tanstaafl: tell me more about your fix. Your printer is exactly the same as mine. Where exactly is the roller you're cleaning?
Unplug the wires from the back of the printer so you can stand it on its back. Remove the paper tray. There is a large, oddly-shaped semi-circular rubber pad on an axle that lets it rotate, right above where the leading edge of the paper would be if the tray were still in place. Clean this roller with alcohol and your problems may go away.
Pickup Roller LowRes.jpg (2989 downloads)
