#109125 - 02/08/2002 19:27 Sokoban for Empeg
I was bored so I wrote a Sokoban game for the Empeg.
It's here if anybody wants it. Move around using the front panel buttons or remote. You can scroll about manually with the knob.
- Trevor
#109126 - 02/08/2002 21:21 Re: Sokoban for Empeg [Re: tman]
cael
Just in case people aren't familiar with the name Sokoban, this is the puzzle game which involves pushing a number of blocks from their starting positions to an end location.
Here's an online java version:
http://www.pimpernel.com/sokoban/sokoban.html
#109127 - 03/08/2002 05:23 Re: Sokoban for Empeg [Re: cael]
New version here
Fixed a couple of bugs and compressed the level data to save some space. Put a move and push counter in as well.
- Trevor
#109128 - 03/08/2002 13:04 Re: Sokoban for Empeg [Re: tman]
justinlarsen
Loc: Petaluma, CA
whoa, this is kick ass. I LOVE GAMES FOR THE EMPEG!
---- Justin Larsen
#109129 - 03/08/2002 15:08 Re: Sokoban for Empeg [Re: tman]
Hi Trevor,
Is there any chance of releasing the source. I'm in the middle of writing my GPS display program and would like to see as many examples of empeg progs to help me write mine. I've got the display routine and the NMEA parsing routine I just need some glue code to get it going.
PLEASE!!
#109130 - 03/08/2002 15:48 Re: Sokoban for Empeg [Re: andym]
Sure. I'll email it to you in a sec
- Trevor
#109131 - 03/08/2002 15:54 Re: Sokoban for Empeg [Re: tman]
You're a wonderful man!
#109132 - 05/08/2002 17:45 Re: Sokoban for Empeg [Re: tman]
kojak71
Wow, this will keep the girlfriend busy.
I do have 1 question, which directory should this program be sitting in, at the moment I have it sitting in /empeg/bin/.
#109133 - 05/08/2002 18:13 Re: Sokoban for Empeg [Re: kojak71]
It needs to have a cute aspect to be a true girlfriend distraction though
It doesn't matter where you put it so feel free to put it in /empeg/bin/
- Trevor
#109134 - 06/08/2002 12:04 Re: Sokoban for Empeg [Re: tman]
oliver
Hi Trevor, very nice work. game is really awesome.
One thing i would like to see added in the future, is be able to hold down a button, and the guy will just go all the way to the wall. There is something that bothers me about pushing the buttons on a priceless display 1000's of times. Is this possible to add into your code?
#109135 - 06/08/2002 12:07 Re: Sokoban for Empeg [Re: oliver]
Yeah. I was thinking of adding this. It was making my finger ache from pressing the buttons so many times
- Trevor
#109136 - 06/08/2002 13:45 Re: Sokoban for Empeg [Re: oliver]
Okay. I've added support for key repeating now. Just hold down the buttons for at least .25 seconds and it should start to repeat. New file is here. Same instructions to install.
It also now supports the launcher program. Give it the command line argument -l to turn it on.
Anybody else want anything else added to it? Or if there are any bugs?
- Trevor
#109137 - 07/08/2002 11:56 Re: Sokoban for Empeg [Re: tman]
Damn you! As if I hadn't ruined enough of my school year playing Sokoban on my Rex6000 in the middle of class, now you've got me playing it at work! Thanks a lot!
#109138 - 07/08/2002 19:41 Re: Sokoban for Empeg [Re: tman]
Woohoo! Thanks, mate!
Edit: Hmm... it doesn't seem to want to grab the display or buttons when run by launcher. I'm not sure if the problem is in my code, or yours. Will try tracking it down on my end.
Edited by canuckInLA (07/08/2002 22:44)
#109139 - 08/08/2002 03:06 Re: Sokoban for Empeg [Re: canuckInOR]
Oops. I accidently commented out the setgeometry ioctl I'll put it back in...
- Trevor
#109140 - 08/08/2002 04:38 Re: Sokoban for Empeg [Re: canuckInOR]
Okay. I've worked out what the problem was.
I'm a little bit more fussy on checking the return codes of the ioctls and it was dying because it couldn't bind the buttons. This always fails for some reason.
A workaround would be to have your launcher program bind all of the available buttons so that it can pass them onto the user app it launches. The viewer program works because it doesn't check the return codes and it also happens to use the same set of buttons that you do. Haven't had the time to work out why exactly since I'm technically supposed to be working...
I'll put a fixed version of empsoko up in a bit. Still trying to find out why empsoko isn't getting the "-l" argument to run in launcher mode though.
- Trevor
#109141 - 08/08/2002 06:12 Re: Sokoban for Empeg [Re: canuckInOR]
Okay. Fixed the problem about the command line arguments. And the button binding issue.
New version of empsoko is here. You don't need to upgrade unless you're using launcher.
Ignore patch. It's reversed. Will reply with proper one
- Trevor
108335-launcher.patch (178 downloads)
Edited by tman (08/08/2002 06:15)
#109142 - 08/08/2002 06:15 Re: Sokoban for Empeg [Re: tman]
New patch for Launcher v1.0
Must get back to work!
- Trevor
108337-launcher.patch (114 downloads)
#109143 - 08/08/2002 19:43 Re: Sokoban for Empeg [Re: tman]
Ah, sweet! Thanks for the patch. Will get that fixed and distributed when I get home...
Edit: Ah, I see... I saw it commented out in the example in hijack.h, which said it was done by WAITMENU.
Edit2: See post in programming forum for updated distro. I need a website, I think.
Edited by canuckInLA (09/08/2002 00:36)
