#146573 - 03/03/2003 13:19
Can someone figure this out for me?
Loc: Atlanta, GA
Here’s what I’d like to do.
Given:
The total number of days in a range of dates
The first day as an integer (i.e. Thursday= 4)
X is my input value representing a day of the week (i.e. Sunday = 0)
I Want:
The number of times X is contained in the range of days.
Example:
Number of days = 16
Starting day = Thursday
X = Sunday
Answer = 2
I just want to know if there’s a simple way to do this with mathematics (not If->Then logic). I had a long weekend and my brain is tired so I can’t figure out how to do this, or even if it’s possible. I’m probably going to go ahead and write a function to do it with If-Then, but if anyone can give me a mathematical answer I’d appreciate it as this is really bugging me.
#146574 - 03/03/2003 14:03
Re: Can someone figure this out for me?
[Re: JeffS]
Loc: Seattle, WA, U.S.A.
Dang, this almost worked but not quite:
INT(((7+X-StartDay+DurationInDays)/7)-1))
I'm assuming you have an INT/ROUND function at your disposal. Do you have an offset system date/days function?
Jim
#146575 - 03/03/2003 14:23
[Re: jimhogan]
Loc: Atlanta, GA
I'm working in Pascal, so I do have Round, Trunc, mod, etc. functions. As for the second question, Delphi 7 has a great host of date functions available, if that's what you're asking. The code currently builds up an array by looping through all the days and populating an array, but this is what I'd like to change. It just seems to me I should be able to do it with math functions.
#146576 - 03/03/2003 14:47
[Re: JeffS]
I think this'll work (C++):
/** Given a run of days, length total_days, starting on
* start_day_of_week, where 0=Sunday, 6=Saturday, return the number of
* days that are a particular day, given by find_day_of_week
int dayCount(int total_days, int start_day_of_week, int find_day_of_week)
if (total_days == 0)
return 0;
int total_weeks = total_days / 7;
int days_remaining = total_days % 7;
// If I've got entire weeks, then I've got one find_day_of_week in
// each.
// To see if our remaining days contain the one we're looking for
// we 'unmodulo' the maths, and then do a range comparison.
if (find_day_of_week < start_day_of_week + days_remaining)
return total_weeks + 1;
return total_weeks;
#146577 - 03/03/2003 14:50
[Re: JeffS]
d = total days
s = start day (0-6)
t = target day (0-6)
x = ( d div 7 ) + ( ( ( ( d % 7) - ( ( ( 7 - s ) + t ) % 7 ) ) % 7 ) + 1 )
I think that's right.
d div 7 gives the number of full weeks, so the target day should be in each of those.
d % 7 gives the number of days past the last full week.
( ( ( 7 - s ) + t ) % 7 ) should give the day difference between the start day and the target day.
The difference of those two should be -6 to 6, inclusive. If it's negative, then it didn't get to the target day again. If it's non-negative, then it did.
Taking the % 7 of that difference should return -1 or 0 in the two above cases.
Adding one to that gives 0 or 1, 0 if the day wasn't reached, 1 if it was.
I haven't tested fully, but that should get you most of the way there.
#146578 - 03/03/2003 14:51
[Re: Roger]
do this with mathematics (not If->Then logic) if (find_day_of_week < start_day_of_week + days_remaining)
Hmmm.
#146579 - 03/03/2003 14:55
It's only one if-then, and this is Pascal. It's not like there's a loop, which is surely the bigger problem.
Anyway, my solution is off-by-one on a couple of points in the problem space. Ignore it anyway.
#146580 - 03/03/2003 14:59
[Re: JeffS]
Loc: California
In C:
((Start - X + 6) % 7 + NumDays) / 7
It's been 18 years since I've written any Pascal, but it should be something like:
Trunc((((Start - X + 6) Mod 7) + NumDays)/7)
Some testing will, obviously, be required.
--John
#146581 - 03/03/2003 15:02
Unless there's something wrong with the slowDayCount function in the attached, then Bitt's code doesn't work quite right, either.
144616-days.cpp (131 downloads)
#146582 - 03/03/2003 15:02
Loc: Atlanta, GA
Thanks, I'll test this to make sure. This looks like the road I was going down, but it started looking complicated so I figured I was doing something wrong.
Now comes the question of code readability. . .
#146583 - 03/03/2003 15:04
[Re: Roger]
Like I said, I didn't test it, but it ought to be close.
#146584 - 03/03/2003 15:05
[Re: JeffS]
code readability Well, in C, I'd say macros would be your friend, but I don't know what kind of preprocessors exist in Pascal world.
#146585 - 03/03/2003 15:07
Loc: Hartsville, South Carolina for...
I wasn't aware that Pascal world still existed....
Michael West
#146586 - 03/03/2003 15:12
Loc: Atlanta, GA
No preprocessor unfortunately, and normally this doesn't bother me. I generally dislike macros when I write in C, but this is one time that a solid macro would be very beneficial.
#146587 - 03/03/2003 15:16
[Re: revlmwest]
Loc: Atlanta, GA
Yes, though it's only really used in Delphi now. Delphi's a great development tool that is much more powerful than people give it credit for. There are very few times I get frustrated about not being able to do something I'd be able to do in C (like the aforementioned macros) but I can develop apps in a quarter of the time it took me in C++, without writing shoddy code.
#146588 - 03/03/2003 15:19
[Re: JeffS]
I can develop apps [in pascal] in a quarter of the time it took me in C++ My crappy language is better than your crappy language!
#146589 - 03/03/2003 15:22
Loc: Atlanta, GA
Heh, actually C++ is clearly the better language as far as I'm concerned. I just think Borland makes better development tools than M$. Now outside of Windows development it's another story altogether.
#146590 - 03/03/2003 15:29
[Re: JeffS]
Right, this one definitely works (assuming my slowDayCount function is correct):
return 0;
// each.
// The run of days remaining starts at start_day_of week and ends
// at start_day_of_week + days_remaining - 1
if ((((find_day_of_week + 7) - start_day_of_week) % 7) < days_remaining)
return total_weeks;
It's still got those two 'if' statements in it. Your call. I think that the problem with Bitt's solution (or, strictly, my implementation of it) is that the C/C++ % operator does odd things with negative numbers.
144630-days.cpp (145 downloads)
#146591 - 03/03/2003 15:32
[Re: rompel]
Yep. That one works. You win.
#146592 - 03/03/2003 15:36
[Re: Roger]
Loc: Atlanta, GA
Excellent, I'll tranlate this into Pascal and see how it handles the Mod stuff. Either way you've all been a big help. Not only did you build me a great MP3 player, now you're writing my code for me!
#146593 - 03/03/2003 15:38
[Re: rompel]
Loc: Atlanta, GA
Ouch, totally missed your post. I suppose it was too simple!
#146594 - 03/03/2003 15:38
[Re: Roger]
Loc: California
Yeah, that's why my solution has a +6 instead of a -1.
#146595 - 03/03/2003 15:39
[Re: Roger]
#146597 - 04/03/2003 09:09
[Re: JeffS]
Loc: Atlanta, GA
Just as an update:
Having gotten sidetracked onto a different project at the end of yesterday (darn multitasking) I've only now been able to verify the answer:
((((StartingDay - FindDay + 6) Mod 7) + TotalDays) div 7);
Rompel was correct, though in the Pascal implementation the "Div" makes a Trunc unnecessary.
Thanks again to all, I'll feel much better about the way this works now. (The existing solution built up an array in global memory by the slow method. I didn't care for this as it really divorced the computation from the usage as well as requiring an unnecessary global variable).
