#99147 - 13/06/2002 01:12 more 'W'-symbols with Hijack...
pupvogel
Loc: Hamburg, Germany
From time to time I have a long pause (say, 2-3 seconds) between tracks and see the W-symbol at that time (if the harddisk-icon is turned on).
Strange thing about this: I see this about once an hour if Hijack is installed - but only about once a day when Hijack is NOT installed.
I have that same issue with both my players (empeg and riocar, 12MB and 16MB) and I also logged the serial-port when that was happening - no messages at all.
It doesn't matter if I listen to VBR- or CBR-encoded music. It happens with both.
Maybe some cache issue or memory-leak ? That comes more into foreground when more memory or resources are used ?
So since 2 months or so I don't have Hijack installed, because these frequent pauses are very annoying when listening to mix-CDs.
Trade-off: the remote really often doesn't work, because I can't enjoy the Hijack-fix of THAT issue... not to mention all the other luxuries of Hijack ...
Last time I tried it with Hijack v266, so I'll give it a shot with the newest version today...
#99148 - 13/06/2002 04:39 Re: more 'W'-symbols with Hijack... [Re: pupvogel]
The only possible culprit, which I doubt, would be the failsafe spindown that Hijack enables. You can try disabling this if you want, using:
[hijack]
spindown_seconds=0
#99149 - 13/06/2002 06:39 Re: more 'W'-symbols with Hijack... [Re: mlord]
That goes into config.ini, of course.
#99150 - 18/06/2002 02:16 Re: more 'W'-symbols with Hijack... [Re: mlord]
pupvogel
I put v276 on it two days ago and didn't have a single 'W'-lockup since then... weird...
