#119588 - 06/10/2002 21:14 emplode display problem
This is minor, but annoying.
In emplode, if a playlist is selected in the left panel and I then scroll so that the selected playlist is no longer on screen and I then click a `+' in order to expand a playlist to see its sub-playlists, the panel jumps in the direction of the selected playlist.
If that direction is up, then it jumps just far enough to get the selected item displayed, if it can display both that playlist and the expanded list at the same time, or, if it can't, it jumps so that the last item in the expanded list is the last fully viewable item on the panel.
If that direction is down, it jumps all the way to the bottom of the list, regardless of whether either the selected or expanded playlist is visible there. Edit: Oops. That's wrong. Actually, if both can be displayed at the same time, then it jumps down so that the selected playlist is the last not-fully-viewable item on the panel. If they can't both be on the panel, then it jumps all the way to the bottom. Most of the time. There seems to be a little inconsistency here that I can't quite figure. It may have to do with whether the expanded playlist has been expanded since the selected playlist has been selected.
This is with emplode 2.0b13 under Win2k Pro.
Edited by wfaulk (06/10/2002 21:30)
#119589 - 06/10/2002 21:26 Re: emplode display problem [Re: wfaulk]
And you haven't tried 2.0b13 to see if the problem is still there on that version?
#119590 - 06/10/2002 21:30 Re: emplode display problem [Re: tfabris]
I'm sorry. Typo. I meant 13. Fixed. Edit: But it was there under 11, as well.
Edited by wfaulk (06/10/2002 21:31)
#119591 - 06/10/2002 22:11 Re: emplode display problem [Re: wfaulk]
jwickis
Loc: India
I've been noticeing this as well it does jump all the way to the bottom and midly annoying. I don't remember it doing this before, I really believe it was just since the last fix for Emplode.
#119592 - 07/10/2002 03:18 Re: emplode display problem [Re: jwickis]
Nah. It's been doing it for a while. I find it irritating as well.
#119593 - 08/10/2002 16:12 Re: emplode display problem [Re: Roger]
jwickis
Loc: India
It doesn't always happen though it seems, last night I was clicking the exact same playlist that usually causes it to scroll down and it didn't do it, of course. Much like when I take my car in to the mechanic.
