and without the Empeg. Kinda dark - hard to see detail. But the sled is behind the fascia, which holds it snugly in place. Due to the depth of the opening in the MINI, none of the sled tabs is bent to hold it.
The stock rear mount in the car lines up perfectly with the mount hole in the sled, but the sled uses the wrong size fastener. So you can't use the mount plug from the stock HU. I used a machine screw that fit, and added a rubber plug on it to slide it the support bracket in the car.
Now to get the stock HU apart so I can use the stock face as a stealth cover....... Muuhaahaa
-- Terry K -- 03 DS/W MCS
