#147864 - 10/03/2003 16:43 Hijack ver 3.xx Question Khttpd related
ernestp
Loc: San Diego,Ca USA
I have a question concerning the khttpd in hijack.
1) What is the max connections for the khttpd server, it says 4 as the default but is that all or can I add more, what are my limitations
2) How can I hid the play,append functions from LAN people who are streaming from my Empeg player via the khttpd server
Thanks for your response and it's a great program and easy to use once you read the FAQ & search this BBS
Ernest
Blk Infiniti I-30, 1 OVR 0 MkII Serial # 080000457, 120gigs +2000 Music Cd's [Listing avail]
#147865 - 12/03/2003 12:09 Re: Hijack ver 3.xx Question Khttpd related [Re: ernestp]
There's a Hijack section in the Empeg FAQ (see link at top of screen).
Much of this (and more!) should already be in there.
#147866 - 12/03/2003 12:12 Re: Hijack ver 3.xx Question Khttpd related [Re: ernestp]
(1) see "max_connections" parameter in the Hijack FAQ. The real limitation is available memory on the player, which can be adjusted (to the detriment of music read-ahead buffering) using a "reserved" keyword (forgot exact name, see the general Empeg FAQ for that parameter).
(2) see "khttpd_commands" parameter in the Hijack FAQ, as well as the section on "securing" your player on a LAN.
Edited by mlord (12/03/2003 12:13)
#147867 - 12/03/2003 12:24 Re: Hijack ver 3.xx Question Khttpd related [Re: mlord]
Actually, the config.ini options are here in the developer info section rather than in the FAQ. The parameter in question is [startup] reservecache=nnn and it's described in detail if you follow that link.
