Ok, my tuner seems to be dead. In the last week I experienced some signal losses. Simply, the signal strenght would decrease down to two or one on the signal strength bar. Then it would come back up after two or three seconds, and after a RDS rescan, usually. Last night the signal strength decreased to never come back up.
So this morning I went to my firend installer and we spent almost two hours trying to find out what the problem was.
- The extension cable is streight
- The antenna is powered (in fact it has been working fine so far)
- The antenna and the antenna cable is ok, as tested with another regular tuner connected to it
The tuner now seems not to receive anything. Only a very very weak signal once in a while.
I am using alpha 3
The tuner is an original empeg one. I purchased second hand here after mine was stolen, and it seemed pretty new. It had been installed only once for test purposes, supposedly. We also opened it and the only thing we noticed is what seems to be some rust (?!), which should not be there, I believe (what do you think?): that radio has been installed in my new car since September, and no humidity was around it...
Other than that, I don't know what to do/think.
193414-Resize of IMG_2711.JPG (76 downloads)
Edited by taym (20/12/2003 08:58)
