#148875 - 16/03/2003 10:35 Anyway to Auto-Change only your favorite visuals?
SE_Sport_Driver
Is there some way to do this in the config.ini file?
#148876 - 16/03/2003 14:05 Re: Anyway to Auto-Change only your favorite visuals? [Re: SE_Sport_Driver]
I thought that simply activating the favorite visuals was enough to make the auto-change work with only the favorite visuals. All you have to do is hold the Visual button to toggle it to "Favorites" and you're done. That's the way I remember it working when I tried it. Did the behavior change?
#148877 - 16/03/2003 17:41 Re: Anyway to Auto-Change only your favorite visuals? [Re: SE_Sport_Driver]
jwickis
Loc: India
It works for me that way. I believe it's player menu, 'favorite visuals' then select 'auto-change' the visuals after that.
#148878 - 16/03/2003 17:56 Re: Anyway to Auto-Change only your favorite visuals? [Re: tfabris]
SE_Sport_Driver
Hmm... maybe my Favorites list is messed up then. It keeps changing through visuals that I didn't pick, but I never checked the list to see if it actually changed. I was quite surprised that it didn't seem to be working that way.
Thanks, I'll check my list.
#148879 - 17/03/2003 00:09 Re: Anyway to Auto-Change only your favorite visuals? [Re: SE_Sport_Driver]
Also check to make sure you're not having this problem...
#148880 - 30/03/2003 09:15 Re: Anyway to Auto-Change only your favorite visuals? [Re: tfabris]
burdell1
I can't get this to work either....it keeps changing all the visuals, not the favorite ones
#148881 - 30/03/2003 12:13 Re: Anyway to Auto-Change only your favorite visuals? [Re: burdell1]
And you've pressed and held the "Visual" button on the Rio remote so that the screen flashes the words "Favourites Mode"?
#148882 - 31/03/2003 20:38 Re: Anyway to Auto-Change only your favorite visuals? [Re: tfabris]
burdell1
i didn't read carefully about the 'holding the visualizations' button in...i tried it and it worked great....THANKS!!!
