#102286 - 30/06/2002 11:32
My home docking station pictures and description.
#102287 - 30/06/2002 11:40
Re: My home docking station pictures and description.
very nice, as usual
#102288 - 30/06/2002 11:47
[Re: rockstar]
Thanks!
Next one will use a better grade of wood, I think. Plywood still doesn't look great even after it's stained.
#102289 - 30/06/2002 12:02
Loc: Indiana, USA
Tony,
You should try laminate over the wood. Fairly inexpensive, and all you need is some adhesive and a flush router bit. I used black laminate over plywood for my arcade cabinet, and couldnt be happier with the results.
ED7
20G Mark2A
SN#: 010101680
1997 Chrysler Sebring LXi
#102290 - 30/06/2002 12:03
Loc: Greenhills, Ohio
Any way you would be interested in doing one for my MKI or sending me some plans that I could have someone else make one for me? I kind of like the wood idea better than metal, it's classy looking. I do know someone with woodworking skills.
Laura
MKI #017/90
whatever
#102291 - 30/06/2002 12:05
Just a couple of ideas for the current version - If you have a router, you might try rounding the corners for a softer look. As far as the finish goes, you might try a couple coats of sealant to cover the grain and then paint it black. Black hides a multitude of imperfections  I realize that that defeats half the purpose of using wood, but like you said, plywood doesn't have the most pleasing grain and color anyway.
#102292 - 30/06/2002 12:06
Loc: Louisiana, USA
Why not use a nice exotic wood like Rosewood or Coco Bolo. They look best without stain at all. You can even get Rosewood plywood for the top and front and use solid Rosewood for the sides. I know that's what I would do anyway.
Stu
#102293 - 30/06/2002 12:10
[Re: ElectricD7]
Yes, laminate is the next thing I was considering. Although I prefer the look of solid wood, and I also prefer the look of stained wood over just plain black.
I actually have some better wood and I think the next one will just be done with that.
#102294 - 30/06/2002 12:15
[Re: Laura]
Any way you would be interested in doing one for my MKI .
Doing the woodworking is the hardest part for me, and after I finish the second one, I'll probably be completely burned out on woodworking for quite a while. So, I'd have to refuse.
There aren't any plans as such. This was kind of improvised. The only thing I did was to make some measurements and drew some rectangles in Corel Draw so I could decide on the size of the top, bottom, and front pieces so that I could get that 9 degree angle.
If you talk to your woodworking friend, he could probably come up with something much better if you showed him the photos and worked with him on the design.
Don't forget to allow enough space in the back for working with all the wires.
#102295 - 30/06/2002 13:03
[Re: Laura]
this can be made to order if you ask my dad awfuly nicelly
Aberdeen Scotland
#102296 - 30/06/2002 13:46
[Re: thinfourth2]
Wow your dad did a great job,thats a sweet cabnet.I like the way that the plywood turned out.very nice job.
040103958 60g
#102297 - 30/06/2002 13:53
[Re: JBjorgen]
Loc: Louisiana, USA
Plywood does not inherently have displeasing grain or color. It appearance depends on two things. The veneer used and the construction of the plys. If the edges are visible, it would be best plywood to use Baltic Birch plywood which has very thin plys. If the edges are hidden, it really can be hard to separate it from solid wood. The plywood used in his docking station is obviously veneered with rotary cut fir plywood like you find at hardware stores, which is not at all suited for fine woodworking. It's not even easy to make it look real good with paint.
Furniture grade plywoods which use quarter sawn or flat sawn veneers, are an excellent choice for the project as long as the edges are concealed.
Stu
#102298 - 30/06/2002 14:15
[Re: maczrool]
You are of course correct. I was referring to fir or pine plywood like the stuff used to sheet floors and roofs. I use birch all the time when making cabinetry, and it looks great. With something this small though, using solid wood rather than cutting strips to cover the ply edges would be recommended.
#102299 - 30/06/2002 14:20
[Re: thinfourth2]
Gee, I would love something like that for my stereo setup. Right now everything sits on a wire rack. How would I ask your dad and it would probably cost a lot to ship over the pond. You could ask him nicely for me and let me know how much it would cost
Laura
MKI #017/90
whatever
#102300 - 30/06/2002 15:31
[Re: JBjorgen]
Loc: Arizona USA
Hmm, I actually think it looks quite nice. I think the grain, finish etc all work well together. A satin finishing coat, something without too much shine would be perfect.
Elvis
#102301 - 30/06/2002 15:45
[Re: thinfourth2]
Loc: Tucson, AZ
They both look good to me, does anyone have any plans of producing these?
Steve
#102302 - 30/06/2002 16:51
Looks great Tony, I was thinking of making one for myself but I only have one sled and it's in the car. Do you know where I could get another sled?
Ben
Ben mk2a 60gig green/Greenlights Buttons mk2a 60gig green/Greenlights Buttons mk2a 40gig blue no illumination....yet hijacked
#102303 - 30/06/2002 19:09
Loc: Atlanta, Georgia
That is pretty sweet, dude! How's the empeg slide out with the 'fixed' ethernet connection?
Mike 'Fox' Morrey
128BPM@124MPH. Love it!
2002 BRG Mini Cooper
#102304 - 30/06/2002 20:28
[Re: mrfixit]
Order one before the Empeg International Store closes on May 31, 2002.
Help from Christian Williams might be necessary, though.
#102305 - 30/06/2002 20:59
Hey Tony, thats a good one. It just happens that I am a really big fan of the back to the future movies, so I know what you are saying, I found the post from philp69 listing the part#s for the main connector so Im going to make one. Besides Christian`s Delorean won't help... I didnt see a flux capacitor anywhere in it
Ben
#102307 - 30/06/2002 23:20
[Re: elvis]
Or you could coat it with plush fur. like this guy's computer
Murray
Is it the 'N', or the 'Zero'?
#102308 - 01/07/2002 08:07
[Re: muzza]
Now Iv seen everything!
Ben
#102309 - 01/07/2002 09:37
[Re: muzza]
Loc: Tucson, AZ
unbelievable!
Steve
#102310 - 01/07/2002 09:48
[Re: muzza]
Seems someone misunderstood the term "fuzzy logic".
#102311 - 01/07/2002 09:56
#102312 - 01/07/2002 10:03
[Re: tonyc]
Thank you, thank you, I'm here till Thursday.
Be sure to tip your servers.
#102313 - 01/07/2002 21:49
Loc: New Orleans, LA
Where do you people FIND this stuff?
#102314 - 02/07/2002 01:14
[Re: lectric]
#102315 - 02/07/2002 01:41
[Re: frog51]
Loc: Mesa, AZ
It's out there, lectric.
I Love It.
Way too much time and spare parts.
-- Terry K --
30Gb Smoke / Toyota 4x4
30Gb Amber / Bounder RV
Pants first, then shoes
