#98255 - 07/06/2002 14:58 Mark l Drive Upgrade
Laura
Loc: Greenhills, Ohio
I am in the midst of doing a second drive install on my MKl. Any pointers on getting the drive cradle back in? Been at it for an hour now and just can't get it back in right. I had the drive upgrade FAQ up while doing it and had no problems until this point. Crap!
Laura
MKI #017/90
whatever
#98256 - 07/06/2002 15:06 Re: Mark l Drive Upgrade [Re: Laura]
For me, it was a question of deliberately bending and kinking the IDE cables different ways until they did what I wanted them to do.
The only thing you have to be careful of is that riser board in the back, don't put undue pressure on that riser board.
#98257 - 07/06/2002 15:17 Re: Mark l Drive Upgrade [Re: tfabris]
Laura
I finally got all the screws back in the sides. I'll put the top on and find out if I screwed up the display board or not. Very nerve racking for the first time
Laura
MKI #017/90
whatever
#98258 - 07/06/2002 15:22 Re: Mark l Drive Upgrade [Re: tfabris]
Laura
After all that work it doesn't find any drives. Back at it I guess, I was very careful putting the cables on making sure the pins were correct.
Laura
MKI #017/90
whatever
#98259 - 07/06/2002 15:24 Re: Mark l Drive Upgrade [Re: Laura]
Check to make sure the drives are found while they're still outside the case and loosely tethered. Did you format them both? Did you install the player software onto both?
#98260 - 07/06/2002 15:33 Re: Mark l Drive Upgrade [Re: Laura]
Connect up the serial port and see if the Linux kernel can "see" the drives .. it will print something like this:
Partition check:
hdc: hdc1 < hdc5 hdc6 > hdc2 hdc3 hdc4
There should be a line for each of "hda:" and "hdc:". The rest of the stuff on the lines will be bogus until you install the empeg software.
#98261 - 07/06/2002 15:35 Re: Mark l Drive Upgrade [Re: tfabris]
Laura
I just booted it up and Hyperterminal finds both drives but Emplode does not see the player. I thought that the second drive had the software already installed, according to the buyer it did. Would Emplode not find it if it didn't?
Laura
MKI #017/90
whatever
#98262 - 07/06/2002 15:38 Re: Mark l Drive Upgrade [Re: mlord]
Laura
This is what I get.
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
Prolux 4 empeg car - 2.1425 Feb 7 2002
Vcb: 0x4028d000
Laura
MKI #017/90
whatever
#98263 - 07/06/2002 15:43 Re: Mark l Drive Upgrade [Re: Laura]
Software is different between Mk1 and Mk2 players. Mk2 software on a Mk1 player is a no-no. Also, software version must match the emplode version, Emplode 1.03 against player 2.0b11 is a no-no.
Dunno if that's the reason, just a stab.
#98264 - 07/06/2002 15:51 Re: Mark l Drive Upgrade [Re: tfabris]
Laura
I'll try loading it and seeing what happens. He installed the software for the MKl using a MKll. Maybe that is why.
Laura
MKI #017/90
whatever
#98265 - 07/06/2002 15:59 Re: Mark l Drive Upgrade [Re: Laura]
Do the whole disk-formatter thingy from scratch, per the instructions on the upgrade page.
#98266 - 07/06/2002 16:04 Re: Mark l Drive Upgrade [Re: Laura]
That all looks good, the player software is even installed and running, though perhaps for the wrong model.
I would just try installing the beta11 upgrade over the serial link.
#98267 - 07/06/2002 16:10 Re: Mark l Drive Upgrade [Re: mlord]
Laura
Too late. I'm doing the whole disk builder thing from scratch. I'll see what happens when it is done. Been fun so far
Laura
MKI #017/90
whatever
#98268 - 07/06/2002 16:43 Re: Mark l Drive Upgrade [Re: Laura]
Laura
Done. It is all back together and working like it should, woohoo Now I can start loading more music on it.
Thanks for the help guys and thank you for the drive upgrade FAQ sheet Tony. It made it as easy as it was going to be.
Edited by Laura (07/06/2002 16:45)
Laura
MKI #017/90
whatever
#98269 - 07/06/2002 16:48 Re: Mark l Drive Upgrade [Re: Laura]
You're welcome. That'll be $20.00 please.
#98270 - 07/06/2002 17:18 Re: Mark l Drive Upgrade [Re: tfabris]
Laura
Well worth it. The check is in the mail.......
Laura
MKI #017/90
whatever
#98271 - 08/06/2002 04:29 Re: Mark l Drive Upgrade [Re: tfabris]
Sounds like a Vegas line..
