#96357 - 29/05/2002 13:40 another question for you guys
visuvius
On another computer,
It has two OS's installed, 98 and XP. I was on 98 and installed McAfee. Now when it restarts, and i choose to go to 98, it does this virus check where it says, Pass1 Pass2 etc. etc. etc., and it stops on Pass14 and doesn't go any further, HOWEVER, XP will load. How the hell do i fix this?
If i just delete the McAfee folder in XP, will it stop the virus checking? Or i guess, how do i uninstall a program thats on another OS?
i know this isn't a tech support forum, but i'm not gettin' any luck today.
#96358 - 29/05/2002 13:43 Re: another question for you guys [Re: visuvius]
Go all the way into Windows 98 when it gives you the multi-boot choice. While inside Windows 98, de-install the McAfee software.
Then go into Windows XP and install the XP-compatible version of McAfee.
#96359 - 29/05/2002 13:49 Re: another question for you guys [Re: tfabris]
visuvius
thats the thing though, it won't load Windows 98. It stops on Pass14 and just does nothing. My problem is not being able to get to Windows 98.
#96360 - 29/05/2002 13:50 Re: another question for you guys [Re: visuvius]
Dearing
Loc: Florida
Try booting win98 in Safe Mode
_~= Dearing =~_
#96361 - 29/05/2002 13:50 Re: another question for you guys [Re: visuvius]
Try pressing ctrl+C or ctrl+break before it locks up.
#96362 - 29/05/2002 13:53 Re: another question for you guys [Re: Dearing]
visuvius
how do i get to the option where it will let me choose?
#96363 - 29/05/2002 13:59 Re: another question for you guys [Re: visuvius]
Dearing
Loc: Florida
If you've got the WIN98 bootup menu activated (with a timeout larger than 0 seconds if you use TweakUI), then you can select safe mode from that boot menu. Note that this is the menu after you've already selected wich OS to load. It's the same boot menu that lets you boot into "Command Prompt Only", etc.
If you don't have that menu, then holding down <CTRL> during the WIN98 boot sequence should bring up the boot menu.
Good Luck.
_~= Dearing =~_
#96364 - 29/05/2002 14:01 Re: another question for you guys [Re: Dearing]
I didn't know about holding down CTRL. I always just pressed F8 when it said "starting Windows 98".
#96365 - 29/05/2002 14:03 Re: another question for you guys [Re: tfabris]
Dearing
Loc: Florida
Yeah. I couldn't remember if F8 was step-by-step load, or if it was "boot Previous OS". I just found that CTRL trick on google, and I haven't tested it.
_~= Dearing =~_
#96366 - 29/05/2002 15:37 Re: another question for you guys [Re: Dearing]
I believe F5 automatically selects the safe mode, without having to choose it from the menu.
#96367 - 29/05/2002 16:09 Re: another question for you guys [Re: BartDG]
visuvius
i love you guys.
#96368 - 30/05/2002 17:52 Re: another question for you guys [Re: visuvius]
muzza
ten points if you can tell how to get into the bios on Dell, IBM, HP and Packard Bell machines.
#96369 - 30/05/2002 17:54 Re: another question for you guys [Re: muzza]
Most of my Dells, it's F2 during boot.
Depends on the BIOS more than the manufacturer.
#96370 - 30/05/2002 20:13 Re: another question for you guys [Re: muzza]
I remember computers (usually in the 286-386 days) where you had to run a program from within MS- (or PC- or DR- or whatever-) DOS in order to get to the BIOS. Good luck if you were running something else....
But these days, usually Del on direct-to-market motherboards and F2 on Dell, Gateway, etc., but YMMV.
#96371 - 30/05/2002 21:15 Re: another question for you guys [Re: muzza]
dcosta
Loc: Massachussetts
I've seen F2, Delete and F8 used as the key to press during boot.
__________ davecosta Hijacked 60GB MKIIa 2.0b13
#96372 - 30/05/2002 21:31 Re: another question for you guys [Re: dcosta]
ricin
Loc: US: CA
As well as F10 for most Compaq's (some use F12). Better yet, just mash the keyboard, you're bound to hit a key that'll get you in
Donato
MkII/080000565
MkIIa/010101253
ricin.us
#96373 - 31/05/2002 04:04 Re: another question for you guys [Re: ricin]
If nothing else, it'll cause a "Keyboard error, press space to continue, or press F-something to enter the BIOS". Often, that's quite a useful way to figure it out.
Old Phoenix BIOS used Ctrl+Alt+S, IIRC.
#96374 - 31/05/2002 15:25 Re: another question for you guys [Re: Roger]
lectric
Loc: New Orleans, LA
I have also seen Ctrl-Alt-S for Setup.
#96375 - 31/05/2002 16:19 Re: another question for you guys [Re: tfabris]
Satan_X
Loc: Ramsey, NJ
from supporting 4000 pc's, I must say the 'mash the keyboard' method is foolproof (and good stress relief)
VW R32 Empeg 50gig 'Stormy 3 has snuck in a dodgeball' - Stormy 1
