#117193 - 20/09/2002 18:45 Ethernet Problem
jets
Loc: Toronto, Canada
i have been using ethernet for a long time now and all of a sudden, connecting to the player through ethernet is not working.
i have 2 ethernet cards on my PC and i use one to connect to the cable router for internet, file sharing, and all that. the second is obliously for the empeg. so the card i use for the empeg has an ip of lets say 192.168.123.137 with a subnet mask of 255.255.255.0. now i set the empeg at 192.168.123.138 with the same subnet mask and she won't connect. after i checked the about screen on the empeg i have found that the subnet on the player is 255.255.255.255? i thought that was strange so i double-checked and found that it's set correctly in the config.ini file as well as in the networking tab in emplode. this is excruciating since the serial connection takes forever everytime i try something different.
any ideas?
-TIA
It seemed like a good idea at the time.
#117194 - 20/09/2002 18:52 Re: Ethernet Problem [Re: jets]
Did you, by any chance, install the Mark 1 version of the player software onto it?
#117195 - 20/09/2002 21:53 Re: Ethernet Problem [Re: tfabris]
jets
no, the last update was car2-developer-v2.00-beta13.upgrade
#117196 - 21/09/2002 08:59 Re: Ethernet Problem [Re: jets]
jets
had to uninstall the card and re-assign a new "private" ip address.
