357 Dec 27 2002 1ed0
-rw-r--r-- 1 0 0 320 Dec 27 2002 1ed1
-rw-r--r-- 1 0 0 7033484 Dec 27 2002 1ee0
-rw-r--r-- 1 0 0 328 Dec 27 2002 1ef1
-rw-r--r-- 1 0 0 7248270 Dec 27 2002 1f00
-rw-r--r-- 1 0 0 327 Dec 27 2002 1f11
-rw-r--r-- 1 0 0 6262849 Dec 27 2002 1f20
-rw-r--r-- 1 0 0 350 Dec 27 2002 1f31
-rw-r--r-- 1 0 0 6720452 Dec 27 2002 1f40
-rw-r--r-- 1 0 0 348 Dec 27 2002 1f51
-rw-r--r-- 1 0 0 3858354 Dec 27 2002 1f80
-rw-r--r-- 1 0 0 363 Jan 3 21:01 1f91
-rw-r--r-- 1 0 0 6194271 Dec 27 2002 1fa0
-rw-r--r-- 1 0 0 384 Jan 3 21:01 1fa1
-rw-r--r-- 1 0 0 9053780 Dec 27 2002 1fb0
-rw-r--r-- 1 0 0 371 Jan 3 21:01 1fc1
-rw-r--r-- 1 0 0 11308214 Dec 27 2002 1fd0
-rw-r--r-- 1 0 0 417 Jan 3 21:01 1ff1
-rw-r--r-- 1 0 0 6776690 Dec 27 2002 2000
-rw-r--r-- 1 0 0 406 Jan 3 21:01 2011
-rw-r--r-- 1 0 0 16332375 Dec 27 2002 2020
-rw-r--r-- 1 0 0 361 Dec 27 2002 2091
-rw-r--r-- 1 0 0 11714240 Dec 27 2002 20a0
-rw-r--r-- 1 0 0 355 Dec 27 2002 20c1
-rw-r--r-- 1 0 0 8571686 Dec 27 2002 20d0
-rw-r--r-- 1 0 0 372 Dec 27 2002 20d1
-rw-r--r-- 1 0 0 10925045 Dec 27 2002 20e0
-rw-r--r-- 1 0 0 350 Dec 27 2002 2121
-rw-r--r-- 1 0 0 9105194 Dec 27 2002 2130
-rw-r--r-- 1 0 0 354 Dec 27 2002 2141
-rw-r--r-- 1 0 0 8360370 Dec 27 2002 2150
-rw-r--r-- 1 0 0 353 Dec 27 2002 2151
-rw-r--r-- 1 0 0 11243559 Dec 27 2002 2160
-rw-r--r-- 1 0 0 344 Dec 27 2002 2181
-rw-r--r-- 1 0 0 10559145 Dec 27 2002 2190
-rw-r--r-- 1 0 0 344 Dec 27 2002 21a1
-rw-r--r-- 1 0 0 9594356 Dec 27 2002 21b0
-rw-r--r-- 1 0 0 362 Dec 27 2002 21c1
-rw-r--r-- 1 0 0 9116888 Dec 27 2002 21d0
-rw-r--r-- 1 0 0 379 Dec 27 2002 21e1
-rw-r--r-- 1 0 0 7730320 Dec 27 2002 2200
-rw-r--r-- 1 0 0 336 Dec 27 2002 2211
-rw-r--r-- 1 0 0 8954366 Dec 27 2002 2220
-rw-r--r-- 1 0 0 343 Dec 27 2002 2231
-rw-r--r-- 1 0 0 7770459 Dec 27 2002 2240
-rw-r--r-- 1 0 0 333 Dec 27 2002 2271
-rw-r--r-- 1 0 0 6959595 Dec 27 2002 2280
-rw-r--r-- 1 0 0 327 Dec 27 2002 2291
-rw-r--r-- 1 0 0 7899860 Dec 27 2002 22c0
-rw-r--r-- 1 0 0 373 Dec 27 2002 22d1
-rw-r--r-- 1 0 0 6631678 Dec 27 2002 22e0
-rw-r--r-- 1 0 0 333 Dec 27 2002 2311
-rw-r--r-- 1 0 0 7269233 Dec 27 2002 2320
-rw-r--r-- 1 0 0 339 Dec 27 2002 2331
-rw-r--r-- 1 0 0 7265295 Dec 27 2002 2340
-rw-r--r-- 1 0 0 336 Dec 27 2002 2351
-rw-r--r-- 1 0 0 7180048 Dec 27 2002 2360
-rw-r--r-- 1 0 0 363 Dec 27 2002 2361
-rw-r--r-- 1 0 0 340 Dec 27 2002 2371
-rw-r--r-- 1 0 0 5932919 Dec 27 2002 2380
-rw-r--r-- 1 0 0 385 Dec 27 2002 2381
-rw-r--r-- 1 0 0 6816370 Dec 27 2002 2390
-rw-r--r-- 1 0 0 372 Dec 27 2002 23a1
-rw-r--r-- 1 0 0 6927521 Dec 27 2002 23b0
-rw-r--r-- 1 0 0 344 Dec 27 2002 23c1
-rw-r--r-- 1 0 0 7455266 Dec 27 2002 23d0
-rw-r--r-- 1 0 0 337 Dec 27 2002 23e1
-rw-r--r-- 1 0 0 6384085 Dec 27 2002 23f0
-rw-r--r-- 1 0 0 346 Dec 27 2002 2401
-rw-r--r-- 1 0 0 6851421 Dec 27 2002 2410
-rw-r--r-- 1 0 0 339 Dec 27 2002 2421
-rw-r--r-- 1 0 0 9208055 Dec 27 2002 2430
-rw-r--r-- 1 0 0 340 Dec 27 2002 2441
-rw-r--r-- 1 0 0 6535926 Dec 27 2002 2450
-rw-r--r-- 1 0 0 350 Dec 27 2002 2461
-rw-r--r-- 1 0 0 6354354 Dec 27 2002 2470
-rw-r--r-- 1 0 0 342 Dec 27 2002 2471
-rw-r--r-- 1 0 0 7104092 Dec 27 2002 2480
-rw-r--r-- 1 0 0 354 Dec 27 2002 2491
-rw-r--r-- 1 0 0 7671080 Dec 27 2002 24a0
-rw-r--r-- 1 0 0 336 Dec 27 2002 24b1
-rw-r--r-- 1 0 0 5907299 Dec 27 2002 24c0
-rw-r--r-- 1 0 0 369 Dec 27 2002 24d1
-rw-r--r-- 1 0 0 6209625 Dec 27 2002 24e0
-rw-r--r-- 1 0 0 338 Dec 27 2002 24f1
-rw-r--r-- 1 0 0 6116182 Dec 27 2002 2500
-rw-r--r-- 1 0 0 358 Dec 27 2002 2511
-rw-r--r-- 1 0 0 6069172 Dec 27 2002 2520
-rw-r--r-- 1 0 0 339 Dec 27 2002 2531
-rw-r--r-- 1 0 0 8078540 Dec 27 2002 2540
-rw-r--r-- 1 0 0 311 Dec 27 2002 2571
-rw-r--r-- 1 0 0 6677566 Dec 27 2002 2580
-rw-r--r-- 1 0 0 323 Dec 27 2002 2591
-rw-r--r-- 1 0 0 5549021 Dec 27 2002 25a0
-rw-r--r-- 1 0 0 320 Dec 27 2002 25b1
-rw-r--r-- 1 0 0 9129525 Dec 27 2002 25c0
-rw-r--r-- 1 0 0 323 Dec 27 2002 25e1
-rw-r--r-- 1 0 0 8820304 Dec 27 2002 25f0
-rw-r--r-- 1 0 0 328 Dec 27 2002 2601
-rw-r--r-- 1 0 0 5252628 Dec 27 2002 2630
-rw-r--r-- 1 0 0 328 Dec 27 2002 2641
-rw-r--r-- 1 0 0 8678343 Dec 27 2002 2650
-rw-r--r-- 1 0 0 316 Dec 27 2002 2661
-rw-r--r-- 1 0 0 5972714 Dec 27 2002 2670
-rw-r--r-- 1 0 0 371 Dec 27 2002 2681
-rw-r--r-- 1 0 0 6820793 Dec 27 2002 2690
-rw-r--r-- 1 0 0 370 Dec 27 2002 26a1
-rw-r--r-- 1 0 0 6559577 Dec 27 2002 26b0
-rw-r--r-- 1 0 0 378 Dec 27 2002 26c1
-rw-r--r-- 1 0 0 7121146 Dec 27 2002 26d0
-rw-r--r-- 1 0 0 371 Dec 27 2002 26e1
-rw-r--r-- 1 0 0 4648012 Dec 27 2002 26f0
-rw-r--r-- 1 0 0 388 Dec 27 2002 26f1
-rw-r--r-- 1 0 0 6655240 Dec 27 2002 2700
-rw-r--r-- 1 0 0 371 Dec 27 2002 2721
-rw-r--r-- 1 0 0 8135514 Dec 27 2002 2730
-rw-r--r-- 1 0 0 385 Dec 27 2002 2741
-rw-r--r-- 1 0 0 5580080 Dec 27 2002 2770
-rw-r--r-- 1 0 0 367 Dec 27 2002 2781
-rw-r--r-- 1 0 0 5046646 Dec 27 2002 2790
-rw-r--r-- 1 0 0 474 Dec 27 2002 27a1
-rw-r--r-- 1 0 0 8443376 Dec 27 2002 27b0
-rw-r--r-- 1 0 0 373 Dec 27 2002 27e1
-rw-r--r-- 1 0 0 7131148 Dec 27 2002 27f0
-rw-r--r-- 1 0 0 365 Dec 27 2002 2801
-rw-r--r-- 1 0 0 6099429 Dec 27 2002 2810
-rw-r--r-- 1 0 0 419 Dec 27 2002 2811
-rw-r--r-- 1 0 0 375 Dec 27 2002 2821
-rw-r--r-- 1 0 0 5165719 Dec 27 2002 2840
-rw-r--r-- 1 0 0 346 Dec 27 2002 2841
-rw-r--r-- 1 0 0 6406440 Dec 27 2002 2850
-rw-r--r-- 1 0 0 380 Dec 27 2002 2861
-rw-r--r-- 1 0 0 6051484 Dec 27 2002 2870
-rw-r--r-- 1 0 0 312 Dec 27 2002 2881
-rw-r--r-- 1 0 0 6859677 Dec 27 2002 2890
-rw-r--r-- 1 0 0 315 Dec 27 2002 28a1
-rw-r--r-- 1 0 0 8939863 Dec 27 2002 28b0
-rw-r--r-- 1 0 0 327 Dec 27 2002 28d1
-rw-r--r-- 1 0 0 6739225 Dec 27 2002 28e0
-rw-r--r-- 1 0 0 326 Dec 27 2002 28f1
-rw-r--r-- 1 0 0 4 Dec 27 2002 2550
-rw-r--r-- 1 0 0 39 Dec 27 2002 2551
-rw-r--r-- 1 0 0 40 Jan 3 09:03 2560
-rw-r--r-- 1 0 0 40 Jan 3 09:03 2561
-rw-r--r-- 1 0 0 4 Dec 27 2002 2610
-rw-r--r-- 1 0 0 45 Dec 27 2002 2611
-rw-r--r-- 1 0 0 72 Dec 27 2002 2620
-rw-r--r-- 1 0 0 58 Dec 27 2002 2621
-rw-r--r-- 1 0 0 381 Jan 14 21:22 8461
-rw-r--r-- 1 0 0 329 Dec 27 2002 2a51
-rw-r--r-- 1 0 0 32 Dec 27 2002 2760
-rw-r--r-- 1 0 0 60 Dec 27 2002 2761
-rw-r--r-- 1 0 0 4 Dec 27 2002 27c0
-rw-r--r-- 1 0 0 42 Dec 27 2002 27c1
-rw-r--r-- 1 0 0 12 Jan 3 20:29 27d0
-rw-r--r-- 1 0 0 53 Jan 3 20:29 27d1
-rw-r--r-- 1 0 0 32 Dec 27 2002 2830
-rw-r--r-- 1 0 0 42 Dec 27 2002 2831
-rw-r--r-- 1 0 0 5484815 Dec 27 2002 2920
-rw-r--r-- 1 0 0 393 Dec 27 2002 2921
-rw-r--r-- 1 0 0 4 Dec 27 2002 2900
-rw-r--r-- 1 0 0 46 Dec 27 2002 2901
-rw-r--r-- 1 0 0 8 Dec 30 2002 2910
-rw-r--r-- 1 0 0 57 Dec 30 2002 2911
-rw-r--r-- 1 0 0 5609657 Dec 27 2002 2940
-rw-r--r-- 1 0 0 316 Dec 27 2002 2951
-rw-r--r-- 1 0 0 5447697 Dec 27 2002 2960
-rw-r--r-- 1 0 0 315 Dec 30 2002 2971
-rw-r--r-- 1 0 0 5143631 Dec 27 2002 2980
-rw-r--r-- 1 0 0 318 Dec 27 2002 2991
-rw-r--r-- 1 0 0 28 Jan 28 19:27 2930
-rw-r--r-- 1 0 0 78 Jan 28 19:27 2931
-rw-r--r-- 1 0 0 4902268 Dec 27 2002 29b0
-rw-r--r-- 1 0 0 334 Dec 27 2002 29c1
-rw-r--r-- 1 0 0 12948314 Dec 27 2002 29d0
-rw-r--r-- 1 0 0 326 Dec 27 2002 29f1
-rw-r--r-- 1 0 0 7179271 Dec 27 2002 2a00
-rw-r--r-- 1 0 0 345 Dec 27 2002 2a11
-rw-r--r-- 1 0 0 7193313 Dec 27 2002 2a20
-rw-r--r-- 1 0 0 336 Dec 27 2002 2a31
-rw-r--r-- 1 0 0 10285194 Dec 27 2002 2a40
-rw-r--r-- 1 0 0 338 Dec 27 2002 2a71
-rw-r--r-- 1 0 0 44 Dec 27 2002 29a0
-rw-r--r-- 1 0 0 36 Dec 27 2002 29a1
-rw-r--r-- 1 0 0 13230740 Dec 27 2002 2a90
-rw-r--r-- 1 0 0 385 Dec 27 2002 2aa1
-rw-r--r-- 1 0 0 27672392 Dec 27 2002 2ab0
-rw-r--r-- 1 0 0 386 Dec 27 2002 2ad1
-rw-r--r-- 1 0 0 15237162 Dec 27 2002 2b00
-rw-r--r-- 1 0 0 454 Jan 6 10:50 2b01
-rw-r--r-- 1 0 0 15702351 Dec 27 2002 2b10
-rw-r--r-- 1 0 0 420 Jan 6 10:50 2b31
-rw-r--r-- 1 0 0 26038691 Dec 27 2002 2b40
-rw-r--r-- 1 0 0 462 Jan 6 10:50 2b51
-rw-r--r-- 1 0 0 96 Mar 7 21:56 2a80
-rw-r--r-- 1 0 0 81 Mar 7 21:56 2a81
-rw-r--r-- 1 0 0 24 Dec 27 2002 2ae0
-rw-r--r-- 1 0 0 36 Dec 27 2002 2ae1
-rw-r--r-- 1 0 0 3283865 Dec 27 2002 2b60
-rw-r--r-- 1 0 0 359 Dec 27 2002 2b61
-rw-r--r-- 1 0 0 11386219 Dec 27 2002 2b70
-rw-r--r-- 1 0 0 366 Dec 27 2002 2b71
-rw-r--r-- 1 0 0 6282133 Dec 27 2002 2b80
-rw-r--r-- 1 0 0 387 Dec 27 2002 2b91
-rw-r--r-- 1 0 0 8799833 Dec 27 2002 2ba0
-rw-r--r-- 1 0 0 359 Dec 27 2002 2ba1
-rw-r--r-- 1 0 0 3864897 Dec 27 2002 2bb0
-rw-r--r-- 1 0 0 396 Dec 27 2002 2bc1
-rw-r--r-- 1 0 0 6958480 Dec 27 2002 2bd0
-rw-r--r-- 1 0 0 372 Dec 27 2002 2be1
-rw-r--r-- 1 0 0 8134463 Dec 27 2002 2c00
-rw-r--r-- 1 0 0 345 Dec 27 2002 2c21
-rw-r--r-- 1 0 0 8503285 Dec 27 2002 2c30
-rw-r--r-- 1 0 0 350 Dec 27 2002 2c41
-rw-r--r-- 1 0 0 7048706 Dec 27 2002 2c50
-rw-r--r-- 1 0 0 338 Dec 27 2002 2c51
-rw-r--r-- 1 0 0 8059058 Dec 27 2002 2c60
-rw-r--r-- 1 0 0 334 Dec 27 2002 2c81
-rw-r--r-- 1 0 0 7953223 Dec 27 2002 2c90
-rw-r--r-- 1 0 0 357 Dec 27 2002 2ca1
-rw-r--r-- 1 0 0 6909947 Dec 27 2002 2cb0
-rw-r--r-- 1 0 0 347 Dec 27 2002 2cb1
-rw-r--r-- 1 0 0 6807276 Dec 27 2002 2ce0
-rw-r--r-- 1 0 0 342 Dec 27 2002 2d01
-rw-r--r-- 1 0 0 6687348 Dec 27 2002 2d10
-rw-r--r-- 1 0 0 344 Dec 27 2002 2d11
-rw-r--r-- 1 0 0 5151482 Dec 27 2002 2d20
-rw-r--r-- 1 0 0 323 Dec 27 2002 2d31
-rw-r--r-- 1 0 0 6958362 Dec 27 2002 2d40
-rw-r--r-- 1 0 0 345 Dec 27 2002 2d51
-rw-r--r-- 1 0 0 7830742 Dec 27 2002 2d60
-rw-r--r-- 1 0 0 371 Dec 27 2002 2d91
-rw-r--r-- 1 0 0 281349 Dec 27 2002 2da0
-rw-r--r-- 1 0 0 338 Dec 27 2002 2da1
-rw-r--r-- 1 0 0 7923680 Dec 27 2002 2db0
-rw-r--r-- 1 0 0 326 Dec 27 2002 2dd1
-rw-r--r-- 1 0 0 72460 Dec 27 2002 2de0
-rw-r--r-- 1 0 0 326 Dec 27 2002 2de1
-rw-r--r-- 1 0 0 9841713 Dec 27 2002 2df0
-rw-r--r-- 1 0 0 335 Dec 27 2002 2e11
-rw-r--r-- 1 0 0 6589709 Dec 27 2002 2e20
-rw-r--r-- 1 0 0 352 Dec 27 2002 2e41
-rw-r--r-- 1 0 0 177800 Dec 27 2002 2e50
-rw-r--r-- 1 0 0 332 Dec 27 2002 2e51
-rw-r--r-- 1 0 0 6209075 Dec 27 2002 2e60
-rw-r--r-- 1 0 0 354 Dec 27 2002 2e81
-rw-r--r-- 1 0 0 229235 Dec 27 2002 2e90
-rw-r--r-- 1 0 0 328 Dec 27 2002 2e91
-rw-r--r-- 1 0 0 4827896 Dec 27 2002 2ea0
-rw-r--r-- 1 0 0 357 Dec 27 2002 2ec1
-rw-r--r-- 1 0 0 260428 Dec 27 2002 2ed0
-rw-r--r-- 1 0 0 345 Dec 27 2002 2ed1
-rw-r--r-- 1 0 0 7936568 Dec 27 2002 2ee0
-rw-r--r-- 1 0 0 362 Dec 27 2002 2f01
-rw-r--r-- 1 0 0 2311278 Dec 27 2002 2f10
-rw-r--r-- 1 0 0 355 Dec 27 2002 2f11
-rw-r--r-- 1 0 0 7878639 Dec 27 2002 2f20
-rw-r--r-- 1 0 0 389 Dec 27 2002 2f41
-rw-r--r-- 1 0 0 9619718 Dec 27 2002 2f50
-rw-r--r-- 1 0 0 403 Dec 27 2002 2f61
-rw-r--r-- 1 0 0 4937087 Dec 27 2002 2f70
-rw-r--r-- 1 0 0 395 Dec 27 2002 2f81
-rw-r--r-- 1 0 0 7142515 Dec 27 2002 2f90
-rw-r--r-- 1 0 0 397 Dec 27 2002 2f91
-rw-r--r-- 1 0 0 5337551 Dec 27 2002 2fa0
-rw-r--r-- 1 0 0 383 Dec 27 2002 2fb1
-rw-r--r-- 1 0 0 8378573 Dec 27 2002 2fc0
-rw-r--r-- 1 0 0 4736723 Dec 27 2002 3010
-rw-r--r-- 1 0 0 305 Dec 30 2002 3011
-rw-r--r-- 1 0 0 7277634 Dec 27 2002 3020
-rw-r--r-- 1 0 0 413 Dec 27 2002 3041
-rw-r--r-- 1 0 0 9650187 Dec 27 2002 3050
-rw-r--r-- 1 0 0 320 Dec 27 2002 3061
-rw-r--r-- 1 0 0 7702389 Dec 27 2002 3070
-rw-r--r-- 1 0 0 363 Dec 27 2002 3091
-rw-r--r-- 1 0 0 3943050 Dec 27 2002 30a0
-rw-r--r-- 1 0 0 334 Dec 27 2002 30a1
-rw-r--r-- 1 0 0 10621470 Dec 27 2002 30b0
-rw-r--r-- 1 0 0 352 Dec 30 2002 30d1
-rw-r--r-- 1 0 0 8814887 Dec 27 2002 30e0
-rw-r--r-- 1 0 0 5226496 Dec 28 2002 3380
-rw-r--r-- 1 0 0 8314381 Dec 27 2002 3100
-rw-r--r-- 1 0 0 342 Dec 28 2002 3381
-rw-r--r-- 1 0 0 10726486 Dec 27 2002 3120
-rw-r--r-- 1 0 0 331 Dec 27 2002 3131
-rw-r--r-- 1 0 0 6418244 Dec 27 2002 3140
-rw-r--r-- 1 0 0 306 Dec 27 2002 3141
-rw-r--r-- 1 0 0 9338880 Dec 27 2002 3150
-rw-r--r-- 1 0 0 353 Dec 27 2002 3161
-rw-r--r-- 1 0 0 10309632 Dec 27 2002 3170
-rw-r--r-- 1 0 0 443 Dec 27 2002 3181
-rw-r--r-- 1 0 0 8746880 Dec 28 2002 33c0
-rw-r--r-- 1 0 0 333 Dec 27 2002 31a1
-rw-r--r-- 1 0 0 9396266 Dec 27 2002 31b0
-rw-r--r-- 1 0 0 444 Dec 27 2002 31c1
-rw-r--r-- 1 0 0 8168514 Dec 27 2002 31d0
-rw-r--r-- 1 0 0 440 Dec 27 2002 31e1
-rw-r--r-- 1 0 0 6946087 Dec 27 2002 31f0
-rw-r--r-- 1 0 0 428 Dec 27 2002 3201
-rw-r--r-- 1 0 0 8222277 Dec 28 2002 3210
-rw-r--r-- 1 0 0 343 Jan 3 19:36 3221
-rw-r--r-- 1 0 0 10052963 Dec 27 2002 3230
-rw-r--r-- 1 0 0 375 Dec 27 2002 3241
-rw-r--r-- 1 0 0 13191545 Dec 27 2002 3250
-rw-r--r-- 1 0 0 341 Dec 27 2002 3281
-rw-r--r-- 1 0 0 8922978 Dec 27 2002 3290
-rw-r--r-- 1 0 0 326 Jan 3 10:30 32a1
-rw-r--r-- 1 0 0 383 Dec 27 2002 32b1
-rw-r--r-- 1 0 0 4058132 Dec 27 2002 32c0
-rw-r--r-- 1 0 0 432 Dec 27 2002 32c1
-rw-r--r-- 1 0 0 300 Dec 27 2002 32d1
-rw-r--r-- 1 0 0 7791737 Dec 27 2002 32e0
-rw-r--r-- 1 0 0 416 Dec 27 2002 32f1
-rw-r--r-- 1 0 0 6580224 Dec 27 2002 3300
-rw-r--r-- 1 0 0 345 Dec 27 2002 3311
-rw-r--r-- 1 0 0 10724657 Dec 27 2002 3320
-rw-r--r-- 1 0 0 434 Dec 27 2002 3331
-rw-r--r-- 1 0 0 11072561 Dec 27 2002 3340
-rw-r--r-- 1 0 0 375 Dec 27 2002 3351
-rw-r--r-- 1 0 0 8 Mar 7 21:56 db0
-rw-r--r-- 1 0 0 383 Dec 27 2002 3371
-rw-r--r-- 1 0 0 385 Dec 28 2002 3401
-rw-r--r-- 1 0 0 437 Dec 27 2002 33a1
-rw-r--r-- 1 0 0 10771749 Dec 27 2002 33b0
-rw-r--r-- 1 0 0 10306874 Dec 28 2002 3c50
-rw-r--r-- 1 0 0 3491759 Dec 27 2002 33d0
-rw-r--r-- 1 0 0 295 Dec 27 2002 33d1
-rw-r--r-- 1 0 0 5208734 Dec 27 2002 33e0
-rw-r--r-- 1 0 0 381 Dec 27 2002 33e1
-rw-r--r-- 1 0 0 6783019 Dec 27 2002 33f0
-rw-r--r-- 1 0 0 403 Dec 28 2002 3c71
-rw-r--r-- 1 0 0 10841983 Dec 27 2002 3410
-rw-r--r-- 1 0 0 348 Dec 27 2002 3421
-rw-r--r-- 1 0 0 6338444 Dec 27 2002 3430
-rw-r--r-- 1 0 0 415 Dec 27 2002 3441
-rw-r--r-- 1 0 0 6019327 Dec 27 2002 3450
-rw-r--r-- 1 0 0 376 Dec 27 2002 3451
-rw-r--r-- 1 0 0 5616704 Dec 27 2002 3460
-rw-r--r-- 1 0 0 314 Dec 27 2002 3471
-rw-r--r-- 1 0 0 7773647 Dec 27 2002 3480
-rw-r--r-- 1 0 0 357 Dec 27 2002 3481
-rw-r--r-- 1 0 0 11274062 Dec 27 2002 3490
-rw-r--r-- 1 0 0 392 Dec 27 2002 34a1
-rw-r--r-- 1 0 0 14996367 Dec 27 2002 34b0
-rw-r--r-- 1 0 0 321 Dec 30 2002 34d1
-rw-r--r-- 1 0 0 7067648 Dec 27 2002 34e0
-rw-r--r-- 1 0 0 319 Dec 27 2002 34e1
-rw-r--r-- 1 0 0 7908332 Dec 27 2002 34f0
-rw-r--r-- 1 0 0 313 Dec 27 2002 3501
-rw-r--r-- 1 0 0 8713948 Dec 27 2002 3510
-rw-r--r-- 1 0 0 342 Dec 27 2002 3541
-rw-r--r-- 1 0 0 6379520 Dec 27 2002 3550
-rw-r--r-- 1 0 0 334 Dec 27 2002 3551
-rw-r--r-- 1 0 0 4558848 Dec 27 2002 3560
-rw-r--r-- 1 0 0 7172096 Dec 27 2002 3580
-rw-r--r-- 1 0 0 323 Dec 27 2002 35a1
-rw-r--r-- 1 0 0 6602752 Dec 27 2002 35b0
-rw-r--r-- 1 0 0 324 Dec 27 2002 35c1
-rw-r--r-- 1 0 0 5601280 Dec 27 2002 35e0
-rw-r--r-- 1 0 0 319 Dec 27 2002 35f1
-rw-r--r-- 1 0 0 5888000 Dec 27 2002 3600
-rw-r--r-- 1 0 0 371 Dec 27 2002 3611
-rw-r--r-- 1 0 0 3198976 Dec 27 2002 3620
-rw-r--r-- 1 0 0 332 Dec 27 2002 3631
-rw-r--r-- 1 0 0 2580480 Dec 27 2002 3640
-rw-r--r-- 1 0 0 345 Dec 27 2002 3641
-rw-r--r-- 1 0 0 4878336 Dec 27 2002 3650
-rw-r--r-- 1 0 0 329 Dec 27 2002 3661
-rw-r--r-- 1 0 0 5433344 Dec 27 2002 3670
-rw-r--r-- 1 0 0 383 Dec 27 2002 3681
-rw-r--r-- 1 0 0 7618560 Dec 27 2002 36a0
-rw-r--r-- 1 0 0 335 Dec 27 2002 36c1
-rw-r--r-- 1 0 0 6217728 Dec 27 2002 36d0
-rw-r--r-- 1 0 0 338 Dec 27 2002 36d1
-rw-r--r-- 1 0 0 6221824 Dec 27 2002 36e0
-rw-r--r-- 1 0 0 324 Dec 27 2002 3701
-rw-r--r-- 1 0 0 6193152 Dec 27 2002 3710
-rw-r--r-- 1 0 0 311 Dec 27 2002 3721
-rw-r--r-- 1 0 0 4724736 Dec 27 2002 3730
-rw-r--r-- 1 0 0 316 Dec 27 2002 3741
-rw-r--r-- 1 0 0 4952064 Dec 27 2002 3760
-rw-r--r-- 1 0 0 342 Dec 27 2002 3771
-rw-r--r-- 1 0 0 5369856 Dec 27 2002 3780
-rw-r--r-- 1 0 0 342 Dec 27 2002 3791
-rw-r--r-- 1 0 0 7290880 Dec 27 2002 37a0
-rw-r--r-- 1 0 0 351 Dec 27 2002 37b1
-rw-r--r-- 1 0 0 4759552 Dec 27 2002 37c0
-rw-r--r-- 1 0 0 348 Dec 27 2002 37d1
-rw-r--r-- 1 0 0 4796416 Dec 27 2002 37e0
-rw-r--r-- 1 0 0 371 Dec 27 2002 37f1
-rw-r--r-- 1 0 0 4581376 Dec 27 2002 3810
-rw-r--r-- 1 0 0 355 Dec 27 2002 3811
-rw-r--r-- 1 0 0 5877760 Dec 27 2002 3820
-rw-r--r-- 1 0 0 350 Dec 27 2002 3831
-rw-r--r-- 1 0 0 6178816 Dec 27 2002 3840
-rw-r--r-- 1 0 0 356 Dec 27 2002 3851
-rw-r--r-- 1 0 0 7671808 Dec 27 2002 3860
-rw-r--r-- 1 0 0 374 Dec 27 2002 3881
-rw-r--r-- 1 0 0 4556800 Dec 27 2002 3890
-rw-r--r-- 1 0 0 374 Dec 27 2002 38a1
-rw-r--r-- 1 0 0 8970240 Dec 27 2002 38b0
-rw-r--r-- 1 0 0 345 Dec 27 2002 38d1
-rw-r--r-- 1 0 0 4403200 Dec 27 2002 38e0
-rw-r--r-- 1 0 0 349 Dec 27 2002 38f1
-rw-r--r-- 1 0 0 5111808 Dec 27 2002 3900
-rw-r--r-- 1 0 0 333 Dec 27 2002 3901
-rw-r--r-- 1 0 0 6576128 Dec 27 2002 3930
-rw-r--r-- 1 0 0 343 Dec 27 2002 3941
-rw-r--r-- 1 0 0 4939776 Dec 27 2002 3950
-rw-r--r-- 1 0 0 325 Dec 27 2002 3961
-rw-r--r-- 1 0 0 5812224 Dec 27 2002 3970
-rw-r--r-- 1 0 0 348 Dec 27 2002 3981
-rw-r--r-- 1 0 0 4487168 Dec 27 2002 3990
-rw-r--r-- 1 0 0 345 Dec 27 2002 3991
-rw-r--r-- 1 0 0 6520832 Dec 27 2002 39a0
-rw-r--r-- 1 0 0 349 Dec 27 2002 39b1
-rw-r--r-- 1 0 0 5744640 Dec 27 2002 39c0
-rw-r--r-- 1 0 0 347 Dec 27 2002 39e1
-rw-r--r-- 1 0 0 4292608 Dec 27 2002 3a10
-rw-r--r-- 1 0 0 335 Dec 27 2002 3a21
-rw-r--r-- 1 0 0 5715968 Dec 27 2002 3a30
-rw-r--r-- 1 0 0 344 Dec 27 2002 3a41
-rw-r--r-- 1 0 0 5396480 Dec 27 2002 3a50
-rw-r--r-- 1 0 0 348 Dec 27 2002 3a61
-rw-r--r-- 1 0 0 5468160 Dec 27 2002 3a70
-rw-r--r-- 1 0 0 350 Dec 27 2002 3a71
-rw-r--r-- 1 0 0 6760448 Dec 27 2002 3a80
-rw-r--r-- 1 0 0 350 Dec 27 2002 3aa1
-rw-r--r-- 1 0 0 6488064 Dec 27 2002 3ab0
-rw-r--r-- 1 0 0 343 Dec 27 2002 3ad1
-rw-r--r-- 1 0 0 5605376 Dec 27 2002 3ae0
-rw-r--r-- 1 0 0 352 Dec 27 2002 3ae1
-rw-r--r-- 1 0 0 6494208 Dec 27 2002 3af0
-rw-r--r-- 1 0 0 347 Dec 27 2002 3b01
-rw-r--r-- 1 0 0 5197824 Dec 27 2002 3b10
-rw-r--r-- 1 0 0 384 Dec 27 2002 3b21
-rw-r--r-- 1 0 0 7350272 Dec 27 2002 3b30
-rw-r--r-- 1 0 0 398 Dec 27 2002 3b41
-rw-r--r-- 1 0 0 6031360 Dec 27 2002 3b50
-rw-r--r-- 1 0 0 5042176 Dec 27 2002 3b70
-rw-r--r-- 1 0 0 335 Dec 27 2002 3b81
-rw-r--r-- 1 0 0 5959680 Dec 27 2002 3b90
-rw-r--r-- 1 0 0 374 Dec 27 2002 3ba1
-rw-r--r-- 1 0 0 128 Mar 7 21:56 3000
-rw-r--r-- 1 0 0 79 Mar 7 21:56 3001
-rw-r--r-- 1 0 0 64 Feb 14 09:57 3030
-rw-r--r-- 1 0 0 78 Feb 14 09:57 3031
-rw-r--r-- 1 0 0 36 Dec 27 2002 3530
-rw-r--r-- 1 0 0 42 Dec 27 2002 3531
-rw-r--r-- 1 0 0 44 Dec 27 2002 35d0
-rw-r--r-- 1 0 0 42 Dec 27 2002 35d1
-rw-r--r-- 1 0 0 44 Dec 27 2002 3690
-rw-r--r-- 1 0 0 38 Dec 27 2002 3691
-rw-r--r-- 1 0 0 40 Dec 27 2002 3750
-rw-r--r-- 1 0 0 50 Dec 27 2002 3751
-rw-r--r-- 1 0 0 64 Dec 27 2002 3800
-rw-r--r-- 1 0 0 47 Dec 27 2002 3801
-rw-r--r-- 1 0 0 4 Dec 27 2002 3910
-rw-r--r-- 1 0 0 42 Dec 27 2002 3911
-rw-r--r-- 1 0 0 48 Dec 27 2002 3920
-rw-r--r-- 1 0 0 38 Dec 27 2002 3921
-rw-r--r-- 1 0 0 16 Jan 7 20:41 39f0
-rw-r--r-- 1 0 0 38 Jan 7 20:41 39f1
-rw-r--r-- 1 0 0 44 Dec 27 2002 3a00
-rw-r--r-- 1 0 0 46 Dec 27 2002 3a01
-rw-r--r-- 1 0 0 56 Dec 27 2002 3ac0
-rw-r--r-- 1 0 0 52 Dec 27 2002 3ac1
-rw-r--r-- 1 0 0 7843004 Dec 27 2002 240
-rw-r--r-- 1 0 0 365 Dec 27 2002 3bc1
-rw-r--r-- 1 0 0 6350848 Dec 27 2002 3bd0
-rw-r--r-- 1 0 0 331 Dec 27 2002 3be1
-rw-r--r-- 1 0 0 5222400 Dec 27 2002 3bf0
-rw-r--r-- 1 0 0 363 Dec 27 2002 3c01
-rw-r--r-- 1 0 0 6633472 Dec 27 2002 3c10
-rw-r--r-- 1 0 0 363 Dec 27 2002 3c21
-rw-r--r-- 1 0 0 6381568 Dec 27 2002 3c30
-rw-r--r-- 1 0 0 362 Dec 27 2002 3c41
-rw-r--r-- 1 0 0 4 Dec 27 2002 7c0
-rw-r--r-- 1 0 0 43 Dec 27 2002 7c1
-rw-r--r-- 1 0 0 40 Dec 27 2002 890
-rw-r--r-- 1 0 0 37 Dec 27 2002 891
-rw-r--r-- 1 0 0 11940803 Dec 28 2002 3c80
-rw-r--r-- 1 0 0 439 Dec 27 2002 3c61
-rw-r--r-- 1 0 0 11055234 Dec 28 2002 4040
-rw-r--r-- 1 0 0 437 Dec 28 2002 4041
-rw-r--r-- 1 0 0 9633638 Dec 27 2002 3c90
-rw-r--r-- 1 0 0 398 Dec 27 2002 3ca1
-rw-r--r-- 1 0 0 12331927 Dec 28 2002 3cb0
-rw-r--r-- 1 0 0 373 Dec 28 2002 3cc1
-rw-r--r-- 1 0 0 8893796 Dec 28 2002 3cd0
-rw-r--r-- 1 0 0 353 Dec 28 2002 3ce1
-rw-r--r-- 1 0 0 22786760 Dec 28 2002 3cf0
-rw-r--r-- 1 0 0 382 Dec 28 2002 3d01
-rw-r--r-- 1 0 0 432 Dec 28 2002 4051
-rw-r--r-- 1 0 0 388 Dec 29 2002 40e1
-rw-r--r-- 1 0 0 336 Dec 28 2002 3211
-rw-r--r-- 1 0 0 381 Dec 28 2002 3d21
-rw-r--r-- 1 0 0 10201088 Dec 28 2002 3d50
-rw-r--r-- 1 0 0 394 Dec 28 2002 3d61
-rw-r--r-- 1 0 0 6651904 Dec 28 2002 3d70
-rw-r--r-- 1 0 0 406 Dec 28 2002 3d81
-rw-r--r-- 1 0 0 12664832 Dec 28 2002 3d90
-rw-r--r-- 1 0 0 451 Dec 28 2002 3da1
-rw-r--r-- 1 0 0 6754304 Dec 28 2002 3db0
-rw-r--r-- 1 0 0 407 Dec 28 2002 3dc1
-rw-r--r-- 1 0 0 5050368 Dec 28 2002 3dd0
-rw-r--r-- 1 0 0 399 Dec 28 2002 3de1
-rw-r--r-- 1 0 0 8194048 Dec 28 2002 3df0
-rw-r--r-- 1 0 0 327 Dec 28 2002 3e21
-rw-r--r-- 1 0 0 5750523 Dec 28 2002 3e30
-rw-r--r-- 1 0 0 4808438 Dec 28 2002 3e50
-rw-r--r-- 1 0 0 328 Dec 28 2002 3e71
-rw-r--r-- 1 0 0 9549824 Dec 28 2002 3e80
-rw-r--r-- 1 0 0 337 Dec 28 2002 3ea1
-rw-r--r-- 1 0 0 4319429 Dec 28 2002 3eb0
-rw-r--r-- 1 0 0 320 Dec 28 2002 3eb1
-rw-r--r-- 1 0 0 7837912 Dec 28 2002 3ec0
-rw-r--r-- 1 0 0 313 Dec 28 2002 3ee1
-rw-r--r-- 1 0 0 4134794 Dec 28 2002 3ef0
-rw-r--r-- 1 0 0 344 Jan 3 21:01 3f01
-rw-r--r-- 1 0 0 7048520 Dec 28 2002 3f10
-rw-r--r-- 1 0 0 328 Jan 3 21:01 3f21
-rw-r--r-- 1 0 0 9050007 Dec 28 2002 3f30
-rw-r--r-- 1 0 0 362 Jan 3 21:01 3f41
-rw-r--r-- 1 0 0 7870842 Dec 28 2002 3f50
-rw-r--r-- 1 0 0 346 Jan 3 21:01 3f71
-rw-r--r-- 1 0 0 5563171 Dec 28 2002 3f80
-rw-r--r-- 1 0 0 354 Jan 3 21:01 3f81
-rw-r--r-- 1 0 0 7717239 Dec 28 2002 3f90
-rw-r--r-- 1 0 0 350 Dec 28 2002 3fe1
-rw-r--r-- 1 0 0 14950132 Dec 28 2002 3ff0
-rw-r--r-- 1 0 0 348 Dec 28 2002 3ff1
-rw-r--r-- 1 0 0 349 Dec 28 2002 4001
-rw-r--r-- 1 0 0 21316552 Dec 28 2002 4010
-rw-r--r-- 1 0 0 349 Dec 28 2002 4021
-rw-r--r-- 1 0 0 16531408 Dec 28 2002 4030
-rw-r--r-- 1 0 0 348 Dec 28 2002 4031
-rw-r--r-- 1 0 0 20 Dec 28 2002 3fb0
-rw-r--r-- 1 0 0 80 Dec 28 2002 3fb1
-rw-r--r-- 1 0 0 24 Dec 28 2002 3fc0
-rw-r--r-- 1 0 0 78 Dec 28 2002 3fc1
-rw-r--r-- 1 0 0 24 Dec 28 2002 3fd0
-rw-r--r-- 1 0 0 85 Dec 28 2002 3fd1
-rw-r--r-- 1 0 0 9606098 Dec 29 2002 40f0
-rw-r--r-- 1 0 0 13427276 Dec 28 2002 4070
-rw-r--r-- 1 0 0 371 Dec 28 2002 4091
-rw-r--r-- 1 0 0 7823360 Dec 28 2002 40a0
-rw-r--r-- 1 0 0 390 Dec 28 2002 40a1
-rw-r
#151232 - 29/03/2003 15:15 Re: Playlists disappeared [Re: tfabris]
dinkum
Loc: ca, usa
Tony, I have beta13 version. Do I still need to look into the config.ini. If so, how do I get into config.ini because Jemplode doesn't work for me any longer?
#151233 - 29/03/2003 15:24 Re: Playlists disappeared [Re: dinkum]
Good. Lots of music still on the two drives. Someone else can take it from here.
Tony?
#151234 - 29/03/2003 16:13 Re: Playlists disappeared [Re: dinkum]
Your root playlist has only one entry (which may be junk). Empeg Emplode detects all the unattached playlists and adds them back to the root again -- looks like Jemplode doesn't do this. Is it possible for you to run Emplode?
#151235 - 30/03/2003 12:44 Re: Playlists disappeared [Re: dinkum]
Beta 13 prevents that funky bug from happening, but it doesn't correct the mangled list after-the-fact. You would only have that problem if you were running beta 11 before this and messed with the favorite visuals in that version.
But that's probably not what's happening. Like the man said, the reason this is happening is because your root playlist is hosed for some reason. My thing about checking for the beta-11 bug was just a stab in the dark.
#151236 - 30/03/2003 13:09 Re: Playlists disappeared [Re: tfabris]
dinkum
Loc: ca, usa
What Peter suggested did the trick!!! You guys are tight.
THANK YOU VERY MUCH
#151237 - 31/03/2003 08:21 Re: Playlists disappeared [Re: peter]
tms13
Loc: Lochcarron and Edinburgh
If not, then it's certainly possible to search for orphaned playlists using JEmplode's advanced search: (type == "playlist" && refs == 0).
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
