#95960 - 27/05/2002 17:16 20 = 1 or 2 hdd?
Gunnar
Hi
I was just wondering if my 20GB player has got 2x10GB or 1x20GB harddrives.
and what brand are they?
Daniel Gunnarsson Sweden
#95961 - 27/05/2002 17:55 Re: 20 = 1 or 2 hdd? [Re: Gunnar]
Install Hijack, and then go to the "Vital signs" screen from the Hijack menu.
Or,
Install Hijack, connect to ethernet, and point your web browser at http://your.empeg.ip.addr/proc/ide/hda/model and again at http://your.empeg.ip.addr/proc/ide/hdb/model
#95962 - 27/05/2002 18:08 Re: 20 = 1 or 2 hdd? [Re: mlord]
...Or hook up terminal services, watch the boot sequence and see if there are two drives found on it. Sometimes the direct approach is easiest.
#95963 - 27/05/2002 20:02 Re: 20 = 1 or 2 hdd? [Re: pgrzelak]
genixia
...or shine a torch through the vent on the top to see how many drives there are, although that won't tell you who made them.
#95964 - 28/05/2002 01:49 Re: 20 = 1 or 2 hdd? [Re: Gunnar]
David
Loc: Cambridge
Unless it has been upgraded, it will have one 20GB drive.
#95965 - 28/05/2002 03:49 Re: 20 = 1 or 2 hdd? [Re: David]
Unless it's a very old player - Mk.1's had 2x10GB.
#95966 - 28/05/2002 04:40 Re: 20 = 1 or 2 hdd? [Re: pgrzelak]
But that won't show the make/model. Only /proc/ide/*/model shows that information.
#95967 - 28/05/2002 04:57 Re: 20 = 1 or 2 hdd? [Re: mlord]
Greetings!
It does. Granted, not much detail and a little cryptic, but a quick google search can translate the code to the make / model, if the code itself doesn't help. I know some drives are easier to read than others...
empeg single channel IDE
Probing primary interface...
hda: IC25T060ATCS05-0, ATA DISK drive
hdb: IC25T060ATCS05-0, ATA DISK drive
hda: IC25T060ATCS05-0, 57231MB w/1768kB Cache, CHS=7296/255/63
hdb: IC25T060ATCS05-0, 57231MB w/1768kB Cache, CHS=7296/255/63
IBM Travelstar 60
hda: IBM-DJSA-220, ATA DISK drive
hdb: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
hdb: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
IBM Travelstar 20
#95968 - 28/05/2002 06:00 Re: 20 = 1 or 2 hdd? [Re: pgrzelak]
Doh! But of course you are correct.
Just shows how much I've forgotten about code I wrote a while ago..
#95969 - 28/05/2002 07:08 Re: 20 = 1 or 2 hdd? [Re: mlord]
No problem. See, you thought of this problem with the empeg long in advance of the unit ever being built!!! I think someone owes you royalties...
