Page 1 of 5 1 2 3 4 5 >
#140368 - 05/02/2003 13:20 General Parts list....
lopan
Loc: Manassas VA
The Replacement Parts List now resides on the Empeg Wiki.
In another thread I'd suggested a place in the FAQ for just parts related information. Then I decided to scour and try and find any existing information for parts. (Parts being LED's, sled plugs, resistors, fuses) What I'd like is a good list with digikey part numbers and or links for easy access to the manufacturer. I realize most of this is on the BBS here somewhere but trying to dig it up can sometimes be daunting. I think having a centralized location for all this would make it really easy for the do-it-yourselfers to easily find what they need for projects (even if it's only in this post).
Heres what I have so far... If you see anything wrong or can contribute part numbers go for it!!
Button Materials
Buttons
4 button leds, Digikey Part 67-1606
1 SMD resistor pack, 1k Ohm, 4 resistors, Digikey part Y4102CT
Knob Materials
Knob Board (from Brian) or your own design
1 SMD Transistor
2 to 4 100 Ohm SMD resistors
1 10k Ohm SMD resistor
3 or 4 knob leds, Digikey Part 67-1608
Sled Plugs
Digikey Part H10109-ND - QR/P6-24P-C(01) Male Housing 1
Digikey Part H10085-ND - QR/P1-PC1A-111 Male Power Terminal 1
Digikey Part H10087-ND - QR/P1-PC2A-111 Male Signal Terminal 22
I can probably dig up some digikey part numbers for a few more of the button pieces.
Edited by wfaulk (17/09/2009 18:01)
Brett 60Gb MK2a with Led's
#140369 - 07/02/2003 10:19 Re: General Parts list.... [Re: lopan]
lopan
Loc: Manassas VA
I feel so alone.......
#140370 - 07/02/2003 10:41 Re: General Parts list.... [Re: lopan]
Okay. If you're feeling lonely
Hugo gives the Farnell part number for the Mk1 buttons here
- Trevor
#140371 - 07/02/2003 10:47 Re: General Parts list.... [Re: tman]
lopan
Loc: Manassas VA
ah.. cool, I forgot all about that one I'll add that to the list
Plain circular button cap for mk1
nr 917-461 www.farnell.com
#140372 - 07/02/2003 10:51 Re: General Parts list.... [Re: lopan]
loren
I think this is a great idea by the way.
|| loren ||
#140373 - 07/02/2003 10:58 Re: General Parts list.... [Re: lopan]
2mm jumpers for the HD from the post here
Farnell - 510920 (blue), 510932 (black) and 510944 (red)
Jameco - 119263
Digikey - A26244
- Trevor
#140374 - 07/02/2003 11:38 Re: General Parts list.... [Re: loren]
lopan
Loc: Manassas VA
Thanks Loren!
For the Knob materials I have some part numbers that I used on mine...
For the 100 Ohm SMD resistors, Digikey part number 311-100CCT-ND
Now I'm trying to figure out why I have 560 Ohm resistors??
#140375 - 07/02/2003 12:14 Re: General Parts list.... [Re: lopan]
Warp10
Loc: Germany
Hey, great idea!
Here's the part number of the Female Plug. I think it should also be on the list if somebody needs a replacement or just a backup ;-)
DigiKey Part# H10110-ND Female Housing
---------------------------- MK1: 00314 (4GB) MK2a: 030103104 (30GB) Installed in a BMW 323ti
#140376 - 07/02/2003 12:25 Re: General Parts list.... [Re: lopan]
StigOE
I think he used 560 Ohms first (that's also what's in the picture), but I think he had some problems with them and changed to 1kOhm. I read it in an old post, but I can't remember which one.
Stig
#140377 - 07/02/2003 15:44 Re: General Parts list.... [Re: StigOE]
lopan
Loc: Manassas VA
That would explain it... and probably why I can't find part numbers for the 1k in all my crap! (or any 1k's in my parts drawer)
#140378 - 07/02/2003 15:50 Re: General Parts list.... [Re: lopan]
StigOE
Here's the Farnell number for the resistor pack
196-770 ARV241-1k-5:RESISTOR ARRAY, 1kOhm (size 1206)
Stig
#140379 - 07/02/2003 19:40 Re: General Parts list.... [Re: Warp10]
lopan
Loc: Manassas VA
I'm assuming this part is the power recepticle?
#140380 - 07/02/2003 20:05 Re: General Parts list.... [Re: lopan]
lopan
Loc: Manassas VA
Dug around on the FAQ and pulled a few more part numbers... so heres everything we have so far.
LED Hack
Button Materials
Buttons
1 SMD resistor pack, 1k Ohm, 4 resistors, Digikey part Y4102CT or Farnell 196-770 ARV241-1k-5:RESISTOR ARRAY, 1kOhm (size 1206)
Knob Materials
1 SMD Transistor
Sled
Sled Plugs
MK1
Plain circular button cap for mk1 Farnell part 917-461
Hard Drive
2mm HD jumpers
Jameco - 119263
Digikey - A26244
Power
Power Receptacle
Female Housing DigiKey part H10110-ND Female Housing
Fuse Replacement
FUSE FAST-ACT 1.00A 63V 1206 SMD Digikey part WK4661CT-ND
Dimmer Fix
.01uf (10nF) surface-mount capacitor. anyone gotta part number for this guy?
#140381 - 07/02/2003 20:25 Re: General Parts list.... [Re: lopan]
One more: Mk1 docking connector part codes for Farnell are RP16 and RS16 according to this
- Trevor
Edited by tman (07/02/2003 20:26)
#140382 - 07/02/2003 22:56 Re: General Parts list.... [Re: tman]
mandiola
3 or 4 knob leds, Digikey Part 67-1608 seem to not show up as a product at digikey.
-Greg
#140383 - 08/02/2003 03:55 Re: General Parts list.... [Re: lopan]
Warp10
Loc: Germany
No, Part # H10110-ND is the 24 pin connector on the back of the empeg which connects to part # H10109-ND.
#140384 - 08/02/2003 10:50 Re: General Parts list.... [Re: mandiola]
lopan
Loc: Manassas VA
uh... just checked they seem to be showing up just fine for me? You typed those numbers in the parts search box?
Maybe the site was just acting sketchy?
#140385 - 08/02/2003 10:51 Re: General Parts list.... [Re: Warp10]
lopan
Loc: Manassas VA
Duhhh! Ok I get it... I'll update accordingly thanks!
#140386 - 08/02/2003 13:12 Re: General Parts list.... [Re: lopan]
StigOE
Farnell number for the 10nF cap : 499-225 (size 0805, order multiple=10)
The Farnell number for the resistor pack is 196-770 (the rest is only description).
Btw, what size is Brian using for the SMT LEDs and resistors?
It should be possible to use Farnell number 355-7996 for the white SMT LEDs.
I don't know if he is using 0603 or 0805 size resistors, but here are the Farnell numbers:
100 Ohm (0603): 911-112
100 Ohm (0805): 911-732
10 kOhm (0603): 911-355
10 kOhm (0805): 911-975
Farnell numbers for 3mm LEDs:
941-852 (about the same intensity as Brian's LEDs, but expensive)
352-6847 (less than half the price and half the intensity)
I used a BC857A transistor when I made my boards and that has Farnell number 302-3412
Stig
#140387 - 08/02/2003 16:03 Re: General Parts list.... [Re: StigOE]
mandiola
Ahh I see the problem. I was just entering that in the order... they have 2 different options(with part numbers) to order. Just out of curiosity.. does anyone have a pdf or something of the nob pcb with the 4 leds. I have a kit here to make pcb's but it would be much easier with a template... I just want to try and make one for my empeg since it seems like it will be a while before brian can get some more out.. plus then all I need is the buttons. This is the one that would be great to have a pdf of: <img src="http://www.hulkster.net/empeg/buttons/pics/knoblayout-new.jpg">
Also.. anyone know the digikey number for:
1 SMD Transistor
Thanks ,
Greg
Edited by mandiola (08/02/2003 16:11)
#140388 - 09/02/2003 12:31 Re: General Parts list.... [Re: mandiola]
lopan
Loc: Manassas VA
Added the 100 Ohm SMD resistor part number to the list, I don't have any of the other numbers, here is the updated, corrected list so far...
LED Hack
Button Materials
Buttons
Knob Materials
1 SMD Transistor
2 to 4 100 Ohm SMD resistors, Digikey part 311-100CCT-ND
Sled Plugs
Female Housing DigiKey part H10110-ND Female Housing (Back of Empeg)
MK1
Docking Connectors Farnell parts RP16 and RS16
Hard Drive
2mm HD jumpers
Jameco - 119263
Digikey - A26244
Fuse Replacement
Dimmer Fix
.01uf (10nF) surface-mount capacitor, Farnell Part 499-225 (size 0805, order multiple=10)
I hate to keep posting this list as it keeps getting bigger and bigger, but I don't really know how else to keep the list updated and intact without just reposting it over and over
Edited by lopan (09/02/2003 12:33)
#140389 - 09/02/2003 13:09 Re: General Parts list.... [Re: lopan]
maczrool
Loc: Louisiana, USA
Here's something to add. No Digikey part number as they don't carry them, but here are Molex part numbers:
10-pin header (male) used for internal connections to docking connector, 89400-1020
10-pin housing (female) used for internal connections to docking connector, 87369-1000
Female contacts for above housing, 50212-8100
You can order these as samples if need be.
Stu
#140390 - 10/02/2003 12:17 Re: General Parts list.... [Re: Warp10]
rtundo
Loc: Albany, NY
Does anybody know where to get the male/female plugs and wire terminals to make a tuner extension similar to that of the original that came with tuner?
#140391 - 10/02/2003 13:12 Re: General Parts list.... [Re: rtundo]
The wire that comes with the tuner kit is as long as the extension cord on the original tuner was. And you probably shouldn't make it any longer.
#140392 - 10/02/2003 14:21 Re: General Parts list.... [Re: lopan]
smu
Loc: Germany (Ruhrgebiet)
It would be even more usefull if you could give the specs on these (diameter, height, connector pitch, electrical parameters), so that those without access to Digikey (or those wanting to order it from a store a little closer) have a chance identifying the parts.
cu,
sven
#140393 - 10/02/2003 14:34 Re: General Parts list.... [Re: smu]
mtempsch
Given the parts numbers, the parameters are easily enough found on digi-keys website.
But the main points:
Button LEDs - standard 3mm round housing, radial leads 1U (2.54mm) c/c. Vf=3.6V, 1100mCd
Knob LEDs - 3.2mm x 2.8mm x 1.9mm, Vf=3.6V, 150mCd
#140394 - 10/02/2003 18:36 Re: General Parts list.... [Re: tfabris]
rtundo
Loc: Albany, NY
Thanks for the warning Tony, I missed that little bit on legthening the cables.
#140395 - 10/02/2003 20:51 Re: General Parts list.... [Re: mtempsch]
lopan
Loc: Manassas VA
Speaking of LED information does anyone know if Brian or anyone else ever posted part numbers for the newer LED's he was using? (the milky white ones)
#140396 - 13/02/2003 01:37 Re: General Parts list.... [Re: lopan]
mandiola
Ok. So i've got just about everything ready to order to light up my empeg. Just need two things: 1 10k Ohm SMD resistor and 1 SMD Transistor. Does anyone know the Digi-key part numbers for these?
Also for the dimmer fix.. will this capacitor from Digi-key work? Digi-Key part 399-1158-1-ND. If so you can add that to your list ; )
Thanks,
Greg
#140397 - 13/02/2003 06:57 Re: General Parts list.... [Re: mandiola]
lopan
Loc: Manassas VA
As far as the transistor goes, I asked Brian about this a while ago, he didn't remember a specific part number but it's a basic pnp switching transistor. I ordered two different kinds (unfortunately can't find the order or part number to save me) they both worked, one was just microsopic.... A Digikey search should bring up a few results.
