#98066 - 06/06/2002 16:55 Hijack with FAT support and the DSP mod for S/PDIF
Hi,
I've compiled the new Hijack kernels with the extra bits people wanted. Usual place
v2.00b11 with Hijack v273 and FAT support is here
v2.00b11 with Hijack v273 and the DSP modifications needed for the S/PDIF board is here
- Trevor
#98067 - 06/06/2002 16:58 Re: Hijack with FAT support and the DSP mod for S/PDIF [Re: tman]
Sheeesh. Out of date already!
#98068 - 06/06/2002 17:13 Re: Hijack with FAT support and the DSP mod for S/PDIF [Re: mlord]
Argh. You work too quickly!
Okay. Second time lucky!
Hijack v274 with FAT support
Hijack v274 with DSP mod
- Trevor
#98069 - 29/06/2002 02:56 Re: Hijack with FAT support and the DSP mod for S/PDIF [Re: tman]
v278 for all those interested...
Hijack v278 with FAT support
Hijack v278 with DSP mod
- Trevor
#98070 - 09/07/2002 07:31 Re: Hijack with FAT support and the DSP mod for S/PDIF [Re: tman]
v280 is at the usual place here. I also fixed the dodgy PHP which was making the page appear blank... Oops.
Hijack v280 with FAT support
Hijack v280 with DSP mod
- Trevor
#98071 - 09/07/2002 09:01 Re: Hijack with FAT support and the DSP mod for S/PDIF [Re: tman]
maczrool
Loc: Louisiana, USA
Does your mod also have the beep fix? What does this DSP mod do? I'd just try it, but it requires a serial port to install if I remember correctly, and I don't have access to one at the moment.
Thanks,
Stu
#98072 - 09/07/2002 09:04 Re: Hijack with FAT support and the DSP mod for S/PDIF [Re: maczrool]
The DSP mod is the fix for the beeps. That's it.
If you've got Hijack already installed then you can FTP it over but otherwise yes, you do need the serial port to upgrade it.
- Trevor
#98073 - 09/07/2002 09:08 Re: Hijack with FAT support and the DSP mod for S/PDIF [Re: tman]
maczrool
Loc: Louisiana, USA
Thanks. I guess I was confusing it for a subwoofer out mod. I personally don't need or want a sub out board, but it has been brought to my attention that others do. Any thoughts on how to mod the kernel to enable the DSP's sub out?
Stu
#98074 - 09/07/2002 09:17 Re: Hijack with FAT support and the DSP mod for S/PDIF [Re: maczrool]
I should really name it better next time. It's basically the v2.00b11 empeg kernel with Hijack v280 and the changes in the DSP initialisation that reenables the beeps. The kernel with FAT support actually has the DSP changes as well.
As for the subwoofer, I'll have a look at the manual for the DSP tonight when I get home. It shouldn't be too hard (famous last words... )
- Trevor
#98075 - 09/07/2002 12:22 Re: Hijack with FAT support and the DSP mod for S/PDIF [Re: tman]
justinlarsen
Loc: Petaluma, CA
u know tman, with a glass of wine and a back rub, you can probably talk mark into implating the code.
---- Justin Larsen
#98076 - 24/07/2002 12:52 Re: Hijack with FAT support and the DSP mod for S/PDIF [Re: tman]
I've put the kernels with mods for v2.00b13 with Hijack v281 at usual place
Kernel with DSP changes for S/PDIF here
Kernel with FAT support here
There is no harm in using either kernel with a stock player.
Enjoy
- Trevor
#98077 - 24/07/2002 16:26 Re: Hijack with FAT support and the DSP mod for S/PDIF [Re: tman]
Argh. Mark's done it again! I get a new version up and he supercedes it
Usual place
- Trevor
#98078 - 24/07/2002 16:35 Re: Hijack with FAT support and the DSP mod for S/PDIF [Re: tman]
Can you send me a patchfile showing your diff's from stock Hijack?
#98079 - 24/07/2002 16:50 Re: Hijack with FAT support and the DSP mod for S/PDIF [Re: mlord]
Sure. The patch needed for the S/PDIF board is attached to this message. It just changes the initialisation of one of the DSP registers. I've not noticed any problems with running it on a stock player as well so it should be safe.
- Trevor
105684-spdif.patch (219 downloads)
#98080 - 24/07/2002 18:19 Re: Hijack with FAT support and the DSP mod for S/PDIF [Re: tman]
Usual place for v283
- Trevor
#98081 - 25/07/2002 18:30 Re: Hijack with FAT support and the DSP mod for S/PDIF [Re: tman]
Okay, this patch (which did not apply cleanly for me, but I managed to do it by hand) will be in Hijack v284.
#98082 - 25/07/2002 18:34 Re: Hijack with FAT support and the DSP mod for S/PDIF [Re: mlord]
Oops. I've moved some stuff around and must have a slightly different kernel tree than you. It's basically changing the OutSwi lines anyway. Should only be a few references of it.
- Trevor
#98083 - 27/07/2002 09:09 Re: Hijack with FAT support and the DSP mod for S/PDIF [Re: tman]
Updates for Hijack v285. There is a mistake in the S/PDIF patch for v285. It's fixed in the compiled version below and I've sent Mark the fix.
Usual place here
FAT support kernel here
S/PDIF kernel here
- Trevor
#98084 - 02/08/2002 12:08 Re: Hijack with FAT support and the DSP mod for S/PDIF [Re: tman]
FAT support for v291
Usual place here
- Trevor
