#98448 - 09/06/2002 09:11 Actual output voltage? 4v?
newguy1
Loc: Massachusetts,USA
The specifications list 4v as the car outputs.I attemptedto verify this by measuring a 1kz test tone at 0db wav file.The measurement i got was less than 2 volts.Eq flat, balance ctr.How is the output measured/determined?I'd like to set my amp gains to the correct voltage other than just by ear. Thanks
MIKE 80Gb RIO
#98449 - 09/06/2002 09:31 Re: Actual output voltage? 4v? [Re: newguy1]
F0X
Loc: Alberta, Canada
What did you use to measure the voltage? I believe 4V is peak, so a with a sine wave input, the average voltage would be considerably lower.
F0X 3xMkIIa
#98450 - 09/06/2002 09:35 Re: Actual output voltage? 4v? [Re: F0X]
newguy1
I used an AC voltage meter which i believe is what the output form is.I have used this method with my pioneer cd player with decent results.
MIKE 80Gb RIO
#98451 - 09/06/2002 09:57 Re: Actual output voltage? 4v? [Re: newguy1]
F0X
Hmm. Unfortunately I dont know enough about car audio and the way things are labelled. A 1 kHz sine wave most definitely is AC, but I am not sure how it is interpreted in audio terminology. I am sure someone here knows much more than I.
Edited by F0X (09/06/2002 11:32)
F0X 3xMkIIa
#98452 - 09/06/2002 10:24 Re: Actual output voltage? 4v? [Re: newguy1]
0dB is not full-volume on the Empeg. Full volume is +??dB, which may require a configuration setting to make it available.
Edited by mlord (09/06/2002 10:25)
#98453 - 09/06/2002 10:41 Re: Actual output voltage? 4v? [Re: mlord]
newguy1
The 0db i was referring to was for the level of the sine wave.When i measured the output, the volume indicator on the Empeg read +10db Overdrive which appears to be the max but the measurement from the AC meter didnt quite make it to 2 volts(compared to the 4v spec)Im not trying to cause any waves here just want to set the amp with appropiate input
MIKE 80Gb RIO
#98454 - 09/06/2002 13:20 Re: Actual output voltage? 4v? [Re: newguy1]
thinfourth2
OKay i think that 4v means peak to peak but AC voltage is measured as average also dependant on your meter 1khz may confuse it if it was designed for mains at 60Hz but Hugo has said before on home to measure the output and i don't think a meter works.
#98455 - 09/06/2002 13:27 Re: Actual output voltage? 4v? [Re: newguy1]
snowwhite
Volt meters normally show an RMS level which would be about 3/4 of the peak value. As someone else pointed out a 1Khz tone is also very high (frequency) for a standard multimeter, a scope would be a better test.
PS, why do you care as long as it sounds loud enough?
#98456 - 09/06/2002 21:37 Re: Actual output voltage? 4v? [Re: snowwhite]
Actually most cheaper multimeters do not measure true RMS. If they do it's a big deal and there will be something like "True RMS" written on it somewhere.
And if it does read the true RMS and the signal is a pure sine wave then the peak value is 1.414 times the RMS value.
