#105018 - 14/07/2002 13:44 jEmplode 39
mschrag
Loc: Richmond, VA
OK .. 39 is going up (give it about 5-10 mins -- I have a crappy connection now that I moved ... no more spoiled by 768k dsl )
38 Changes (I added a couple quick things in and made a 38 before Tony reported that bug)
new "decade" tag available in jEmplode -- This takes all your 1981, 1982, 1983 and returns "1980" for them. You'll see why this is kind of neat in a sec.
new customizable soup playlists - this isn't the mirroing thing yet, but basically now you can design your own soup playlists (like if you wanted By Genre/By Artist instead of the builtin type, you can do that now). Now you see why decade might be kind of neat -- Not just By Year -- you could have By Decade/By Artist.
Loop at the very bottom of www.jempeg.org/faq.html to find out how to do thse. Keep in mind that the more of these you have, the slower jEmplode's going to get on downloading and updating after making changes (since it has to propogate all the changes to all the soup nodes). The flip side is that you can remove the current ones if you want it to get faster (i.e. no soup nodes). You'll always have "All" and "Searches".
39 Changes
Fixed the bug that basically made Wendy Filter editing not work at all.
Mike
Edited by mschrag (14/07/2002 13:45)
#105019 - 14/07/2002 14:38 Re: jEmplode 39 [Re: mschrag]
mcomb
Loc: San Carlos, CA
Hmm, I just upgraded to v39 and the latest hijack and I can no longer connect to my empeg over ethernet from jemplode. Emptool still works, but jemplode does not from either OSX or FreeBSD. Strange.
-Mike
#105020 - 14/07/2002 14:42 Re: jEmplode 39 [Re: mcomb]
mcomb
Loc: San Carlos, CA
The new NetworkEmpegDiscoverer thingy finds it, but I am unable to connect. mschrag is there a debug mode still so I can't see what is going on?
-Mike
#105021 - 14/07/2002 14:49 Re: jEmplode 39 [Re: mcomb]
mcomb
Loc: San Carlos, CA
OK, got it. Something weird mush have happened with my .jempegrc, as soon as I moved that file it started working again. It was working fine with v37 and broke when I went to v39. I attached the old .jempegrc in case you want to take a look at it.
-Mike
103710-old.jempegrc.txt (321 downloads)
#105022 - 14/07/2002 15:10 Re: jEmplode 39 [Re: mcomb]
mschrag
Loc: Richmond, VA
Did you check the Connection Options dialog? Did everything look correct? I have a memory of maybe renaming a configuration option, but I can't for the life of me figure out what it was ....
#105023 - 14/07/2002 15:22 Re: jEmplode 39 [Re: mcomb]
mschrag
Loc: Richmond, VA
i'm still looking, but I diffed my 36 version against my 39 version and the only changes were the customized soup playlist entries....
#105024 - 14/07/2002 15:27 Re: jEmplode 39 [Re: mcomb]
mschrag
Loc: Richmond, VA
I just used the jempegrc you attached on my 39 on OS X (and changed the unicast ip address) and it worked. Yours was set to Specific IP Address and not for Broadcast discovery ... It would have reset to broadcast if you removed .jempegrc . Can you check the IP Address in that .jempegrc and make sure it's correct for your Empeg?
#105025 - 14/07/2002 15:32 Re: jEmplode 39 [Re: mschrag]
mcomb
Loc: San Carlos, CA
Weird. The IP was correct, it was originally on unicast but during troubleshooting I put in the actual IP to make sure it wasn't a unicast problem.
-Mike
#105026 - 14/07/2002 16:17 Re: jEmplode 39 [Re: mcomb]
mcomb
Loc: San Carlos, CA
Well now I have another problem. I am unable to upload any files with v39. It creates directories, and uploads the song info fids but not the actual songs. The sync goes way to fast and then when after it reboots I get a message like "There was no tune or playlist that has ID 288" for each song I tried to upload.
-Mike
#105027 - 14/07/2002 16:20 Re: jEmplode 39 [Re: mcomb]
mcomb
Loc: San Carlos, CA
Forgot to mention that I tried both fast and regular connections to two different empegs and had the same problem in all scenarios.
-Mike
#105028 - 14/07/2002 16:57 Re: jEmplode 39 [Re: mcomb]
mschrag
Loc: Richmond, VA
@#$*^@#($& I changed some of the API for marking nodes dirty and called the wrong one in FIDLocalFile (basically making local files appear to not be dirty). 40's comin right up ...
#105029 - 14/07/2002 17:03 Re: jEmplode 39 - www.jempeg.org down? [Re: mschrag]
AndrewT
Loc: Oxford, UK
Is www.jempeg.org down ATM or is it my ISP?
#105030 - 14/07/2002 17:06 Re: jEmplode 39 - www.jempeg.org down? [Re: AndrewT]
mschrag
Loc: Richmond, VA
you probably caught me in the middle of uploading release 40... Check back in about 5 mins and it should be done.
Mike
#105031 - 16/07/2002 06:17 Re: jEmplode 39 [Re: mschrag]
tms13
Loc: Lochcarron and Edinburgh
Mike, could you add instructions on custom columns to the jEmplode FAQ? I'll find them here on the board, but they belong in the FAQ as well...
[Edit - added URL]
Edited by tms13 (16/07/2002 06:20)
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#105032 - 16/07/2002 06:31 Re: jEmplode 39 [Re: tms13]
mschrag
Loc: Richmond, VA
Done ... i forgot about that one ... Thanks
Mike
