#246483 - 14/01/2005 20:10
Re: PCI Express 1920x1200 DVI Recommendations
[Re: blitz]
Quote: I appreciate the input on the ATI cards. On the ATI cards, how do you reduce the vertical blanking interval.
Check the attachment to see where it is set. Though make sure to use the drivers with the normal control panel. Last I knew the CCC didn't expose these options yet.
Quote: I had thought about the 30" Apple Display before I bought the Samsung. Honestly though the 1920x1200 was big enough for what we need it for. I also heard that a lot of the controls on the apple displays are through software only with no support through PCs.
This is normal for any DVI display. My Samsung gere gives me brightness controls and menu repositioning options only when running in DVI. The rest has to be controlled by the source. An Apple display on the PC will be the same as any other LCD on a PC.
