#94636 - 19/05/2002 12:09 No worky(internal fuse?)
suitjason
Yesterday I fumbled my Empeg while getting out of the car. It was in its case and it only fell about a foot. Problem is now that it does not start up. At home when first plugged in the Blue light to the right briefly lights and nothing more. Same thing happens in the car when the ignition is turned on. I have looked inside to verify everthing is connected. Everything looks fine. I was wondering if there is an internal fuse? Any ideas?
Jason
#94637 - 19/05/2002 13:17 Re: No worky(internal fuse?) [Re: suitjason]
Yes, there are several internal fuses. Maybe it's something as simple as a connector that got jarred loose. Please contact support by e-mailing carsupport@riohome.com and they can help you diagnose what might be wrong.
#94638 - 20/05/2002 09:39 Re: No worky(internal fuse?) [Re: suitjason]
beaker
Loc: England
Are you absolutely sure it's not just the nipple broken off the VFD? If this has happened and the player's in pause mode it would look like the player's dead. Have you tried pressing the top button to see if it starts playing?
Just an idea.
#94639 - 20/05/2002 10:12 Re: No worky(internal fuse?) [Re: beaker]
Yeah, pics of a broken nipple are in the FAQ now, here. So check that.
#94640 - 21/05/2002 18:46 Re: No worky(internal fuse?) [Re: tfabris]
ineedcolor
Loc: Windsor, Ontario Canada
I had to ship my player across Canada when I first received it from overseas...When I powered it up at the other end, I found I had the exact same symtoms as described above. I shook the player slightly and it rattled...soon the tell-tale broken nipple fell out of the case. Sure enough, my VFD was gone. It cost me a big dollar to get it replaced.
Sorry for the bummer news if that's what your problem turns out to be...
#94641 - 25/05/2002 11:00 Re: No worky(internal fuse?) [Re: ineedcolor]
suitjason
My VFD is still in place. I noticed the red LED on the inside does not light. Looks like i am going to ship it back to the UK for repair. Thanks for all your help
Jason
