#138392 - 30/01/2003 22:53 equalizer controls bug
Loc: Los Angeles, CA
not sure if this would be called a feature or not, but when you're in the eq screen.... and you're in the middle right in the begining... you usually use the track fwd/back buttons to get to the bars...
if you use the volume while in the middle, and then use track fwd/back... it changes the track. in the rest of the player, any track fwd/back press while the volume bar is displayed only escapes the display.
#138393 - 31/01/2003 09:47 Re: equalizer controls bug [Re: image]
I wish the track fwd/back worked when the volume bar is up even in the regular screen.
I even put it on the internal bug list, and was shot down.
#138394 - 31/01/2003 11:08 Re: equalizer controls bug [Re: tfabris]
That's very odd.. the next/prev track buttons on the Rio Remote appear to work just fine for me when the volume popup is on the screen, but no so for the front-panel next/prev buttons..
I suppose a quick ir-translate could "fix" that.. or would it have nasty side-effects? Probably.
[ir_translate]
Left=PrevTrack
Right=NextTrack
#138395 - 31/01/2003 11:29 Re: equalizer controls bug [Re: mlord]
I tried that argument... (consistency)...
I think the remote works correctly in this instance.
#138396 - 31/01/2003 14:37 Re: equalizer controls bug [Re: tfabris]
AndrewT
Loc: Oxford, UK
Me too, it's a bit of a PITA. I really can't think of a good reason for this behaviour except that I suppose some would call it "predictable". Perhaps a compromise would be to make the volume bar disappear when the fwd/back buttons were pressed?
What reasons were cited for this not being accepted as a bug (of sorts)?
#138397 - 31/01/2003 14:50 Re: equalizer controls bug [Re: AndrewT]
Well, maybe the guys will chime in here and give their reasons...
#138398 - 31/01/2003 14:55 Re: equalizer controls bug [Re: tfabris]
Chimaera
Loc: DFW Area, Texas, US
Maybe adjusting the volume on a MK1 without using the remote played some part in that decision?
#138399 - 31/01/2003 15:22 Re: equalizer controls bug [Re: Chimaera]
Possibly, but wouldn't it be nice if the Mk2 behaved differently? They are different player apps after all.
#138400 - 01/02/2003 02:07 Re: equalizer controls bug [Re: AndrewT]
It already does. And it took me about 3 months to persuade Mike to even go that far.
Tony would've had no chance.
#138401 - 01/02/2003 08:52 Re: equalizer controls bug [Re: Roger]
so is my bug report valid then? it doesnt disappear in the situation i've stated.... might as well be consistent in all of the player.
#138402 - 03/02/2003 03:44 Re: equalizer controls bug [Re: image]
Looks like it.
