#108383 - 30/07/2002 10:43 Did something stupid
f_devocht
Loc: Belgium
Halfway through upgrading to beta13, I cancelled the process (pushed cancel button) cause I realised I forgot to upgrade emplode first. Anyway, I installed emplode beta 13 but I can't reconnect to the player.
Any ideas to get the software on the player again?
The player is a mk2a with (previously) beta 11 and hijack 27x .
This is what hyperterminal says:
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...change_root: old root has d_count=1
Mounting proc
Press 'q' now to go into development mode. You Have Zero Seconds To ComStarting
player
Exec player faiüRestored terminal settings
No player!
Starting bash.
bash-2.03#
#108384 - 30/07/2002 10:45 Re: Did something stupid [Re: f_devocht]
Remove the power from the player.
Start the upgrade process.
Do not apply power to the player until the upgrade program tells you to do so.
Then it will work.
#108385 - 30/07/2002 10:47 Re: Did something stupid [Re: tfabris]
f_devocht
Loc: Belgium
Sjees, so simple it makes me ...
Thanks Tony!
Frank
#108386 - 30/07/2002 10:51 Re: Did something stupid [Re: f_devocht]
No problem. That'll be $20.00. I take PayPal.
#108387 - 30/07/2002 15:25 Re: Did something stupid [Re: tfabris]
snoopstah
Loc: Squamish, BC
No, eBay take PayPal.
A.
#108388 - 31/07/2002 02:05 Re: Did something stupid [Re: f_devocht]
David
Loc: Cambridge
I suppose now is a little late to mention that it wouldn't have mattered that you hadn't upgraded emplode first anyway?
#108389 - 31/07/2002 04:08 Re: Did something stupid [Re: tfabris]
f_devocht
Loc: Belgium
heh, this reminds me of the time I took my car to the garage because I thought it had a bad wheel bearing. Turned out the wheel nuts were loose. Cost me $20 and an empty fuel tank. Guess they had a good laugh and a great time with the car (230hp miata).
Frank
#108390 - 31/07/2002 04:11 Re: Did something stupid [Re: David]
f_devocht
Loc: Belgium
Actually it is, but thanks anyway. I'll keep it in mind next time
Frank
