#95635 - 23/05/2002 21:00 Riocar stuck on Building Music Databases
JeepBastard
Loc: Brooklyn
My Riocar is stuck on Building Music Databases. I have The Developer Image and Hijack Installed.
I can connect only via serial port , but I cannot drop to shell (when i press Q , Ctrl-A or Ctrl-T it just ignores it?
Here is the output i get:
Partition check:
hda:hda: set_geom(16383,16,63)
[PTBL] [2432/255/63] hda1 < hda5 hda6 > hda2 hda3 hda4
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init
empeg init 0.8
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting player
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
! tags.cpp : 61:Failed to open tags (0xc0041002).
[ then it repeats this next block ad infinitum]:
attempt to access beyond end of device
03:04: rw=0, want=1073758212, limit=19430617
dev 03:04 blksize=1024 blocknr=1073758211 sector=-2147450874 size=1024 count=1
EXT2-fs error (device ide0(3,4)): ext2_readdir: directory #129 contains a hole at offset 0
Remounting filesystem read-only
any suggestions? I am still combing the FAQ and I haven't yet opened the device yet to check for loose cables.
my current blog
#95636 - 23/05/2002 21:03 Re: Riocar stuck on Building Music Databases [Re: JeepBastard]
JeepBastard
Loc: Brooklyn
I also am now getting Hard Drive Not Found / Customer Support message intermittently.
It wont allow me to flash to an older kernel either.
my current blog
#95637 - 23/05/2002 21:27 Re: Riocar stuck on Building Music Databases [Re: JeepBastard]
BAKup
Loc: Houston, TX
It's either a loose cable(more likely), or the HD going bad(less likely).
--Ben
78GB MkIIa, Dead tuner.
#95638 - 24/05/2002 10:00 Re: Riocar stuck on Building Music Databases [Re: BAKup]
JeepBastard
Loc: Brooklyn
i actually bought it second hand.
I opened it up and the cables aren't loose.
i guess my only option is to replace the drive.
my current blog
#95639 - 24/05/2002 10:45 Re: Riocar stuck on Building Music Databases [Re: JeepBastard]
What is the serial number of this unit?
Before scrapping the hard drive, try reinstalling EVERYTHING from scratch.
#95640 - 24/05/2002 12:10 Re: Riocar stuck on Building Music Databases [Re: mlord]
JeepBastard
Loc: Brooklyn
I can't get it to reinstall any image at the moment.
Should I try installing that disk rebuilding image?
my current blog
#95641 - 24/05/2002 14:58 Re: Riocar stuck on Building Music Databases [Re: JeepBastard]
Yes, that's what I would try.
#95642 - 24/05/2002 15:56 Re: Riocar stuck on Building Music Databases [Re: JeepBastard]
David
Loc: Cambridge
You probably have a faulty drive cable. email me for a replacement.
#95643 - 24/05/2002 16:03 Re: Riocar stuck on Building Music Databases [Re: JeepBastard]
i actually bought it second hand. I opened it up and the cables aren't loose. i guess my only option is to replace the drive.
No.
First, contact David in support and replace the cable.
Even if the connectors are plugged in tight, the cable and/or connectors themselves are probably faulty. It is about 80% likely that this is your problem.
#95644 - 24/05/2002 18:20 Re: Riocar stuck on Building Music Databases [Re: tanstaafl.]
justinlarsen
Loc: Petaluma, CA
ya dont give up hop, i thought my drive was bad, but i just messed with the jumped, you dont happen to have a double drive unit do ya?
---- Justin Larsen
#95645 - 05/06/2002 16:03 Re: Riocar stuck on Building Music Databases [Re: JeepBastard]
JeepBastard
Loc: Brooklyn
Thanks Empeg!
I got my cable promptly! I really appretiate it.
I replaced the cable but unfortunately it didnt solve the problem.
I get NO HARD DISK FOUND CONTACT SUPPORT with the new cable.
When i go back to the old one.. i stillg et stuck on Building music database
my current blog
#95646 - 05/06/2002 16:08 Re: Riocar stuck on Building Music Databases [Re: JeepBastard]
Be absolutely certain that you do not have the new cable installed with a one-pin offset from its correct position either on the hard drive or the mainboard. The IBM Travelstar drives are built in such a fashion that it is not only easy to offset the cable by one pin, it actually looks more "correct" that way.
#95647 - 05/06/2002 16:40 Re: Riocar stuck on Building Music Databases [Re: tanstaafl.]
JeepBastard
Loc: Brooklyn
I actually have a 20 gig Hitachi Drive in there .. I'm still trying of course
my current blog
