#99825 - 17/06/2002 07:40 MK2 Drive Upgrade Questions
RobRoy
I am preparing to upgrade my MK2 unit, and I have a question as far as hard drive mouting and jumpers are concerned.
I plan to use a pair of new IBM Travelstar drives, and I am quite familiar with them as I have done countless laptop upgrades, etc.
However, in every instance prior, I have never had to supply the following (and the drives in OEM packaging do not provide):
1. Mounting Screws
2. Jumpers
I saw a link in the FAQ to Farnell, but they are apparently in the UK, and I am in the USA.
So, I need to know the following:
Will I actually have to jumper the two drives as Master & Slave, or will the IDE cable already present in the unit do this automatically via Cable Select?
If someone has a link to a US Merchant selling the appropriate jumpers and screws, I would greatly appreciate it!
Thanks,
#99826 - 17/06/2002 07:49 Re: MK2 Drive Upgrade Questions [Re: RobRoy]
Terminator
Loc: Dallas, TX
You can find the correct jumpers on floppy drives if you have any of them laying around unused. I found the screws at the hardware store but i cant remember exactly what thread and type they were.
Sean
#99827 - 17/06/2002 07:52 Re: MK2 Drive Upgrade Questions [Re: Terminator]
RobRoy
Sean,
Thanks for the information.
I was under the impression (perhaps incorrectly) that the jumpers for desktop (3.5") drives were larger than the jumpers most commonly used for laptops (2.5") and therefore were prone to falling off, etc.
If anyone has the specs on the screws, I would appreciate it!
Thanks Again,
#99828 - 17/06/2002 08:01 Re: MK2 Drive Upgrade Questions [Re: RobRoy]
Terminator
Loc: Dallas, TX
Yes, the jumpers on 3.5 hard drives are bigger, but floppy drives use smaller jumpers.
#99829 - 17/06/2002 08:04 Re: MK2 Drive Upgrade Questions [Re: RobRoy]
mrfixit
Here is another link if anyone needs those little jumpers https://www.jameco.com/cgi-bin/ncommerce3/ExecMacro/Jameco/searchResult.d2w/report?search=jumper&sort=BKW&startRowNum=1&totalSize=76&cgrfnbr=501&cgmenbr=91&ctgys=&Next.x=40&Next.y=15 I'm still looking for the screws.
p.s. would somone reply to my post
Ben
mk2 20gig
hijacked
Ben
hijacked
#99830 - 17/06/2002 08:16 Re: MK2 Drive Upgrade Questions [Re: mrfixit]
SE_Sport_Driver
I simply stoll 2 screws from one of the drives... so there are 2 screws holding each one in. It has held my drives for over 18 months with no issues. It is even mentioned in the upgrade guide.
#99831 - 17/06/2002 08:27 Re: MK2 Drive Upgrade Questions [Re: RobRoy]
The screws are the same type that are used to screw in a CD-rom or a floppy drive in a PC. They may be a little longer, but I fixed that by putting two washers between each screw and the Harddisk. That way there's also no way the harddisk will ever touch the metal of the drive bay too.
#99832 - 17/06/2002 08:32 Re: MK2 Drive Upgrade Questions [Re: mrfixit]
RobRoy
Ben,
Do you have a part # on those jumpers? That link wasn't valid for me, but I was able to pull up the main page so I don't think it was my connection.
Thanks,
#99833 - 17/06/2002 08:33 Re: MK2 Drive Upgrade Questions [Re: BartDG]
mrfixit
Thanks Archeon, for some reason I thoght the laptop drive screws were smaller... I have tons of cdrom screws.
Ben
hijacked
#99834 - 17/06/2002 08:36 Re: MK2 Drive Upgrade Questions [Re: RobRoy]
mrfixit
Shure Rob, Jameco #119263 Mfg Ref #2.0MINI JUMPER OPEN
not shure why the link didnt work.
Ben
hijacked
#99835 - 17/06/2002 09:51 Re: MK2 Drive Upgrade Questions [Re: mrfixit]
Thanks, the Jameco part number has been added to the drive upgrade FAQ. If someone has a similar part number for the drive mounting screws, I'll put that in, too.
#99836 - 17/06/2002 18:46 Re: MK2 Drive Upgrade Questions [Re: tfabris]
mrfixit
Just thought I would add this link, http://www.tccomputers.com they have screw kits, just type in screws at the search on the page.
Ben
mk2 20gig
hijacked
Ben
hijacked
