#107481 - 26/07/2002 00:37 Autochange visual bug still present
jheathco
Loc: Mission Viejo, California
In 2.0b11, I turned on autochange visuals to 'on track change'. Since then, I have been unable to turn it off. I've upgraded to 2.0b13 to no avail...
John Heathco - 30gig MKIIa w/ tuner module
#107482 - 26/07/2002 07:34 Re: Autochange visual bug still present [Re: jheathco]
I've never reproduced this one. I have been able to turn it on and off at will. Anyone else?
#107483 - 26/07/2002 09:55 Re: Autochange visual bug still present [Re: tfabris]
F0X
Loc: Alberta, Canada
I have not had this problem myself.
F0X 3xMkIIa
#107484 - 26/07/2002 11:44 Re: Autochange visual bug still present [Re: tfabris]
jheathco
Others have reported it so I don't know.... when I go back to the menu, even if I haven't rebooted, 'off' is always selected, yet that's not really what's chosen.
#107485 - 26/07/2002 19:23 Re: Autochange visual bug still present [Re: jheathco]
jheathco
Am I the only one with this bug? Where does the empeg store its settings? If its on some partition, can I just format it and re-upgrade?
#107486 - 26/07/2002 22:23 Re: Autochange visual bug still present [Re: jheathco]
F0X
Unfortunately I dont have an empeg handy for the next couple weeks so I cant test this out.
This may be totally obvious, and if it is I am sorry, but does the empeg show the current mode in the menu, or does it always start at off, regardless of current setting. Do you actually select the 'off' setting, or do you just exit the menu as it looks like it is already set to 'off'. Once again, sorry if this is obvious, I dont mean to insult, just something I though of.
F0X 3xMkIIa
#107487 - 26/07/2002 22:50 Re: Autochange visual bug still present [Re: F0X]
jheathco
Hehe no prob. But yes, it is always on 'off' and yes, I do re-select it.
#107488 - 27/07/2002 01:38 Re: Autochange visual bug still present [Re: jheathco]
jheathco
Anyone on where the empeg stores settings?
#107489 - 27/07/2002 07:21 Re: Autochange visual bug still present [Re: jheathco]
Flash.
#107490 - 27/07/2002 10:47 Re: Autochange visual bug still present [Re: tfabris]
jheathco
Well, that stinks . Is there anyway to have the empeg revert to default settings or anything like that?
#107491 - 28/07/2002 12:42 Re: Autochange visual bug still present [Re: jheathco]
Here is a customized Hijack, just for you, that nukes the flash settings EVERY RESTART/REBOOT.
http://empeg-hijack.sourceforge.net/v286-nukeflash.zImage
Install it, reboot once, verify your problem is gone, and then re-install a proper kernel again.
#107492 - 29/07/2002 06:26 Re: Autochange visual bug still present [Re: mlord]
SE_Sport_Driver
Wow... how's that for a favor? Your very own HiJack!
#107493 - 31/07/2002 22:23 Re: Autochange visual bug still present [Re: SE_Sport_Driver]
jheathco
Mark,
You are THE MAN. I'll definately be dishing that one over to my empeg very soon
Thanks again...
#107494 - 01/08/2002 14:24 Re: Autochange visual bug still present [Re: mlord]
jheathco
Worked great, thanks Mark, I owe you one...
