#99131 - 12/06/2002 20:29 Will RioCar display to LCD in-dash monitor?
wazoo
I've got a Kenwood GPS system which displays on their KVT-m700 touchscreen 7" LCD display. The m700 also has video in as well as an AM/FM tuner.
I'm going to have a shop install the RioCar by slaving it to the m700 (i.e. utilizing its built in amp).
I know this is a longshot, but is there a way to use the LCD screen as a display for the Riocar?
Thanks for helping a newbie...
Wazoo
#99132 - 12/06/2002 20:38 Re: Will RioCar display to LCD in-dash monitor? [Re: wazoo]
robricc
A while ago someone made a TV output device for the empeg. See here. I don't believe it allows you to use the menus, only shows what's currently playing. Nothing ever came of it, but with all the new LCD screens in cars I think there is a new demand for this sort of thing.
#99133 - 12/06/2002 21:20 Re: Will RioCar display to LCD in-dash monitor? [Re: wazoo]
Wazoo, this is a FAQ entry. Please click here.
#99134 - 14/06/2002 12:04 Re: Will RioCar display to LCD in-dash monitor? [Re: wazoo]
eternalsun
Loc: San Jose, CA
The easiest way is to use a computer to fetch the image from the empeg over http or ftp or some mechanism and do a tv-out to the display.
Calvin
#99135 - 14/06/2002 12:29 Re: Will RioCar display to LCD in-dash monitor? [Re: eternalsun]
But if you're going to do an in-car computer, then why not go whole-hog with it and do the DVD player, MP3 playing, navigation, etc, all on the PC?
#99136 - 14/06/2002 13:36 Re: Will RioCar display to LCD in-dash monitor? [Re: tfabris]
eternalsun
Loc: San Jose, CA
Cost. I bet you can get a DOS based ftp utility, and a tv-out board that can display an image file. *shrug*
Calvin
#99137 - 14/06/2002 14:16 Re: Will RioCar display to LCD in-dash monitor? [Re: eternalsun]
lopan
Loc: Manassas VA
don't know.... but this lil guy is pretty cool, NS GXm SBC with 200MHz Low power CPU ,Audio,VGA/LCD,Ethernet and TV-out.... and I'm pretty sure if ya call em they'll even put an embedded OS on it for you. Granted it's not a Ghz processor but if your running low level stuff it wouldn't make a difference... you can put a laptop drive or a regular 3.5 HD (need to have a 12 volt power source) but the board can run a laptop drive and only need a 5v power source.... purty slick . I used something similar for a mp3 solution before I got the Riocar, mine didn't have a TV out... but pics are on this post at the bottom. You could slap a hub in your car, connect the TV out to your LCD and control the Riocar via the http interface.... there would be the question of how to control it (mouse/keyboard) without making it look junky....
Edited by lopan (14/06/2002 14:22)
Brett 60Gb MK2a with Led's
