looking closer on this CF card, I see that it really says "Writing Inode Tables" and then the numbers are flashing by. After a short wait, it said "done" and then said "Writing superblocks and filesystem accounting information:" And then nothing after that for a while.
It will be very slow, depending on the CF Card. Just wait for it. Eventually it should say "Done!" on the serial port (and on the front panel display!) and then drop to a (bash) command prompt.
More expensive CF cards boasting very fast sustained WRITE speeds will be quicker there. Using the v6 builder will also be MUCH quicker than the other choices too.
Here (attached this time, rather than inline) is the actual/recommended v6 builder script. I should have posted this one earlier instead of v3. If you have a quick peek, you should be able to see exactly what it is doing at any point.
builder_v6_init_script.txt (456 downloads)
Description: v6 builder /sbin/init script
Edited by mlord (16/05/2019 15:47)
