#110807 - 13/08/2002 14:50 Reboot empeg before sync
pache
Loc: Switzerland
I reboot my empeg before i start synchronizing. Now emplode can't connect to the player (Could not connect socket error).
The point is i don't want to restart emplode (it's still open on my PC) , since i maid a lot of change in the playlists. Is it possible to resolve that easily (if it's to difficult i just restart emplode) that will save me a lot of time.
Daniel Mk1 40go and MK2 30go
#110808 - 13/08/2002 14:58 Re: Reboot empeg before sync [Re: pache]
No. If you rebooted the player after Emplode grabbed its databse, you cannot synch without exiting emplode and losing your changes.
Don't do that.
#110809 - 13/08/2002 15:01 Re: Reboot empeg before sync [Re: tfabris]
Since the entirety of the state information is held in emplode until the sync occurs, I can't conceive of a reason that there couldn't be a reconnect option added to emplode. It might want to check to make sure that it's the same empeg, or warn the use that reconnecting to a different empeg might cause data loss, but there shouldn't be any reason that it's undoable.
#110810 - 13/08/2002 15:04 Re: Reboot empeg before sync [Re: wfaulk]
I think you could seriously damage the database if certain things happened in the wrong order. Early on, before they added the failsafe into the software to prevent this problem, I seriously hosed my database once doing something like this.
#110811 - 14/08/2002 04:55 Re: Reboot empeg before sync [Re: tfabris]
pache
Loc: Switzerland
Well, thank you any way.
I'll sort it over again.
#110812 - 14/08/2002 08:24 Re: Reboot empeg before sync [Re: wfaulk]
tms13
Loc: Lochcarron and Edinburgh
JEmplode manages reconnection no problem. I often synchronise my changes a day later, having gone home and back (and used the player there as well as in the car both ways) in between.
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#110813 - 14/08/2002 08:53 Re: Reboot empeg before sync [Re: tfabris]
Why not? Did I break something? The only reason that I can think of that would break it is if the DHCP server gave you the wrong IP address, or the USB path changed, or whatever.
We protect against database corruption by keeping a generation id (sequence_id) so that we can tell if you changed the database on another PC.
