I'd like to find Digikey ordering numbers for these guys, to order replacements, but my searches there aren't working, nothing is coming up which looks anything like what I've got here. Anyone know how to ID these? Photos attached.
These are parts from a joystick, Thrustmaster T-Flight HOTAS 4 model. The pots are for X/Y axis and the rudder rotation axis, and the switches are for the 4-way thumb-hatswitch.
Switches are temporary pushbuttons with a sort of a "click" to them when they are pressed. Potentiometers have a limited rotation travel range of about 270 degrees total, though I don't have an easy way to measure that accurately to be sure. I'm hoping that the printed codes on there are some kind of a clue to their detailed specs.
Thanks for any advice or help you can offer!
Potentiometer - 9.9mm wide 01.JPG (794 downloads)
Potentiometer - 9.9mm wide 02.JPG (916 downloads)
Potentiometer - 9.9mm wide 03.JPG (587 downloads)
Pushbutton Switch - 6mm wide - 01.JPG (309 downloads)
Pushbutton Switch - 6mm wide - 02.JPG (294 downloads)
Pushbutton Switch - 6mm wide - 03.JPG (216 downloads)
